[Geoserver-devel] geoserver WMS performance issue
Hi Everybody,
I am using geoserver 2.8.3 with Oracle NG (JNDI) datasource. i have an SQL View based wms layer.
I noticed that at org.geoserver.catalog.ResourcePool.java (line 929 ) there is an internal check witch queries tha database at every WMS request.
the select is the following :
SELECT NULL AS table_cat,
o.owner AS table_schem,
o.object_name AS table_name,
o.object_type AS table_type,
NULL AS remarks
FROM all_objects o
WHERE o.owner LIKE :1 ESCAPE ‘/’
AND o.object_name LIKE :2 ESCAPE ‘/’
AND o.object_type IN (‘xxx’, ‘TABLE’, ‘VIEW’, ‘SYNONYM’)
ORDER BY table_type, table_schem, table_name;
Can somebody tell me why this query is running at every WMS request. Is a name
collision detection with database objects needed at every WMS request ? because i thing this is a performance issue and a bug.
Or maybe i missing something …
Thanks for Help,
Kiss Attila
Hi Attila,
fancy that, I looked at this a few days ago and I believe this is caused by a change
made some time ago in a commit message titled “Resource Pool performance patch from Ordnance Survey”. I see
a pull request for it here, even if the change got committed directly afterwards:
https://github.com/geoserver/geoserver/pull/396/files
What I did not see back then is that now the check for cacheabiliy includes the handleProjectionPolicy flag,
if false there is no caching… which is a problem since we always call with that flag at false while grabbing
the feature source, and for sql views in particular, we have extra machinery that makes sure the view cannot
be cached (there are reasons for that, cannot be removed, or two separate requests would end up stepping on
each other toes).
So… if anything I would remove the “&& handleProjectionPolicy” here:
https://github.com/geoserver/geoserver/blame/master/src/main/src/main/java/org/geoserver/catalog/ResourcePool.java#L883
Kevin, do you know if there was a good reason to add it in the first place?
Attila, if you have the code handy could you verify if my suggestion helps (as in, improves performance, and
causes no other obvious problems?)
On Mon, Jun 6, 2016 at 5:00 PM, Kiss Attila <kiss.attila@anonymised.com> wrote:
Hi Everybody,
NULL AS remarks
FROM all_objects o
Thanks for Help,
Kiss Attila
Ez a levél vírus- és spammentes. | This e-mail is virus-free.
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
That coud work in my case, but i cannot see the wool graph, my opinion is that in oracle type DataStore, this name collision check is useless because, in Oracle you cannot have UID type Object names (e.g 8cddb91e-c522-4134-b6ae-24443c4dc9c0) so that collision is never happening.
so this check should be run only if info.store.type not equal Any oracle type datastore )
Attila
Feladó: andrea.aime@…403… [mailto:andrea.aime@…403…] Meghatalmazó Andrea Aime
Küldve: 2016. június 6. 17:52
Címzett: Kiss Attila <kiss.attila@…4468…>; Kevin Smith <ksmith@…3839…>
Másolatot kap: geoserver-devel@lists.sourceforge.net
Tárgy: Re: [Geoserver-devel] geoserver WMS performance issue
Hi Attila,
each other toes).
On Mon, Jun 6, 2016 at 5:00 PM, Kiss Attila <kiss.attila@…4468…> wrote:
Hi Everybody,
NULL AS remarks
FROM all_objects o
Thanks for Help,
Kiss Attila
Ing. Andrea Aime
@geowolf
Technical Lead
here is the solution:
create an empty "all_objects" table in the same schema as the geoserver to
Oracle db connection; this table will become a facade table for the
nonsensical call, bypassing the actual "all_objects" system view
e.g.:
create table <your geoserver login user>.all_objects
as
SELECT
         o.owner,
         o.object_name,
         o.object_type
    FROM all_objects o
   WHERE
1 = 0
View this message in context: http://osgeo-org.1560.x6.nabble.com/geoserver-WMS-performance-issue-tp5270153p5309930.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
