Hello !
I was trying the tutorials in the Programming Guide for geoserver and i run
into some problem.
In the tutorial for creating a WPS Services
(http://docs.geoserver.org/stable/en/developer/programming-guide/wps-services/implementing.html)
maven didn`t find org.geoserver.wps.gs.GeoServerProcess.
If commented that line out i could build/install the project, so it seams
like Maven can`t find the class.
Which i thinks is strange because i have followed the tutorial quite
carefully.
So i would really appreciate tips where to start, when solving this problem.
I`m quit new to Maven, but not to programming.
Setup:
OSX Mavericks
Apache Maven 2.2.1
Java verision: 1.6
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoServer-WPS-Maven-Build-failed-tp5135084.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
