Hi everyone, I have seen that GeoServer works with MySQL and Postgresql, I wish your opinion, With which of these two databases, to geoserver works better with geographic data?
I try to handle with geoserver the cadastre of a whole region.
Regards.
Hi everyone, I have seen that GeoServer works with MySQL and Postgresql, I wish your opinion, With which of these two databases, to geoserver works better with geographic data? I try to handle with geoserver the cadastre of a whole region.
PostGIS, and not just because Refractions sponsors it Much more time has been spent on PostGIS support w/ respect to conformance testing with CITE and optimization.
Definitley PostGIS. Postgis support in geotools is one of the better maintained and used modules so it is very stable. Not to knock MySQL, its just that postgres/postgis is very easy to install and use, which makes it very easy to support and test.
-Justin
Jody
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files
for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD SPLUNK! http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click
Geoserver-devel mailing list
Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
I will point out he is the PostGIS module maintainer
Darn, Jody caught me tooting on my own horn again. To my defense I have only been the module maintainer for about a month now and cant take credit for the robustness of the module :).
interesting, I am trying to create datastore for Postgresql 8,1, but there is an error:
ERROR: function postgis_version() does not exist
I have installed GeoServer 1.3 RC6, What more I need to install to support Postgresql 8.1?
Regards.
To: /Justin Deoliveira <jdeolive@anonymised.com>/
CC: /Mauricio Lopez
<mauriciolopez32@anonymised.com>,geoserver-devel@lists.sourceforge.net/
Subject: /Re: [Geoserver-devel] Geoserver/
Date: /Tue, 13 Dec 2005 15:54:45 -0800/
Descubre la descarga digital segura. Medio millón de canciones en MSN Music. <http://g.msn.com/8HMAESES/2755??PS=47575>
(The contents of this could be moved to the geotools wiki by someone with appropriate priveleges.)
Rob Atkinson
Regards.
CC: /Mauricio Lopez
Descubre la descarga digital segura. Medio millón de canciones en MSN Music. <http://g.msn.com/8HMAESES/2755??PS=47575> ------------------------------------------------------- This SF.net email is sponsored by: Splunk Inc. Do you grep through log files for problems? Stop! Download the new AJAX search engine that makes searching your log files as easy as surfing the web. DOWNLOAD SPLUNK! http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click _______________________________________________ Geoserver-devel mailing list Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Everyone has appropriate priveleges, you just need to sign up for a
confluence account, put your email and password. Would be nice to have
information in the geoserver wiki as well.
Also Mauricio, if you're using Windows the postgresql installer has an
option for PostGIS, it's not on by defualt, but you just need to click
it and you'll be set up.
Chris
Rob Atkinson
but
> there is an error:
> Regards.
> From: /Jody Garnett <jgarnett@anonymised.com>/
> CC: /Mauricio Lopez
to
install
MSN
for
SPLUNK!
log files
