Uaaaaaaaaah
The translation property files are loaded in this manner
InputStream in = url.openStream();
properties.load(in);
reader.close();
The load method of the Properties class requires ISO-8859.
http://download.oracle.com/javase/1.5.0/docs/api/java/util/Properties.html#load(java.io.InputStream)
Special chars have to be escaped with \u.
This is extremly unlucky,making translations will drive you crazy.
Since Java 1.6, you can do the following
InputStreamReader reader = new InputStreamReader(in);
properties.load(reader);
reader.close();
I tested this sequence, works perfectly, but only for Java 1.6
Another possibility is to use
http://download.oracle.com/javase/1.4.2/docs/tooldocs/windows/native2ascii.html
This possibility requires to store 2 files, GeoServerApplication.properties and GeoServerApplication.utf8, the second for editing, the first for geoserver.
Opinions ?
Christian
Quoting Justin Deoliveira <jdeolive@anonymised.com>:
I would say using UTF encoding for files probably makes most sense. The
question is where in the code are the files being read in a way that does
not respect the file encoding. My guess would be in the
GeoServerResourceStreamLocator class where we read the property file.
On Tue, Jan 11, 2011 at 7:39 AM, <christian.mueller@anonymised.com> wrote:
Hi, I have a set of of GeoServerApplication_de.properties files for a
German translation for the GeoServer admin GUI.
The files are encoded UTF-8.
I can see the German special characters on linux /windows with any
editor or browser, only the geoserver admin GUI displays garbage.
The majority off the property files are ASCII text, some of them are
UTF-8, an an example for French
./wms/src/main/resources/GeoServerApplication_fr.properties: UTF-8
Unicode English text
Is it possible to use UTF-8 or do I have to recode ?
This message was sent using IMP, the Internet Messaging Program.
Gaining the trust of online customers is vital for the success of any
company
that requires sensitive data to be transmitted over the Web. Learn how to
best implement a security strategy that keeps consumers' information secure
and instills the confidence they need to proceed with transactions.
http://p.sf.net/sfu/oracle-sfdevnl
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
