[Geoserver-devel] GeoServerLoader doesn't allow for non XSTream loaders
Hey,
I found that though there's a ServiceLoader extension point,
GeoServerLoader explicitly limits itself to XSTreamServiceLoaders. Now,
I wonder if that is just to avoid LegacyServiceLoaders from messing up
the normal operation, and if so, I would like to propose the following
patch: <http://pastebin.com/BT18jEN3&gt;
Rationale being that I want to load GWC provided services by its own
means, so as to reuse GWC's configuration persistence while at the same
time being able to configure the services through the UI.
Thoughts?
Gabriel
Gabriel Roldan
groldan@anonymised.com
Expert service straight from the developers
Sounds good. +1.
On Tue, Sep 21, 2010 at 3:42 PM, Gabriel Roldán <groldan@anonymised.com> wrote:
Hey,
I found that though there’s a ServiceLoader extension point,
patch: <http://pastebin.com/BT18jEN3>
means, so as to reuse GWC’s configuration persistence while at the same
Thoughts?
Gabriel
Gabriel Roldan
Justin Deoliveira
OpenGeo - http://opengeo.org
