[Geoserver-devel] GeoServerNodeInfo outside of wicket UI
Hi folks,
I have a need where I would like to get access to data provided via GEOSERVER_NODE_OPTS but in a module that doesn’t depend on the UI modules. Currently it looks like all the infrastructure for parsing and representing the parameter lives in the web modules. While I could just add a dependency on web-core I was thinking it potentially made sense to move some of that stuff info main.
What I am thinking is this:
  • Introduce an interface named something like GeoServerNodeData that would be the “data object” for the properties stored in the node opts parameter. It would also come with a default implementation that does all the non-UI bits of what DefaultGeoServerNodeInfo does now.
  • Update GeoServerNodeInfo adding an accessor to get at the “node data”. Something like:
      interface GeoServerNodeInfo {
          GeoServerNodeData getData();
  • Update GeoServerNodeInfo.getId() to call through to getData(), and/or perhaps deprecate it?
          default String getId() {
             return getData().getId();
Does that make sense? If folks are ok with the idea I’ll whip up a patch. I am happy to do a proposal as well but I think the changes for this one should be pretty minimal and non-distruptive.
Thanks!
-Justin
That sounds fine, you just need this at the java level right, no rest api access for node info.
On 30 January 2017 at 08:23, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi folks,
Thanks!
-Justin
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Jody Garnett
Hey Jody,
Correct, I just need it at the java level, no apis required at this time.
-Justin
Jody Garnett
Hi folks,
Thanks!
-Justin
Excellent - bring it on :slight_smile:
Hi folks,
Thanks!
-Justin
Jody Garnett
You asked for it :stuck_out_tongue:
https://github.com/geoserver/geoserver/pull/2079
Jody Garnett
Hi folks,
Thanks!
-Justin
