Hello!
I would like to propose PR for fix empty config files. This fix concerns the main module of geoserver - I’m not sure if an outsider can make such PR?
Here I described the problem:
https://osgeo-org.atlassian.net/browse/GEOS-9244
I see that the code that populates the file with the default values is located in the catch block in the loadProperties method:
https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/org/geoserver/config/GeoServerPropertyConfigurer.java#L101
However, during debugging, I’ve observed that FileNotFoundException is never thrown by the loadProperties of the PropertiesLoaderSupport Spring class. After exiting this method, the file is already created (empty).
I propose to remove try-catch block and to check if config file is empty instead:
@Override
protected void loadProperties(Properties props) throws IOException {
super.loadProperties(props);
if (configFile != null && copyOutTemplate && configFile.file().length() == 0) {
try (OutputStream fout = configFile.out()) {
props.store(fout, comments);
fout.flush();
I’m not sure about the use of file() method (it has side effects - creates a file) in this case, but I have no other idea. What do you think about it?
I also added a new test method detecting this error:
@Test
public void testSaveDefaultsToConfigFile() throws IOException {
FileInputStream in = new FileInputStream(“target/foo.properties”);
Properties prop = new Properties();
prop.load(in);
assertEquals(“value1”, prop.get(“prop1”));
assertEquals(“value2”, prop.get(“prop2”));
Greeting,
Joanna Jółkowska
OPEGIEKA Sp. z o.o., al. Tysiąclecia 11, 82-300 Elbląg, www.opegieka.pl
Bank Millennium S.A., PL: 84 1160 2202 0000 0000 6191 2549, EUR: PL 71 1160 2202 0000 5296 6311,
SWIFT CODE: BIGBPLPW. Sąd Rejonowy w Olsztynie, VIII Wydział Gospodarczy Krajowego Rejestru
Sądowego, KRS 0000190471, NIP 5780004498, REGON 001364260.
Kapitał zakładowy/wpłacony 101 000 PLN.
