I upgraded the icons we had to the latest revision (GEOS-3556) and used
the occasion to make the layers and preview page use a type specific
icon: instead of just "vector" the icon now tells the user if the
layer is a point, line or polygon (using the old icon for unspecified
vector layers).
I've attached a sample screenshot. What do you think?
Andrea Aime
OpenGeo - http://opengeo.org
Thanks for sending this, Andrea. I had meant to email the list about the updated raster and vector icons before RC2 went final (as you suggested) but I was on vacation at the time and dropped the ball.
icon: instead of just “vector” the icon now tells the user if the
vector layers).
I’ve attached a sample screenshot. What do you think?
vector layers).
It makes enough sense imho. An icon with a mix of points, lines and
polygons might represent better the undeterminate-dness of the geometry
type, but at the same time it could become quite dense graphically
wise (to the point of being confusing).
Another minor detail is about the raster icons, on my screen the contrast between the pixels is low and at a first glance the icon
might seem just a square with some pattern fill inside (i.e., it's
not readily apparent that it's actually a grid).
Andrea Aime
I can certainly edit them (that's what version control is for, after all). Does the attached work better? Need still more contrast?
As for the generic vector icon i do agree that having the mix of the three would be the best, but understandable it is hard to pull off with that many pixels.
Another nice to have may be to represent multi geometries, having the point icon have multiple points, line string icons with multiple line strings, etc... again maybe a bit hard to pull off with a limited amount of real estate to work with. But just a thought.
vector layers).
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day trial. Simplify your report design, integration and deployment - and focus on what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
This should be passed on to the graphics@anonymised.com email list where
projects are also trying to work with a similar mandate (ie visual
harmonization across projects).
vector layers).
There is one weakness with the new icons that I tried to address when
I took a run at this; often we have an unknown "Geometry" and need to
represent point, line, and polygon via the same image. If I do that
with the images provided it ends up looking like a rectangle that has
been crossed out.
Yup, it indeed works better. More contrast... maybe make the light
pixels a bit lighter? Otherwise it's good as it is.
Remember I don't have a Mac so my color profile is different, plus
my color perception is different as well (the set of color shades
I actually see is lower than the one of a person with normal color
perception) so both might be concurring in my difficulty to recognize
the grid at a glance.
Andrea Aime
vector layers).
been crossed out.
vector layers).
been crossed out.
Well, it does not seem to convey the idea that the geom type is vector but unkonwn. Looking at it I have the impression of looking at a polygon
layer with blue fill (a sort of a mini sample map).
Andrea Aime
been crossed out.
This is why—despite how great it looks—I was wary of going into detail beyond raster/vector on that page rather than using a 'generic' vector icon.
Combining all three geom types into one icon obvious won't work in such a constrained space (nor does cominbation really convey the idea of 'unknown' geom type) and, once that is settled, we'll run into issues with the modified icons (eg, the add vector, vector file, WFS, etc. icons on http://projects.opengeo.org/geosilk/).
I'll keep thinking of ways to deal with the generic/unknown vector issue but I'm definitely open to further suggestions.
It is not that - the point of the udig icon set is to use a consistent set of combinations. So you change the generic vector icon you need to update the icons that depend on that.
So we have a good place to start; once the look of the layer (point / line / poly) is established; and we have a generic geometry defined we need to remember to update the different datastore icons to match (ie server + generic feature overlay).
I don't mind updating the udig icon set to match what is decided here; or we could go move to the graphics@anonymised.com list if you like.
So there are two things to think about:
- my rant about combining poly / point / shape to represent generic is mostly of concern to me when I create the icon based on the current style (it looks like you have just drawn them with a paint program? I have some code that draws them based on SLD settings). As such I want to make sure the "point" does not get confused with the polygon or line.
One thing that I think would be powerful here is to leave the raster as a square shape; and see if we can make the polygon shape non square to tell them apart at different sizes; would a diamond work? Or would knocking the top left corner off the square work?
I think we got two ideas on the table here:
- difference between raster and vector
- once you have established vector the ability to communicate polygon, point, or line (if known). If unknown perhaps we could stick to a generic vector icon?
- once you have established raster the ability to communicate bands gray or rgb or actual grid coverage
jody
On 06/11/2009, at 4:42 AM, Rolando Peñate wrote:
On Nov 5, 2009, at 11:28 AM, Andrea Aime wrote:
Rolando Peñate ha scritto:
<snip />
when
to
has
been crossed out.
at a polygon
icon.
—R
Geoserver-devel mailing list
Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
