I’ve read with interest the GeoStyler code sprint progress report here:
https://geostyler.org/codesprint-2022/
Among the other things, this caught my attention from the P.O.V. of module management:
“the extension will now be served under the dedicated repository geostyler-geoserver-plugin.”
The community module contents have not been updated since Feb 27th 2021 (other commits are repo wide changes), from the message above it seems to have been abandoned.
Should it be removed, and the documentation updated so that it just links to the new repository?
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Hi Andrea,
with moving the GeoStyler extension to a dedicated repository, it will be easier for us to keep it up-to-date.
So yes, the source code for the extension can be removed from the geoserver repo and links should be updated. Daniel (@dnlkoch) will provide a PR for this.
Thanks for pointing this out!
Kind regards
Jan
PS: The GeoStyler Code Sprint was a lot of fun and the new layout that was implemented there will be integrated into the GeoStyler extension, as soon as it is production ready.
On 16.06.22 10:48, Andrea Aime wrote:
== GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information. == Ing. Andrea Aime @geowolf Technical Lead
GeoSolutions Group phone: +39 0584 962313
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.comsourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
M.Sc. Geoinformatics Jan Suleiman
- Anwendungsentwickler -
terrestris GmbH & Co. KG
Kölnstraße 99
53111 Bonn
Tel: +49 (0)228 / 96 28 99 -543
Fax: +49 (0)228 / 96 28 99 -57
Email: [suleiman@anonymised.com](mailto:suleiman@anonymised.com808...)
Web: [http://www.terrestris.de](http://www.terrestris.de)
Komplementärin: terrestris Verwaltungsgesellschaft mbH vertreten durch:
Torsten Brassat, Marc Jansen
Informationen über Ihre gespeicherten Daten finden Sie auf
unserer Homepage unter folgendem Link:
[https://www.terrestris.de/datenschutzerklaerung/](https://www.terrestris.de/datenschutzerklaerung/)
