Torben,
the GEOT-5224 ArcGrid change breaks GeoServer master in gs-wcs1_0:
https://osgeo-org.atlassian.net/browse/GEOT-5224
https://github.com/geotools/geotools/pull/970
bencaradocdavies wrote:
"This value is used to populate wcs:supportedFormats/wcs:formats in a WCS 1.0 DescribeCoverage response. These tokens are used bare in a gml:CodeListType and must not contain spaces. The presence of a space in this token causes the GeoServer master build to fail in gs-wcs1_0. One solutions would be to change this to "ArcInfoAsciiGrid" or similar. Does changing this value from ArcGRid change the user-visible API?"
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Hi Ben,
I’ve reverted the change for the moment (using Github gui for reverting a pull)
On Sun, Sep 27, 2015 at 7:02 AM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Torben,
“This value is used to populate wcs:supportedFormats/wcs:formats in a WCS 1.0 DescribeCoverage response. These tokens are used bare in a gml:CodeListType and must not contain spaces. The presence of a space in this token causes the GeoServer master build to fail in gs-wcs1_0. One solutions would be to change this to “ArcInfoAsciiGrid” or similar. Does changing this value from ArcGRid change the user-visible API?”
Kind regards,
Director
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks, Andrea. I can confirm that the GeoServer build on master is now fixed for me. (GeoTools is still having some infrastructure problems.)
Kind regards,
Ben.
On 27/09/15 19:36, Andrea Aime wrote:
Hi Ben,
I've reverted the change for the moment (using Github gui for reverting a
pull)
Director
New Zealand
