[Geoserver-devel] GeoTools build failure cascading to GeoServer
it seems there are git troubles in geotools builds:
Started by an SCM change
Checkout:workspace / /var/lib/hudson/jobs/geotools-master/workspace - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision 532f41b6d39b86e61ccc2e896c1bc62deec63f3e (origin/master)
Fetching changes from the remote Git repository
Fetching upstream changes from git://[github.com/geotools/geotools.git](http://github.com/geotools/geotools.git)
Commencing build of Revision 0b22d590d7f6559151e2356f25f68d9bbe253c00 (origin/master)
Checking out Revision 0b22d590d7f6559151e2356f25f68d9bbe253c00 (origin/master)
FATAL: Error performing command: git checkout -f 0b22d590d7f6559151e2356f25f68d9bbe253c00
Command "git checkout -f 0b22d590d7f6559151e2356f25f68d9bbe253c00" returned status code 128: fatal: Unable to create '/var/lib/hudson/jobs/geotools-master/workspace/.git/index.lock': File exists.
If no other git process is currently running, this probably means a
git process crashed in this repository earlier. Make sure no other git
process is running and remove the file manually to continue.
[hudson.plugins.git.GitException](http://stacktrace.hudson-ci.org/search?query=hudson.plugins.git.GitException): Error performing command: git checkout -f 0b22d590d7f6559151e2356f25f68d9bbe253c00
	at hudson.plugins.git.GitAPI.launchCommandIn(GitAPI.java:730)
	at hudson.plugins.git.GitAPI.launchCommand(GitAPI.java:692)
	at hudson.plugins.git.GitAPI.launchCommand(GitAPI.java:703)
	at hudson.plugins.git.GitAPI.checkoutBranch(GitAPI.java:798)
	at hudson.plugins.git.GitSCM$1.invoke(GitSCM.java:702)
	at hudson.plugins.git.GitSCM$1.invoke(GitSCM.java:687)
	at hudson.FilePath.act(FilePath.java:758)
	at hudson.FilePath.act(FilePath.java:740)
	at hudson.plugins.git.GitSCM.getBuildConfig(GitSCM.java:687)
	at hudson.plugins.git.GitSCM.checkout(GitSCM.java:647)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1479)
	at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:507)
	at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:424)
	at hudson.model.Run.run(Run.java:1366)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
	at hudson.model.ResourceController.execute(ResourceController.java:88)
	at hudson.model.Executor.run(Executor.java:145)
Caused by: hudson.plugins.git.GitException: Command "git checkout -f 0b22d590d7f6559151e2356f25f68d9bbe253c00" returned status code 128: fatal: Unable to create '/var/lib/hudson/jobs/geotools-master/workspace/.git/index.lock': File exists.
	at hudson.plugins.git.GitAPI.launchCommandIn(GitAPI.java:723)
	... 16 more
Unfortunately the GS build now also fails because a new test needs a fix back
in GeoTools to pass
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I’m on it. We have been having some serious issues with that server as of late. Our sysadmin had to kill a bunch of processes on it and i am guessing one was in the middle of doing an update on the git repo.
On Thu, Aug 29, 2013 at 11:35 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
	... 16 more
in GeoTools to pass
Ing. Andrea Aime
@geowolf
Technical Lead
Learn the latest–Visual Studio 2012, SharePoint 2013, SQL 2012, more!
Discover the easy way to master current and previous Microsoft technologies
and advance your career. Get an incredible 1,500+ hours of step-by-step
tutorial videos with LearnDevNow. Subscribe today and save!
http://pubads.g.doubleclick.net/gampad/clk?id=58040911&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
