GeoTools2 module build report 20040806
gt2:main cleaned, compiled, tested, INSTALLED 0913
gt2:utils cleaned, compiled, tested, INSTALLED 0913
gt2:rendering-styling cleaned, compiled, tested, INSTALLED 0914
gt2:pickle cleaned, compiled, tested, INSTALLED 0914
gt2:sample-data cleaned, compiled, tested, INSTALLED 0914
gt2:mapinfo cleaned, compiled, tested, INSTALLED 0914
gt2:svgsupport cleaned, compiled, tested, INSTALLED 0914
gt2:dir_ds cleaned
gt2:arcsde cleaned, compiled, tested, INSTALLED 0914
gt2:image cleaned, compiled, tested, INSTALLED 0915
gt2:mysql cleaned, compiled, tested, INSTALLED 0915
gt2:wms cleaned, compiled, tested, INSTALLED 0915
gt2:postgis cleaned, compiled, tested, INSTALLED 0915
gt2:geomedia cleaned, compiled, tested, INSTALLED 0915
gt2:tiger cleaned
gt2:vpf cleaned, compiled
gt2:gtopo30 cleaned, compiled, tested, INSTALLED 0916
gt2:arcgrid cleaned, compiled, tested, INSTALLED 0916
gt2:graph cleaned, compiled, tested, INSTALLED 0917
gt2:reprojection cleaned, compiled, tested, INSTALLED 0917
gt2:view cleaned, compiled, tested, INSTALLED 0917
__ __
| \/ |__ _Apache__ ___
| |\/| / _` \ V / -_) ' \ ~ intelligent projects ~
|_| |_\__,_|\_/\___|_||_| v. 1.0
build:start:
build:
[echo] looking for modules in: /home/autorun/cvs/geotools/gt/module, /home/autorun/cvs/geotools/gt/plugin, /home/autorun/cvs/geotools/gt/ext
reporting progress to /home/autorun/cvs/geotools/gt
[delete] Deleting directory /home/autorun/cvs/geotools/gt/target/test-reports
Starting the reactor...
Our processing order:
geotools-main
geotools-utils
geotools-renderer-sldstyling
geotools-pickle
geotools-sample-data
geotools-mapinfo
geotools-svgsupport
| Building Module geotools-main
| Memory: 3M/5M
Attempting to download geoapi-SNAPSHOT.jar.
Plugin 'maven-deploy-plugin' in project 'geotools-main' is not available
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/module/main/target
clean:
java:prepare-filesystem:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/main/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/module/main/target/classes
[javac] Compiling 1033 source files to /home/autorun/cvs/geotools/gt/module/main/target/classes
Note: Some input files use or override a deprecated API.
Note: Recompile with -deprecation for details.
[rmic] RMI Compiling 28 classes to /home/autorun/cvs/geotools/gt/module/main/target/classes
java:jar-resources:
Copying 41 files to /home/autorun/cvs/geotools/gt/module/main/target/classes
test:prepare-filesystem:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/main/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/main/target/test-reports
test:test-resources:
Copying 112 files to /home/autorun/cvs/geotools/gt/module/main/target/test-classes
Copied 1 empty directory to /home/autorun/cvs/geotools/gt/module/main/target/test-classes
test:compile:
[javac] Compiling 147 source files to /home/autorun/cvs/geotools/gt/module/main/target/test-classes
test:test:
[junit] Running org.geotools.gml.ServiceTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.782 sec
[junit] Running org.geotools.gml.GmlTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.379 sec
[junit] Running org.geotools.gml.ProducerTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 1.566 sec
[junit] Running org.geotools.metadata.iso19115.MetaDataTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.846 sec
[junit] Running org.geotools.metadata.iso19115.ContactTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.762 sec
[junit] Running org.geotools.gui.tools.ToolListImplTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.738 sec
[junit] Running org.geotools.gui.swing.tables.FeatureTableModelTest
[junit] Warning: Cannot convert string "-b&h-lucida-medium-r-normal-sans-*-140-*-*-p-*-iso8859-1" to type FontStruct
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 6.624 sec
[junit] Running org.geotools.gui.swing.MiscellaneousWidgetTest
[junit] Tests run: 10, Failures: 0, Errors: 0, Time elapsed: 11.543 sec
[junit] Running org.geotools.gui.swing.ProgressWindowTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 4.516 sec
[junit] Running org.geotools.filter.SQLEncoderTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.905 sec
[junit] Running org.geotools.filter.FilterEqualsTest
[junit] Tests run: 10, Failures: 0, Errors: 0, Time elapsed: 1.101 sec
[junit] Running org.geotools.filter.ExpressionTest
[junit] Tests run: 10, Failures: 0, Errors: 0, Time elapsed: 0.871 sec
[junit] Running org.geotools.filter.FilterVisitorTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.856 sec
[junit] Running org.geotools.filter.XMLEncoderTest
[junit] Tests run: 14, Failures: 0, Errors: 0, Time elapsed: 1.534 sec
[junit] Running org.geotools.filter.AttributeTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.828 sec
[junit] Running org.geotools.filter.FilterAttributeExtractorTest
[junit] Tests run: 8, Failures: 0, Errors: 0, Time elapsed: 0.966 sec
[junit] Running org.geotools.filter.AreaFunctionTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.904 sec
[junit] Running org.geotools.filter.FilterTest
[junit] Tests run: 9, Failures: 0, Errors: 0, Time elapsed: 1.295 sec
[junit] Running org.geotools.filter.SQLUnpackerTest
[junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 1.117 sec
[junit] Running org.geotools.filter.CapabilitiesTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.76 sec
[junit] Running org.geotools.filter.MathTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.902 sec
[junit] Running org.geotools.filter.BetweenTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.867 sec
[junit] Running org.geotools.filter.DOMParserTest
[junit] Tests run: 15, Failures: 0, Errors: 0, Time elapsed: 1.59 sec
[junit] Running org.geotools.filter.LiteralTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.822 sec
[junit] Running org.geotools.filter.ParserTest
[junit] Tests run: 19, Failures: 0, Errors: 0, Time elapsed: 1.753 sec
[junit] Running org.geotools.referencing.operation.transform.LocalizationGridTest
[junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 0.83 sec
[junit] Running org.geotools.referencing.operation.transform.MathTransformTest
[junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 10.682 sec
[junit] Running org.geotools.referencing.operation.ScriptTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.642 sec
[junit] Running org.geotools.referencing.operation.MatrixTest
[junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 0.778 sec
[junit] Running org.geotools.referencing.ParameterTest
[junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 1.338 sec
[junit] Running org.geotools.referencing.BasicTest
[junit] Tests run: 9, Failures: 0, Errors: 0, Time elapsed: 1.507 sec
[junit] Running org.geotools.gc.SampleTranscoderTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 3.584 sec
[junit] Running org.geotools.gc.GridCoverageTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 4.424 sec
[junit] Running org.geotools.gc.GridGeometryTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.91 sec
[junit] Running org.geotools.math.GeometryTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.841 sec
[junit] Running org.geotools.styling.XMLEncoderTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 1.535 sec
[junit] Running org.geotools.styling.SLDStyleTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 1.063 sec
[junit] Running org.geotools.styling.StyleAttributeExtractorTest
[junit] Tests run: 12, Failures: 0, Errors: 0, Time elapsed: 1.135 sec
[junit] Running org.geotools.styling.StyleObjectTest
[junit] Tests run: 18, Failures: 0, Errors: 0, Time elapsed: 0.896 sec
[junit] Running org.geotools.styling.TextSymbolTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 1 sec
[junit] Running org.geotools.styling.StyleFactoryImplTest
[junit] Tests run: 16, Failures: 0, Errors: 0, Time elapsed: 0.818 sec
[junit] Running org.geotools.feature.FlatFeatureFactorySpiTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.804 sec
[junit] Running org.geotools.feature.FeatureFlatTest
[junit] Tests run: 11, Failures: 0, Errors: 0, Time elapsed: 1.111 sec
[junit] Running org.geotools.feature.AttributeTypeTest
[junit] Tests run: 15, Failures: 0, Errors: 0, Time elapsed: 0.916 sec
[junit] Running org.geotools.feature.FeatureTypeFactoryTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.964 sec
[junit] Running org.geotools.feature.FeatureCollectionTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.99 sec
[junit] Running org.geotools.feature.FeatureTypeTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.988 sec
[junit] Running org.geotools.xml.DOMXPathTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 1.005 sec
[junit] Running org.geotools.xml.XPathFactoryTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.985 sec
[junit] Running org.geotools.measure.FormatTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.196 sec
[junit] Running org.geotools.units.UnitTest
[junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 1.019 sec
[junit] Running org.geotools.cs.WKTParserTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 2.156 sec
[junit] Running org.geotools.cs.CreationTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 1.409 sec
[junit] Running org.geotools.cs.GeodeticCalculatorTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 1.189 sec
[junit] Running org.geotools.gp.InterpolatorTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 10.058 sec
[junit] Running org.geotools.gp.OperationTest
[junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 4.548 sec
[junit] Running org.geotools.gp.ResampleTest
[junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 9.258 sec
[junit] Running org.geotools.ct.PassthroughTransformTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 1.271 sec
[junit] Running org.geotools.ct.ScriptTest
[junit] Tests run: 11, Failures: 0, Errors: 0, Time elapsed: 3.121 sec
[junit] Running org.geotools.ct.TransformationTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.219 sec
[junit] Running org.geotools.ct.ProjectionTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.017 sec
[junit] Running org.geotools.ct.GeocentricTransformTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 1.651 sec
[junit] Running org.geotools.renderer.j2d.RendererTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 6.606 sec
[junit] Running org.geotools.renderer.geom.GeometryTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 1.93 sec
[junit] Running org.geotools.renderer.geom.PolygonTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 3.534 sec
[junit] Running org.geotools.renderer.lite.Rendering2DTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 7.878 sec
[junit] Running org.geotools.renderer.lite.LiteShapeTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.187 sec
[junit] Running org.geotools.renderer.array.PointArrayTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 4.454 sec
[junit] Running org.geotools.io.coverage.PropertyParserTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 4.743 sec
[junit] Running org.geotools.cv.SampleDimensionTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 3.245 sec
[junit] Running org.geotools.cv.AdaptersTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 3.457 sec
[junit] Running org.geotools.cv.ScaledColorSpaceTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.83 sec
[junit] Running org.geotools.cv.CategoryListTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 1.486 sec
[junit] Running org.geotools.cv.CategoryTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.631 sec
[junit] Running org.geotools.data.coverage.grid.test.GridCoverageExchangeFinderTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.732 sec
[junit] Running org.geotools.data.coverage.grid.file.test.FileMetadataImplTest
[junit] Tests run: 10, Failures: 0, Errors: 0, Time elapsed: 1.44 sec
[junit] Running org.geotools.data.coverage.grid.file.test.FSCatalogEntryTest
[junit] Tests run: 8, Failures: 0, Errors: 0, Time elapsed: 0.938 sec
[junit] Running org.geotools.data.coverage.grid.stream.test.IOExchangeTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.909 sec
[junit] Running org.geotools.data.FeatureLockTest
[junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 0.795 sec
[junit] Running org.geotools.data.DataUtilitiesTest
[junit] Tests run: 20, Failures: 0, Errors: 0, Time elapsed: 1.565 sec
[junit] Running org.geotools.data.collection.CollectionDataStoreTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 1.249 sec
[junit] Running org.geotools.data.jdbc.JDBCDataStoreTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 1.603 sec
[junit] Running org.geotools.data.DefaultQueryTest
[junit] Tests run: 9, Failures: 0, Errors: 0, Time elapsed: 0.716 sec
[junit] Running org.geotools.data.FilteringFeatureReaderTest
[junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 2.421 sec
[junit] Running org.geotools.data.AbstractDataSourceTest
[junit] Tests run: 14, Failures: 0, Errors: 0, Time elapsed: 1.512 sec
[junit] Running org.geotools.data.DataSourceFinderTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 1.394 sec
[junit] Running org.geotools.data.memory.MemoryDataStoreTest
[junit] Tests run: 32, Failures: 0, Errors: 0, Time elapsed: 3.322 sec
[junit] Running org.geotools.data.MemoryDataSourceTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 1.794 sec
[junit] Running org.geotools.data.DatasourceTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 1.534 sec
[junit] Running org.geotools.data.MemoryLockingDataSourceTest
[junit] Tests run: 39, Failures: 0, Errors: 0, Time elapsed: 2.04 sec
[junit] Running org.geotools.algorithms.classification.EqualClassesTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.114 sec
[junit] Running org.geotools.algorithms.RobustGeometryPropertiesTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 1.786 sec
[junit] Running org.geotools.resources.NumberParserTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 1.351 sec
[junit] Running org.geotools.catalog.QueryTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 1.767 sec
[junit] Running org.geotools.catalog.MetadataXPathTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 1.484 sec
[junit] Running org.geotools.util.DisjointSetTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.857 sec
[junit] Running org.geotools.util.WeakHashSetTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 5.483 sec
[junit] Running org.geotools.util.MonolineFormatterTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 2.118 sec
[junit] Running org.geotools.util.WeakValueHashMapTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 2.27 sec
[junit] Running org.geotools.util.RangeSetTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.733 sec
[junit] Running org.geotools.map.MapContextTest
[junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 1.455 sec
[junit] Running org.geotools.map.MapLayerTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 1.147 sec
[junit] Running org.geotools.expr.LiteralExprTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.756 sec
[junit] Running org.geotools.expr.ArithmaticMathExprTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.674 sec
[echo] merging test reports into higher directory
[copy] Copying 104 files to /home/autorun/cvs/geotools/gt/target/test-reports
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/module/main/target/main-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/module/main/target/main-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/main-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/module/main/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/main-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Module geotools-utils
| Memory: 34M/66M
Plugin 'maven-deploy-plugin' in project 'geotools-utils' is not available
build:end:
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/module/utils/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/utils/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/module/utils/target/classes
[javac] Compiling 1 source file to /home/autorun/cvs/geotools/gt/module/utils/target/classes
java:jar-resources:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/utils/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/utils/target/test-reports
test:compile:
[echo] No test source files to compile.
test:test:
[echo] No tests to run.
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/module/utils/target/utils-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/module/utils/target/utils-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/utils-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/module/utils/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/utils-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Module geotools-renderer-sldstyling
| Memory: 39M/66M
Artifact /geoapi/jars/geoapi-SNAPSHOT.jar doesn't exists in remote repository, but it exists locally
Plugin 'maven-deploy-plugin' in project 'geotools-renderer-sldstyling' is not available
build:end:
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/module/rendering-styling/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/rendering-styling/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/module/rendering-styling/target/classes
[echo] No java source files to compile.
java:jar-resources:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/rendering-styling/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/rendering-styling/target/test-reports
Copying 24 files to /home/autorun/cvs/geotools/gt/module/rendering-styling/target/test-classes
test:compile:
[javac] Compiling 4 source files to /home/autorun/cvs/geotools/gt/module/rendering-styling/target/test-classes
Note: /home/autorun/cvs/geotools/gt/module/rendering-styling/test/org/geotools/styling/RenderingGridCoverageTest.java uses or overrides a deprecated API.
test:test:
[junit] Running org.geotools.styling.DefaultMarkTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 10.54 sec
[junit] Running org.geotools.styling.RenderStyleTest
Aug 6, 2004 9:14:05 AM org.geotools.styling.RenderStyleTest performTestOnRenderer
INFO: Comparing pixels between:
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_builder400x350.png
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_400x350.png
Aug 6, 2004 9:14:06 AM org.geotools.styling.RenderStyleTest performTestOnRenderer
INFO: Total pixel differences 112
Aug 6, 2004 9:14:08 AM org.geotools.styling.RenderStyleTest performTestOnRenderer
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_builder400x350.png
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_400x350.png
Aug 6, 2004 9:14:09 AM org.geotools.styling.RenderStyleTest performTestOnRenderer
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_xml400x250.png
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_400x250.png
INFO: Total pixel differences 80
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_xml400x450.png
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_400x450.png
Aug 6, 2004 9:14:10 AM org.geotools.styling.RenderStyleTest performTestOnRenderer
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_xml200x350.png
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_200x350.png
INFO: Total pixel differences 96
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_xml400x350.png
Aug 6, 2004 9:14:11 AM org.geotools.styling.RenderStyleTest performTestOnRenderer
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_xml600x350.png
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_600x350.png
INFO: Total pixel differences 103
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_xml400x250.png
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_400x250.png
INFO: Total pixel differences 113
Aug 6, 2004 9:14:12 AM org.geotools.styling.RenderStyleTest performTestOnRenderer
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_xml400x350.png
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_xml200x350.png
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_200x350.png
INFO: Total pixel differences 119
Aug 6, 2004 9:14:13 AM org.geotools.styling.RenderStyleTest performTestOnRenderer
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_xml600x350.png
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_600x350.png
[junit] Tests run: 12, Failures: 0, Errors: 0, Time elapsed: 10.509 sec
[junit] Running org.geotools.styling.RenderingGridCoverageTest
Aug 6, 2004 9:14:17 AM org.geotools.gp.GridCoverageProcessor getDefault
WARNING: No such "org.geotools.Hysteresis" operation for this processor.
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 4.892 sec
[junit] Running org.geotools.styling.TextStyleTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 4.012 sec
[copy] Copying 4 files to /home/autorun/cvs/geotools/gt/target/test-reports
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/module/rendering-styling/target/rendering-styling-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/module/rendering-styling/target/rendering-styling-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/rendering-styling-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/module/rendering-styling/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/rendering-styling-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Module geotools-pickle
| Memory: 38M/53M
Plugin 'maven-deploy-plugin' in project 'geotools-pickle' is not available
build:end:
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/module/pickle/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/pickle/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/module/pickle/target/classes
[javac] Compiling 4 source files to /home/autorun/cvs/geotools/gt/module/pickle/target/classes
Note: /home/autorun/cvs/geotools/gt/module/pickle/src/org/geotools/data/pickle/GeometryPickler.java uses or overrides a deprecated API.
java:jar-resources:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/pickle/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/pickle/target/test-reports
Copying 1 file to /home/autorun/cvs/geotools/gt/module/pickle/target/test-classes
test:compile:
[javac] Compiling 1 source file to /home/autorun/cvs/geotools/gt/module/pickle/target/test-classes
test:test:
[junit] Running org.geotools.data.pickle.PickleTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 2.229 sec
[copy] Copying 1 file to /home/autorun/cvs/geotools/gt/target/test-reports
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/module/pickle/target/pickle-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/module/pickle/target/pickle-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/pickle-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/module/pickle/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/pickle-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Module geotools-sample-data
| Memory: 45M/53M
Plugin 'maven-deploy-plugin' in project 'geotools-sample-data' is not available
build:end:
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/module/sample-data/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/sample-data/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/module/sample-data/target/classes
java:jar-resources:
Copying 18 files to /home/autorun/cvs/geotools/gt/module/sample-data/target/classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/sample-data/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/sample-data/target/test-reports
test:compile:
test:test:
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/module/sample-data/target/sample-data-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/module/sample-data/target/sample-data-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/sample-data-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/module/sample-data/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/sample-data-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Module geotools-mapinfo
| Memory: 45M/53M
Plugin 'maven-deploy-plugin' in project 'geotools-mapinfo' is not available
build:end:
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/module/mapinfo/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/mapinfo/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/module/mapinfo/target/classes
[javac] Compiling 3 source files to /home/autorun/cvs/geotools/gt/module/mapinfo/target/classes
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/module/mapinfo/target/classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/mapinfo/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/mapinfo/target/test-reports
Copying 8 files to /home/autorun/cvs/geotools/gt/module/mapinfo/target/test-classes
test:compile:
[javac] Compiling 6 source files to /home/autorun/cvs/geotools/gt/module/mapinfo/target/test-classes
test:test:
[junit] Running org.geotools.data.mapinfo.LoadTest
Aug 6, 2004 9:14:34 AM org.geotools.data.mapinfo.MapInfoDataSource readMifHeader
INFO: version [300]
INFO: delimiter [,]
Read 49 features
Aug 6, 2004 9:14:35 AM org.geotools.data.mapinfo.MapInfoDataSource readMifHeader
INFO: version [300]
INFO: Charset [Neutral]
INFO: delimiter [,]
Read 4 features
INFO: version [300]
INFO: delimiter [,]
Read 4 features
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.858 sec
[junit] Running org.geotools.data.mapinfo.MapInfoDataSourceTest
Testing ability to load file:/home/autorun/cvs/geotools/gt/module/mapinfo/target/test-classes/org/geotools/data/mapinfo/test-data/statepop.mif
Aug 6, 2004 9:14:36 AM org.geotools.data.mapinfo.MapInfoDataSource readMifHeader
INFO: version [300]
INFO: delimiter [,]
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.925 sec
[copy] Copying 2 files to /home/autorun/cvs/geotools/gt/target/test-reports
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/module/mapinfo/target/mapinfo-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/module/mapinfo/target/mapinfo-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/mapinfo-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/module/mapinfo/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/mapinfo-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Module geotools-svgsupport
| Memory: 20M/53M
Plugin 'maven-deploy-plugin' in project 'geotools-svgsupport' is not available
build:end:
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/module/svgsupport/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/svgsupport/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/module/svgsupport/target/classes
[javac] Compiling 1 source file to /home/autorun/cvs/geotools/gt/module/svgsupport/target/classes
java:jar-resources:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/svgsupport/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/svgsupport/target/test-reports
Copying 8 files to /home/autorun/cvs/geotools/gt/module/svgsupport/target/test-classes
test:compile:
[javac] Compiling 1 source file to /home/autorun/cvs/geotools/gt/module/svgsupport/target/test-classes
Note: /home/autorun/cvs/geotools/gt/module/svgsupport/test/org/geotools/svg/SVGTest.java uses or overrides a deprecated API.
test:test:
[junit] Running org.geotools.svg.SVGTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 2.956 sec
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/module/svgsupport/target/svgsupport-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/module/svgsupport/target/svgsupport-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/svgsupport-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/module/svgsupport/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/svgsupport-2.1.x.pom'
jar:install:
mergeTestReports:
geotools-dir
geotools-gml
geotools-shapefile
geotools-arcsde
geotools-image
geotools-oraclespatial
geotools-mysql
geotools-wms
geotools-postgis
geotools-geomedia
geotools-tiger
geotools-vpf
geotools-gtopo30
geotools-arcgrid
| Building Plugin geotools-dir
| Memory: 29M/53M
Plugin 'maven-deploy-plugin' in project 'geotools-dir' is not available
build:end:
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/directory/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/directory/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/directory/target/classes
[javac] Compiling 5 source files to /home/autorun/cvs/geotools/gt/plugin/directory/target/classes
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/AbstractFileDataStore.java:40: cannot access org.opengis.catalog.Catalog
file org/opengis/catalog/Catalog.class not found
public abstract class AbstractFileDataStore extends AbstractDataStore {
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/AbstractFileDataStore.java:64: updateSchema(org.geotools.feature.FeatureType) in org.geotools.data.dir.AbstractFileDataStore cannot be applied to (java.lang.String,org.geotools.feature.FeatureType)
updateSchema(getSchema().getTypeName(), featureType);
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/AbstractFileDataStore.java:73: getFeatureSource() in org.geotools.data.dir.AbstractFileDataStore cannot be applied to (java.lang.String)
return getFeatureSource(getSchema().getTypeName());
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/AbstractFileDataStore.java:84: cannot resolve symbol
symbol : method getFeatureWriter (java.lang.String,org.geotools.filter.Filter,org.geotools.data.Transaction)
location: class org.geotools.data.dir.AbstractFileDataStore
return getFeatureWriter(getSchema().getTypeName(), filter, transaction);
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/AbstractFileDataStore.java:93: cannot resolve symbol
symbol : method getFeatureWriter (java.lang.String,org.geotools.data.Transaction)
return getFeatureWriter(getSchema().getTypeName(), transaction);
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/AbstractFileDataStore.java:102: getFeatureWriterAppend(org.geotools.data.Transaction) in org.geotools.data.dir.AbstractFileDataStore cannot be applied to (java.lang.String,org.geotools.data.Transaction)
return getFeatureWriterAppend(getSchema().getTypeName(), transaction);
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:86: operator != cannot be applied to org.geotools.data.dir.AbstractFileDataStore,<nulltype>
if (afds != null) {
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:87: cannot resolve symbol
symbol : method getTypeNames ()
dataStores.put(afds.getTypeNames()[0], afds);
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:101: inconvertible types
found : java.lang.Object
required: org.geotools.data.dir.AbstractFileDataStore
AbstractFileDataStore afds = (AbstractFileDataStore) i.next();
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:102: cannot resolve symbol
String strs = afds.getTypeNames();
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:117: inconvertible types
AbstractFileDataStore afds = (AbstractFileDataStore) dataStores.get(typeName);
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:119: operator != cannot be applied to org.geotools.data.dir.AbstractFileDataStore,<nulltype>
if (afds != null) {
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:140: operator != cannot be applied to org.geotools.data.dir.AbstractFileDataStore,<nulltype>
if (afds != null) {
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:141: cannot resolve symbol
symbol : method createSchema (org.geotools.feature.FeatureType)
afds.createSchema(featureType);
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:142: put(java.lang.Object,java.lang.Object) in java.util.Map cannot be applied to (java.lang.String,org.geotools.data.dir.AbstractFileDataStore)
dataStores.put(featureType.getTypeName(), afds);
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:157: inconvertible types
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:159: operator != cannot be applied to org.geotools.data.dir.AbstractFileDataStore,<nulltype>
if (afds != null) {
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:169: inconvertible types
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:171: operator != cannot be applied to org.geotools.data.dir.AbstractFileDataStore,<nulltype>
if (afds != null) {
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:184: inconvertible types
AbstractFileDataStore afds = (AbstractFileDataStore) dataStores.get(query
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:187: operator != cannot be applied to org.geotools.data.dir.AbstractFileDataStore,<nulltype>
if (afds != null) {
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:188: getFeatureReader() in org.geotools.data.dir.AbstractFileDataStore cannot be applied to (org.geotools.data.Query,org.geotools.data.Transaction)
return afds.getFeatureReader(query, transaction);
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:200: inconvertible types
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:202: operator != cannot be applied to org.geotools.data.dir.AbstractFileDataStore,<nulltype>
if (afds != null) {
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:215: inconvertible types
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:217: operator != cannot be applied to org.geotools.data.dir.AbstractFileDataStore,<nulltype>
if (afds != null) {
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:230: inconvertible types
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:232: operator != cannot be applied to org.geotools.data.dir.AbstractFileDataStore,<nulltype>
if (afds != null) {
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:253: inconvertible types
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:255: cannot resolve symbol
symbol : method getLockingManager ()
if ((afds.getLockingManager() != null)
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:256: cannot resolve symbol
&& afds.getLockingManager().exists(authID)) {
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:273: inconvertible types
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:275: cannot resolve symbol
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:276: cannot resolve symbol
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:277: cannot resolve symbol
return afds.getLockingManager().release(authID, transaction);
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:293: inconvertible types
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:295: cannot resolve symbol
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:296: cannot resolve symbol
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:297: cannot resolve symbol
return afds.getLockingManager().refresh(authID, transaction);
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:312: inconvertible types
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:314: operator != cannot be applied to org.geotools.data.dir.AbstractFileDataStore,<nulltype>
if ((afds != null) && (afds.getLockingManager() != null)) {
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:314: cannot resolve symbol
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:315: cannot resolve symbol
afds.getLockingManager().unLockFeatureID(typeName, authID,
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:328: inconvertible types
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:330: operator != cannot be applied to org.geotools.data.dir.AbstractFileDataStore,<nulltype>
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:330: cannot resolve symbol
/home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStore.java:331: cannot resolve symbol
afds.getLockingManager().lockFeatureID(typeName, authID,
Note: /home/autorun/cvs/geotools/gt/plugin/directory/src/org/geotools/data/dir/DirectoryDataStoreFactory.java uses or overrides a deprecated API.
47 errors
| Building Plugin geotools-gml
| Memory: 31M/53M
Attempting to download dir_ds-2.1.x.jar.
WARNING: Failed to download dir_ds-2.1.x.jar.
| Building Plugin geotools-shapefile
| Memory: 32M/53M
| Building Plugin geotools-arcsde
| Memory: 29M/53M
Plugin 'maven-deploy-plugin' in project 'geotools-arcsde' is not available
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/arcsde/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/arcsde/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/arcsde/target/classes
[javac] Compiling 16 source files to /home/autorun/cvs/geotools/gt/plugin/arcsde/target/classes
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/plugin/arcsde/target/classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/arcsde/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/arcsde/target/test-reports
Copying 11 files to /home/autorun/cvs/geotools/gt/plugin/arcsde/target/test-classes
test:compile:
[javac] Compiling 6 source files to /home/autorun/cvs/geotools/gt/plugin/arcsde/target/test-classes
Note: /home/autorun/cvs/geotools/gt/plugin/arcsde/test/org/geotools/data/arcsde/GeometryBuilderTest.java uses or overrides a deprecated API.
test:test:
[junit] Running org.geotools.data.arcsde.GeometryBuilderTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 1.392 sec
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/plugin/arcsde/target/arcsde-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/plugin/arcsde/target/arcsde-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/arcsde-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/plugin/arcsde/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/arcsde-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Plugin geotools-image
| Memory: 42M/53M
Plugin 'maven-deploy-plugin' in project 'geotools-image' is not available
build:end:
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/image/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/image/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/image/target/classes
[javac] Compiling 6 source files to /home/autorun/cvs/geotools/gt/plugin/image/target/classes
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/plugin/image/target/classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/image/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/image/target/test-reports
Copying 2 files to /home/autorun/cvs/geotools/gt/plugin/image/target/test-classes
test:compile:
[javac] Compiling 4 source files to /home/autorun/cvs/geotools/gt/plugin/image/target/test-classes
test:test:
[junit] Running org.geotools.coverage.WorldImageFormatTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.789 sec
[junit] Running org.geotools.coverage.WorldImageWriterTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.803 sec
[junit] Running org.geotools.coverage.WorldImageReaderTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 5.408 sec
[copy] Copying 3 files to /home/autorun/cvs/geotools/gt/target/test-reports
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/plugin/image/target/image-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/plugin/image/target/image-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/image-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/plugin/image/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/image-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Plugin geotools-oraclespatial
| Memory: 50M/53M
Attempting to download shapefile-2.1.x.jar.
WARNING: Failed to download shapefile-2.1.x.jar.
| Building Plugin geotools-mysql
| Memory: 51M/53M
Plugin 'maven-deploy-plugin' in project 'geotools-mysql' is not available
build:end:
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/mysql/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/mysql/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/mysql/target/classes
[javac] Compiling 9 source files to /home/autorun/cvs/geotools/gt/plugin/mysql/target/classes
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/plugin/mysql/target/classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/mysql/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/mysql/target/test-reports
Copying 2 files to /home/autorun/cvs/geotools/gt/plugin/mysql/target/test-classes
test:compile:
[javac] Compiling 7 source files to /home/autorun/cvs/geotools/gt/plugin/mysql/target/test-classes
test:test:
[junit] Running org.geotools.filter.SQLEncoderMySQLTest
exporting GeometryFilter
[junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 0.213 sec
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/plugin/mysql/target/mysql-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/plugin/mysql/target/mysql-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/mysql-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/plugin/mysql/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/mysql-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Plugin geotools-wms
| Memory: 33M/53M
Plugin 'maven-deploy-plugin' in project 'geotools-wms' is not available
build:end:
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/wms/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/wms/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/wms/target/classes
[javac] Compiling 52 source files to /home/autorun/cvs/geotools/gt/plugin/wms/target/classes
Note: /home/autorun/cvs/geotools/gt/plugin/wms/src/org/geotools/data/wms/gce/WMSReader.java uses or overrides a deprecated API.
java:jar-resources:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/wms/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/wms/target/test-reports
test:compile:
[javac] Compiling 2 source files to /home/autorun/cvs/geotools/gt/plugin/wms/target/test-classes
test:test:
[junit] Running org.geotools.data.wms.test.WebMapServerTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 2.863 sec
[junit] Running org.geotools.data.wms.gce.test.WMSReaderTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 5.145 sec
jar:jar:
[echo] Warning: shortDescription is greater than 49 characters - trimming for specification title.
[jar] Building jar: /home/autorun/cvs/geotools/gt/plugin/wms/target/wms-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/plugin/wms/target/wms-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/wms-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/plugin/wms/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/wms-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Plugin geotools-postgis
| Memory: 42M/53M
Plugin 'maven-deploy-plugin' in project 'geotools-postgis' is not available
build:end:
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/postgis/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/postgis/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/postgis/target/classes
[javac] Compiling 13 source files to /home/autorun/cvs/geotools/gt/plugin/postgis/target/classes
Note: /home/autorun/cvs/geotools/gt/plugin/postgis/src/org/geotools/data/postgis/PostgisDataStoreFactory.java uses or overrides a deprecated API.
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/plugin/postgis/target/classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/postgis/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/postgis/target/test-reports
Copying 1 file to /home/autorun/cvs/geotools/gt/plugin/postgis/target/test-classes
test:compile:
[javac] Compiling 5 source files to /home/autorun/cvs/geotools/gt/plugin/postgis/target/test-classes
test:test:
[junit] Running org.geotools.filter.SQLEncoderPostgisTest
[junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 0.935 sec
[junit] Running org.geotools.data.postgis.PostgisDataStoreFactoryTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.225 sec
[junit] Running org.geotools.data.postgis.WKBEncoderTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.772 sec
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/plugin/postgis/target/postgis-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/plugin/postgis/target/postgis-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/postgis-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/plugin/postgis/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/postgis-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Plugin geotools-geomedia
| Memory: 24M/53M
Plugin 'maven-deploy-plugin' in project 'geotools-geomedia' is not available
build:end:
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/geomedia/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/geomedia/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/geomedia/target/classes
[javac] Compiling 9 source files to /home/autorun/cvs/geotools/gt/plugin/geomedia/target/classes
Note: /home/autorun/cvs/geotools/gt/plugin/geomedia/src/org/geotools/data/geomedia/GeoMediaDataStoreFactory.java uses or overrides a deprecated API.
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/plugin/geomedia/target/classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/geomedia/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/geomedia/target/test-reports
test:compile:
test:test:
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/plugin/geomedia/target/geomedia-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/plugin/geomedia/target/geomedia-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/geomedia-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/plugin/geomedia/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/geomedia-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Plugin geotools-tiger
| Memory: 28M/53M
Plugin 'maven-deploy-plugin' in project 'geotools-tiger' is not available
build:end:
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/tiger/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/tiger/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/tiger/target/classes
[javac] Compiling 7 source files to /home/autorun/cvs/geotools/gt/plugin/tiger/target/classes
/home/autorun/cvs/geotools/gt/plugin/tiger/src/org/geotools/data/tiger/TigerDataStore.java:51: cannot access org.opengis.catalog.Catalog
public class TigerDataStore extends AbstractDataStore {
/home/autorun/cvs/geotools/gt/plugin/tiger/src/org/geotools/data/tiger/TigerDataStore.java:82: an enclosing instance that contains org.geotools.data.tiger.TigerDataStore.TigerFilenameFilter is required
String list = directory.list(new TigerFilenameFilter());
/home/autorun/cvs/geotools/gt/plugin/tiger/src/org/geotools/data/tiger/TigerDataStoreFactory.java:69: incompatible types
found : org.geotools.data.tiger.TigerDataStore
required: org.geotools.data.DataStore
return new TigerDataStore(file); ^
/home/autorun/cvs/geotools/gt/plugin/tiger/src/org/geotools/data/tiger/TigerDataStoreFactory.java:102: incompatible types
return new TigerDataStore(dirName);
Note: /home/autorun/cvs/geotools/gt/plugin/tiger/src/org/geotools/data/tiger/TigerDataStoreFactory.java uses or overrides a deprecated API.
4 errors
| Building Plugin geotools-vpf
| Memory: 31M/53M
Plugin 'maven-deploy-plugin' in project 'geotools-vpf' is not available
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/vpf/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/vpf/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/vpf/target/classes
[javac] Compiling 54 source files to /home/autorun/cvs/geotools/gt/plugin/vpf/target/classes
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/plugin/vpf/target/classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/vpf/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/vpf/target/test-reports
Copying 4 files to /home/autorun/cvs/geotools/gt/plugin/vpf/target/test-classes
test:compile:
[javac] Compiling 7 source files to /home/autorun/cvs/geotools/gt/plugin/vpf/target/test-classes
test:test:
[junit] Running org.geotools.data.vpf.io.TableColumnDefTest
[junit] Tests run: 10, Failures: 0, Errors: 0, Time elapsed: 0.763 sec
[junit] Running org.geotools.data.vpf.io.TableRowTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.735 sec
[junit] Running org.geotools.data.vpf.io.TableHeaderTest
[junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 0.753 sec
[junit] Running org.geotools.data.vpf.io.TableInputStreamTest
[junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 0.784 sec
[junit] Running org.geotools.data.vpf.io.RowFieldTest
[junit] Tests run: 8, Failures: 0, Errors: 0, Time elapsed: 0.702 sec
[junit] Running org.geotools.data.vpf.io.VPFDateTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.801 sec
[junit] Running org.geotools.data.vpf.util.DataUtilsTest
[junit] Tests run: 7, Failures: 0, Errors: 1, Time elapsed: 0.708 sec
[junit] [ERROR] TEST org.geotools.data.vpf.util.DataUtilsTest FAILED
| Building Plugin geotools-gtopo30
| Memory: 41M/53M
Plugin 'maven-deploy-plugin' in project 'geotools-gtopo30' is not available
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/gtopo30/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/classes
[javac] Compiling 4 source files to /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/classes
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/test-reports
Copying 7 files to /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/test-classes
test:compile:
[javac] Compiling 6 source files to /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/test-classes
Note: /home/autorun/cvs/geotools/gt/plugin/gtopo30/test/org/geotools/data/gtopo30/ServiceTest.java uses or overrides a deprecated API.
test:test:
[junit] Running org.geotools.data.gtopo30.ServiceTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.899 sec
[junit] Running org.geotools.data.gtopo30.GT30DemTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 4.749 sec
[junit] Running org.geotools.data.gtopo30.GT30HeaderTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.72 sec
[junit] Running org.geotools.data.gtopo30.GT30StatTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.711 sec
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/gtopo30-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/plugin/gtopo30/target/gtopo30-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/gtopo30-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/plugin/gtopo30/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/gtopo30-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Plugin geotools-arcgrid
| Memory: 52M/53M
Plugin 'maven-deploy-plugin' in project 'geotools-arcgrid' is not available
build:end:
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/arcgrid/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/arcgrid/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/arcgrid/target/classes
[javac] Compiling 14 source files to /home/autorun/cvs/geotools/gt/plugin/arcgrid/target/classes
java:jar-resources:
Copying 2 files to /home/autorun/cvs/geotools/gt/plugin/arcgrid/target/classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/arcgrid/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/arcgrid/target/test-reports
Copying 2 files to /home/autorun/cvs/geotools/gt/plugin/arcgrid/target/test-classes
test:compile:
[javac] Compiling 6 source files to /home/autorun/cvs/geotools/gt/plugin/arcgrid/target/test-classes
test:test:
[junit] Running org.geotools.data.arcgrid.test.ServiceTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.226 sec
[junit] Running org.geotools.data.arcgrid.test.ArcGridHeaderTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.784 sec
[junit] Running org.geotools.data.arcgrid.test.ArcGridRenderTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 4.3 sec
[junit] Running org.geotools.data.arcgrid.test.ArcGridReaderTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 2.885 sec
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/plugin/arcgrid/target/arcgrid-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/plugin/arcgrid/target/arcgrid-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/arcgrid-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/plugin/arcgrid/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/arcgrid-2.1.x.pom'
jar:install:
mergeTestReports:
geotools-graph
geotools-reprojection
geotools-j2se-demos
geotools-validation
geotools-view
geotools-legend
| Building geotools-graph
| Memory: 34M/53M
Plugin 'maven-deploy-plugin' in project 'geotools-graph' is not available
build:end:
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/ext/graph/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/graph/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/ext/graph/target/classes
[javac] Compiling 95 source files to /home/autorun/cvs/geotools/gt/ext/graph/target/classes
java:jar-resources:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/graph/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/graph/target/test-reports
test:compile:
[javac] Compiling 46 source files to /home/autorun/cvs/geotools/gt/ext/graph/target/test-classes
test:test:
[junit] Running org.geotools.graph.build.basic.BasicGraphBuilderTest
[junit] Tests run: 11, Failures: 0, Errors: 0, Time elapsed: 0.733 sec
[junit] Running org.geotools.graph.build.basic.BasicDirectedGraphBuilderTest
[junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 0.784 sec
[junit] Running org.geotools.graph.build.opt.OptDirectedGraphBuilderTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.734 sec
[junit] Running org.geotools.graph.build.opt.OptGraphBuilderTest
[junit] Tests run: 9, Failures: 0, Errors: 0, Time elapsed: 0.725 sec
[junit] Running org.geotools.graph.io.standard.OptDirectedGraphSerializerTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.956 sec
[junit] Running org.geotools.graph.io.standard.DirectedGraphSerializerTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.995 sec
[junit] Running org.geotools.graph.io.standard.BasicGraphSerializerTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.978 sec
[junit] Running org.geotools.graph.io.standard.OptGraphSerializerTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.929 sec
[junit] Running org.geotools.graph.structure.basic.BasicGraphableTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.71 sec
[junit] Running org.geotools.graph.structure.basic.BasicGraphTest
[junit] Tests run: 11, Failures: 0, Errors: 0, Time elapsed: 0.732 sec
[junit] Running org.geotools.graph.structure.basic.BasicEdgeTest
[junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 0.707 sec
[junit] Running org.geotools.graph.structure.basic.BasicNodeTest
[junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 0.717 sec
[junit] Running org.geotools.graph.structure.basic.BasicDirectedEdgeTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.713 sec
[junit] Running org.geotools.graph.structure.basic.BasicDirectedNodeTest
[junit] Tests run: 20, Failures: 0, Errors: 0, Time elapsed: 0.712 sec
[junit] Running org.geotools.graph.structure.opt.OptEdgeTest
[junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 0.713 sec
[junit] Running org.geotools.graph.structure.opt.OptNodeTest
[junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 0.751 sec
[junit] Running org.geotools.graph.structure.opt.OptDirectedEdgeTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.723 sec
[junit] Running org.geotools.graph.structure.opt.OptDirectedNodeTest
[junit] Tests run: 20, Failures: 0, Errors: 0, Time elapsed: 0.729 sec
[junit] Running org.geotools.graph.linegraph.OptLineGraphGeneratorTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.764 sec
[junit] Running org.geotools.graph.linegraph.LineGraphGeneratorTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.783 sec
[junit] Running org.geotools.graph.linegraph.OptDirectedLineGraphGeneratorTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.772 sec
[junit] Running org.geotools.graph.linegraph.DirectedLineGraphGeneratorTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.766 sec
[junit] Running org.geotools.graph.traverse.standard.DepthFirstTopologicalIteratorTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.756 sec
[junit] Running org.geotools.graph.traverse.standard.DijkstraIteratorTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.812 sec
[junit] Running org.geotools.graph.traverse.standard.DepthFirstIteratorTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.79 sec
[junit] Running org.geotools.graph.traverse.standard.BreadthFirstTopologicalIteratorTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.746 sec
[junit] Running org.geotools.graph.traverse.standard.DirectedDepthFirstIteratorTest
[junit] Tests run: 8, Failures: 0, Errors: 0, Time elapsed: 0.839 sec
[junit] Running org.geotools.graph.traverse.standard.BreadthFirstIteratorTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.781 sec
[junit] Running org.geotools.graph.traverse.standard.NoBifurcationIteratorTest
[junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 0.759 sec
[junit] Running org.geotools.graph.traverse.basic.SimpleGraphWalkerTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.716 sec
[junit] Running org.geotools.graph.path.WalkTest
[junit] Tests run: 8, Failures: 0, Errors: 0, Time elapsed: 0.762 sec
[junit] Running org.geotools.graph.util.GraphPartitionerTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.767 sec
[junit] Running org.geotools.graph.util.GraphFuserTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.837 sec
[junit] Running org.geotools.graph.util.CycleDetectorTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.794 sec
[junit] Running org.geotools.graph.util.DijkstraShortestPathFinderTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.793 sec
[copy] Copying 35 files to /home/autorun/cvs/geotools/gt/target/test-reports
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/ext/graph/target/graph-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/ext/graph/target/graph-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/graph-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/ext/graph/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/graph-2.1.x.pom'
jar:install:
mergeTestReports:
| Building geotools-reprojection
| Memory: 47M/53M
Attempting to download geoapi-SNAPSHOT.jar.
Plugin 'maven-deploy-plugin' in project 'geotools-reprojection' is not available
build:end:
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/ext/reprojection/target
clean:
java:prepare-filesystem:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/reprojection/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/ext/reprojection/target/classes
[javac] Compiling 3 source files to /home/autorun/cvs/geotools/gt/ext/reprojection/target/classes
Note: Some input files use or override a deprecated API.
Note: Recompile with -deprecation for details.
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/ext/reprojection/target/classes
test:prepare-filesystem:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/reprojection/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/reprojection/target/test-reports
test:test-resources:
test:compile:
[javac] Compiling 1 source file to /home/autorun/cvs/geotools/gt/ext/reprojection/target/test-classes
Note: /home/autorun/cvs/geotools/gt/ext/reprojection/test/org/geotools/reprojection/ReprojectionServiceTest.java uses or overrides a deprecated API.
test:test:
[junit] Running org.geotools.reprojection.ReprojectionServiceTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 1.354 sec
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/ext/reprojection/target/reprojection-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/ext/reprojection/target/reprojection-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/reprojection-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/ext/reprojection/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/reprojection-2.1.x.pom'
jar:install:
mergeTestReports:
| Building geotools-j2se-demos
| Memory: 31M/53M
| Building geotools-validation
| Memory: 32M/53M
| Building geotools-view
| Memory: 33M/53M
Plugin 'maven-deploy-plugin' in project 'geotools-view' is not available
build:end:
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/ext/view/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/view/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/ext/view/target/classes
java:jar-resources:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/view/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/view/target/test-reports
test:compile:
test:test:
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/ext/view/target/view-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/ext/view/target/view-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/view-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/ext/view/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/view-2.1.x.pom'
jar:install:
mergeTestReports:
| Building geotools-legend
| Memory: 31M/53M
build:end:
[echo] BUILD REPORT (from buildReport.txt):
Sucessfull modules should read 'cleaned, compiled, tested, INSTALLED HHMM'
GeoTools2 module build report 20040806
gt2:main cleaned, compiled, tested, INSTALLED 0913
gt2:utils cleaned, compiled, tested, INSTALLED 0913
gt2:rendering-styling cleaned, compiled, tested, INSTALLED 0914
gt2:pickle cleaned, compiled, tested, INSTALLED 0914
gt2:sample-data cleaned, compiled, tested, INSTALLED 0914
gt2:mapinfo cleaned, compiled, tested, INSTALLED 0914
gt2:svgsupport cleaned, compiled, tested, INSTALLED 0914
gt2:dir_ds cleaned
gt2:arcsde cleaned, compiled, tested, INSTALLED 0914
gt2:image cleaned, compiled, tested, INSTALLED 0915
gt2:mysql cleaned, compiled, tested, INSTALLED 0915
gt2:wms cleaned, compiled, tested, INSTALLED 0915
gt2:postgis cleaned, compiled, tested, INSTALLED 0915
gt2:geomedia cleaned, compiled, tested, INSTALLED 0915
gt2:tiger cleaned
gt2:vpf cleaned, compiled
gt2:gtopo30 cleaned, compiled, tested, INSTALLED 0916
gt2:arcgrid cleaned, compiled, tested, INSTALLED 0916
gt2:graph cleaned, compiled, tested, INSTALLED 0917
gt2:reprojection cleaned, compiled, tested, INSTALLED 0917
gt2:view cleaned, compiled, tested, INSTALLED 0917
If some modules failed to INSTALL, look for problems from the TOP DOWN as
failures lower in the list will probaly be caused by ones higher up.
If modules cleanded and compiled but were not tested look in the
/target/test-reports direcotry of your module for details.
You can debug problems from the module directory using 'maven java:compile',
'maven test' and 'maven jar:install'.
These build results are available in buildResults.txt
Maven always says 'Build Sucessful', please check the above report.
BUILD SUCCESSFUL
Total time: 11 minutes 12 seconds
Finished at: Fri Aug 06 09:17:45 PDT 2004
