GeoTools2 module build report 20040807
gt2:main cleaned, compiled
gt2:sample-data cleaned, compiled, tested, INSTALLED 2351
__ __
| \/ |__ _Apache__ ___
| |\/| / _` \ V / -_) ' \ ~ intelligent projects ~
|_| |_\__,_|\_/\___|_||_| v. 1.0
build:start:
build:
[echo] looking for modules in: /home/autorun/cvs/geotools/gt/module, /home/autorun/cvs/geotools/gt/plugin, /home/autorun/cvs/geotools/gt/ext
reporting progress to /home/autorun/cvs/geotools/gt
[delete] Deleting directory /home/autorun/cvs/geotools/gt/target/test-reports
Starting the reactor...
Our processing order:
geotools-main
geotools-utils
geotools-renderer-sldstyling
geotools-pickle
geotools-sample-data
geotools-mapinfo
geotools-svgsupport
| Building Module geotools-main
| Memory: 3M/5M
Attempting to download geoapi-SNAPSHOT.jar.
Plugin 'maven-deploy-plugin' in project 'geotools-main' is not available
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/module/main/target
clean:
java:prepare-filesystem:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/main/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/module/main/target/classes
[javac] Compiling 1037 source files to /home/autorun/cvs/geotools/gt/module/main/target/classes
Note: Some input files use or override a deprecated API.
Note: Recompile with -deprecation for details.
[rmic] RMI Compiling 28 classes to /home/autorun/cvs/geotools/gt/module/main/target/classes
java:jar-resources:
Copying 41 files to /home/autorun/cvs/geotools/gt/module/main/target/classes
test:prepare-filesystem:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/main/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/main/target/test-reports
test:test-resources:
Copying 112 files to /home/autorun/cvs/geotools/gt/module/main/target/test-classes
test:compile:
[javac] Compiling 147 source files to /home/autorun/cvs/geotools/gt/module/main/target/test-classes
test:test:
[junit] Running org.geotools.gml.ServiceTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.76 sec
[junit] Running org.geotools.gml.GmlTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.365 sec
[junit] Running org.geotools.gml.ProducerTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 1.283 sec
[junit] Running org.geotools.metadata.iso19115.MetaDataTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.765 sec
[junit] Running org.geotools.metadata.iso19115.ContactTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.679 sec
[junit] Running org.geotools.gui.tools.ToolListImplTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.689 sec
[junit] Running org.geotools.gui.swing.tables.FeatureTableModelTest
[junit] Tests run: 1, Failures: 0, Errors: 1, Time elapsed: 7.04 sec
[junit] [ERROR] TEST org.geotools.gui.swing.tables.FeatureTableModelTest FAILED
[junit] Running org.geotools.gui.swing.MiscellaneousWidgetTest
[junit] Tests run: 10, Failures: 0, Errors: 8, Time elapsed: 8.728 sec
[junit] [ERROR] TEST org.geotools.gui.swing.MiscellaneousWidgetTest FAILED
[junit] Running org.geotools.gui.swing.ProgressWindowTest
[junit] Tests run: 1, Failures: 0, Errors: 1, Time elapsed: 6.944 sec
[junit] [ERROR] TEST org.geotools.gui.swing.ProgressWindowTest FAILED
[junit] Running org.geotools.filter.SQLEncoderTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.847 sec
[junit] Running org.geotools.filter.FilterEqualsTest
[junit] Tests run: 10, Failures: 0, Errors: 0, Time elapsed: 0.894 sec
[junit] Running org.geotools.filter.ExpressionTest
[junit] Tests run: 10, Failures: 0, Errors: 0, Time elapsed: 0.873 sec
[junit] Running org.geotools.filter.FilterVisitorTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.752 sec
[junit] Running org.geotools.filter.XMLEncoderTest
[junit] Tests run: 14, Failures: 0, Errors: 0, Time elapsed: 1.4 sec
[junit] Running org.geotools.filter.AttributeTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.838 sec
[junit] Running org.geotools.filter.FilterAttributeExtractorTest
[junit] Tests run: 8, Failures: 0, Errors: 0, Time elapsed: 0.914 sec
[junit] Running org.geotools.filter.AreaFunctionTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.829 sec
[junit] Running org.geotools.filter.FilterTest
[junit] Tests run: 9, Failures: 0, Errors: 0, Time elapsed: 1.158 sec
[junit] Running org.geotools.filter.SQLUnpackerTest
[junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 1.085 sec
[junit] Running org.geotools.filter.CapabilitiesTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.684 sec
[junit] Running org.geotools.filter.MathTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.819 sec
[junit] Running org.geotools.filter.BetweenTest
[junit] Running org.geotools.filter.DOMParserTest
[junit] Tests run: 15, Failures: 0, Errors: 0, Time elapsed: 1.51 sec
[junit] Running org.geotools.filter.LiteralTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.768 sec
[junit] Running org.geotools.filter.ParserTest
[junit] Tests run: 19, Failures: 0, Errors: 0, Time elapsed: 1.65 sec
[junit] Running org.geotools.referencing.operation.transform.LocalizationGridTest
[junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 0.749 sec
[junit] Running org.geotools.referencing.operation.transform.MathTransformTest
[junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 9.598 sec
[junit] Running org.geotools.referencing.operation.ScriptTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.516 sec
[junit] Running org.geotools.referencing.operation.MatrixTest
[junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 0.768 sec
[junit] Running org.geotools.referencing.ParameterTest
[junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 1.203 sec
[junit] Running org.geotools.referencing.BasicTest
[junit] Tests run: 9, Failures: 0, Errors: 0, Time elapsed: 1.354 sec
[junit] Running org.geotools.gc.SampleTranscoderTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 3.205 sec
[junit] Running org.geotools.gc.GridCoverageTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 3.635 sec
[junit] Running org.geotools.gc.GridGeometryTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.914 sec
[junit] Running org.geotools.math.GeometryTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.729 sec
[junit] Running org.geotools.styling.XMLEncoderTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 1.434 sec
[junit] Running org.geotools.styling.SLDStyleTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 1.047 sec
[junit] Running org.geotools.styling.StyleAttributeExtractorTest
[junit] Tests run: 12, Failures: 0, Errors: 0, Time elapsed: 1.061 sec
[junit] Running org.geotools.styling.StyleObjectTest
[junit] Tests run: 18, Failures: 0, Errors: 0, Time elapsed: 0.889 sec
[junit] Running org.geotools.styling.TextSymbolTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.947 sec
[junit] Running org.geotools.styling.StyleFactoryImplTest
[junit] Tests run: 16, Failures: 0, Errors: 0, Time elapsed: 0.803 sec
[junit] Running org.geotools.feature.FlatFeatureFactorySpiTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.756 sec
[junit] Running org.geotools.feature.FeatureFlatTest
[junit] Tests run: 11, Failures: 0, Errors: 0, Time elapsed: 0.997 sec
[junit] Running org.geotools.feature.AttributeTypeTest
[junit] Tests run: 15, Failures: 0, Errors: 0, Time elapsed: 0.91 sec
[junit] Running org.geotools.feature.FeatureTypeFactoryTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.892 sec
[junit] Running org.geotools.feature.FeatureCollectionTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.954 sec
[junit] Running org.geotools.feature.FeatureTypeTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.953 sec
[junit] Running org.geotools.xml.DOMXPathTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.938 sec
[junit] Running org.geotools.xml.XPathFactoryTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.941 sec
[junit] Running org.geotools.measure.FormatTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.063 sec
[junit] Running org.geotools.units.UnitTest
[junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 0.934 sec
[junit] Running org.geotools.cs.WKTParserTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 1.436 sec
[junit] Running org.geotools.cs.CreationTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 1.292 sec
[junit] Running org.geotools.cs.GeodeticCalculatorTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 1.131 sec
[junit] Running org.geotools.gp.InterpolatorTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 10.051 sec
[junit] Running org.geotools.gp.OperationTest
[junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 4.03 sec
[junit] Running org.geotools.gp.ResampleTest
[junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 8.743 sec
[junit] Running org.geotools.ct.PassthroughTransformTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 1.268 sec
[junit] Running org.geotools.ct.ScriptTest
[junit] Tests run: 11, Failures: 0, Errors: 0, Time elapsed: 3.102 sec
[junit] Running org.geotools.ct.TransformationTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.196 sec
[junit] Running org.geotools.ct.ProjectionTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.931 sec
[junit] Running org.geotools.ct.GeocentricTransformTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 1.59 sec
[junit] Running org.geotools.renderer.j2d.RendererTest
[junit] Tests run: 1, Failures: 0, Errors: 1, Time elapsed: 7.677 sec
[junit] [ERROR] TEST org.geotools.renderer.j2d.RendererTest FAILED
[junit] Running org.geotools.renderer.geom.GeometryTest
[junit] Tests run: 1, Failures: 0, Errors: 1, Time elapsed: 7.007 sec
[junit] [ERROR] TEST org.geotools.renderer.geom.GeometryTest FAILED
[junit] Running org.geotools.renderer.geom.PolygonTest
[junit] Tests run: 1, Failures: 0, Errors: 1, Time elapsed: 7.888 sec
[junit] [ERROR] TEST org.geotools.renderer.geom.PolygonTest FAILED
[junit] Running org.geotools.renderer.lite.Rendering2DTest
[junit] Tests run: 3, Failures: 0, Errors: 3, Time elapsed: 7.708 sec
[junit] [ERROR] TEST org.geotools.renderer.lite.Rendering2DTest FAILED
[junit] Running org.geotools.renderer.lite.LiteShapeTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.025 sec
[junit] Running org.geotools.renderer.array.PointArrayTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 3.873 sec
[junit] Running org.geotools.io.coverage.PropertyParserTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 3.601 sec
[junit] Running org.geotools.cv.SampleDimensionTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 2.429 sec
[junit] Running org.geotools.cv.AdaptersTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 3.252 sec
[junit] Running org.geotools.cv.ScaledColorSpaceTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 1.051 sec
[junit] Running org.geotools.cv.CategoryListTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 1.34 sec
[junit] Running org.geotools.cv.CategoryTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.157 sec
[junit] Running org.geotools.data.coverage.grid.test.GridCoverageExchangeFinderTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.694 sec
[junit] Running org.geotools.data.coverage.grid.file.test.FileMetadataImplTest
[junit] Tests run: 10, Failures: 0, Errors: 0, Time elapsed: 0.869 sec
[junit] Running org.geotools.data.coverage.grid.file.test.FSCatalogEntryTest
[junit] Tests run: 8, Failures: 0, Errors: 0, Time elapsed: 0.791 sec
[junit] Running org.geotools.data.coverage.grid.stream.test.IOExchangeTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.716 sec
[junit] Running org.geotools.data.FeatureLockTest
[junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 0.754 sec
[junit] Running org.geotools.data.DataUtilitiesTest
[junit] Tests run: 20, Failures: 0, Errors: 0, Time elapsed: 1.413 sec
[junit] Running org.geotools.data.collection.CollectionDataStoreTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 1.183 sec
[junit] Running org.geotools.data.jdbc.JDBCDataStoreTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 1.209 sec
[junit] Running org.geotools.data.DefaultQueryTest
[junit] Tests run: 9, Failures: 0, Errors: 0, Time elapsed: 0.707 sec
[junit] Running org.geotools.data.FilteringFeatureReaderTest
[junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 0.984 sec
[junit] Running org.geotools.data.AbstractDataSourceTest
[junit] Tests run: 14, Failures: 0, Errors: 0, Time elapsed: 0.758 sec
[junit] Running org.geotools.data.DataSourceFinderTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.742 sec
[junit] Running org.geotools.data.memory.MemoryDataStoreTest
[junit] Tests run: 32, Failures: 0, Errors: 0, Time elapsed: 1.886 sec
[junit] Running org.geotools.data.MemoryDataSourceTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.933 sec
[junit] Running org.geotools.data.DatasourceTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.921 sec
[junit] Running org.geotools.data.MemoryLockingDataSourceTest
[junit] Tests run: 39, Failures: 0, Errors: 0, Time elapsed: 1.407 sec
[junit] Running org.geotools.algorithms.classification.EqualClassesTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.701 sec
[junit] Running org.geotools.algorithms.RobustGeometryPropertiesTest
[junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 1.04 sec
[junit] Running org.geotools.resources.NumberParserTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.702 sec
[junit] Running org.geotools.catalog.QueryTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.844 sec
[junit] Running org.geotools.catalog.MetadataXPathTest
[junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.742 sec
[junit] Running org.geotools.util.DisjointSetTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.696 sec
[junit] Running org.geotools.util.WeakHashSetTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 3.327 sec
[junit] Running org.geotools.util.MonolineFormatterTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.791 sec
[junit] Running org.geotools.util.WeakValueHashMapTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 2.259 sec
[junit] Running org.geotools.util.RangeSetTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.724 sec
[junit] Running org.geotools.map.MapContextTest
[junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 1.391 sec
[junit] Running org.geotools.map.MapLayerTest
[junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 1.105 sec
[junit] Running org.geotools.expr.LiteralExprTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.756 sec
[junit] Running org.geotools.expr.ArithmaticMathExprTest
[junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.666 sec
| Building Module geotools-utils
| Memory: 35M/67M
Attempting to download main-2.1.x.jar.
WARNING: Failed to download main-2.1.x.jar.
| Building Module geotools-renderer-sldstyling
| Memory: 35M/67M
Artifact /geoapi/jars/geoapi-SNAPSHOT.jar doesn't exists in remote repository, but it exists locally
| Building Module geotools-pickle
| Memory: 36M/67M
| Building Module geotools-sample-data
| Memory: 36M/67M
Plugin 'maven-deploy-plugin' in project 'geotools-sample-data' is not available
build:start:
build:log:
clean:clean:
[delete] Deleting directory /home/autorun/cvs/geotools/gt/module/sample-data/target
clean:
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/sample-data/target/classes
java:compile:
[echo] Compiling to /home/autorun/cvs/geotools/gt/module/sample-data/target/classes
java:jar-resources:
Copying 18 files to /home/autorun/cvs/geotools/gt/module/sample-data/target/classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/sample-data/target/test-classes
[mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/sample-data/target/test-reports
test:compile:
[echo] No test source files to compile.
test:test:
[echo] No tests to run.
[echo] merging test reports into higher directory
jar:jar:
[jar] Building jar: /home/autorun/cvs/geotools/gt/module/sample-data/target/sample-data-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/module/sample-data/target/sample-data-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/sample-data-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/module/sample-data/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/sample-data-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Module geotools-mapinfo
| Memory: 33M/67M
| Building Module geotools-svgsupport
| Memory: 34M/67M
geotools-gml
geotools-shapefile
geotools-arcsde
geotools-image
geotools-oraclespatial
geotools-dir
geotools-mysql
geotools-wms
geotools-postgis
geotools-geomedia
geotools-tiger
geotools-vpf
geotools-gtopo30
geotools-arcgrid
| Building Plugin geotools-gml
| Memory: 36M/67M
| Building Plugin geotools-shapefile
| Memory: 36M/67M
| Building Plugin geotools-arcsde
| Memory: 36M/67M
| Building Plugin geotools-image
| Memory: 37M/67M
| Building Plugin geotools-oraclespatial
| Memory: 33M/67M
Attempting to download shapefile-2.1.x.jar.
WARNING: Failed to download shapefile-2.1.x.jar.
| Building Plugin geotools-dir
| Memory: 34M/67M
Attempting to download gml-2.1.x.jar.
WARNING: Failed to download gml-2.1.x.jar.
| Building Plugin geotools-mysql
| Memory: 35M/67M
| Building Plugin geotools-wms
| Memory: 36M/67M
| Building Plugin geotools-postgis
| Memory: 37M/67M
| Building Plugin geotools-geomedia
| Memory: 33M/67M
| Building Plugin geotools-tiger
| Memory: 33M/67M
| Building Plugin geotools-vpf
| Memory: 34M/67M
| Building Plugin geotools-gtopo30
| Memory: 34M/67M
| Building Plugin geotools-arcgrid
| Memory: 35M/67M
Attempting to download view-2.1.x.jar.
WARNING: Failed to download view-2.1.x.jar.
geotools-graph
geotools-reprojection
geotools-j2se-demos
geotools-validation
geotools-view
geotools-legend
| Building geotools-graph
| Memory: 33M/67M
| Building geotools-reprojection
| Memory: 34M/67M
| Building geotools-j2se-demos
| Memory: 34M/67M
| Building geotools-validation
| Memory: 35M/67M
Attempting to download dir_ds-2.1.x.jar.
WARNING: Failed to download dir_ds-2.1.x.jar.
Attempting to download graph-2.1.x.jar.
WARNING: Failed to download graph-2.1.x.jar.
Attempting to download postgis-2.1.x.jar.
WARNING: Failed to download postgis-2.1.x.jar.
| Building geotools-view
| Memory: 37M/67M
| Building geotools-legend
| Memory: 37M/67M
build:end:
[echo] BUILD REPORT (from buildReport.txt):
Sucessfull modules should read 'cleaned, compiled, tested, INSTALLED HHMM'
If some modules failed to INSTALL, look for problems from the TOP DOWN as
failures lower in the list will probaly be caused by ones higher up.
If modules cleanded and compiled but were not tested look in the
/target/test-reports direcotry of your module for details.
You can debug problems from the module directory using 'maven java:compile',
'maven test' and 'maven jar:install'.
These build results are available in buildResults.txt
Maven always says 'Build Sucessful', please check the above report.
BUILD SUCCESSFUL
Total time: 6 minutes 31 seconds
Finished at: Sat Aug 07 23:51:50 PDT 2004
