[Geoserver-devel] GeoTools Build Report [ 2004/08/09 09:20 ]
GeoTools2 module build report 20040809
    gt2:main cleaned, compiled, tested, INSTALLED 0928
    gt2:utils cleaned, compiled, tested, INSTALLED 0928
    gt2:rendering-styling cleaned, compiled, tested, INSTALLED 0930
    gt2:pickle cleaned, compiled, tested, INSTALLED 0930
    gt2:sample-data cleaned, compiled, tested, INSTALLED 0930
    gt2:mapinfo cleaned, compiled, tested, INSTALLED 0930
    gt2:svgsupport cleaned, compiled, tested, INSTALLED 0930
    gt2:gml cleaned
    gt2:shapefile cleaned, compiled, tested, INSTALLED 0931
    gt2:arcsde cleaned, compiled, tested, INSTALLED 0931
    gt2:image cleaned, compiled, tested, INSTALLED 0931
    gt2:oracle-spatial cleaned, compiled, tested, INSTALLED 0931
    gt2:mysql cleaned, compiled, tested, INSTALLED 0931
    gt2:wms cleaned, compiled, tested, INSTALLED 0932
    gt2:postgis cleaned, compiled, tested, INSTALLED 0932
    gt2:geomedia cleaned, compiled, tested, INSTALLED 0932
    gt2:tiger cleaned
    gt2:vpf cleaned, compiled
    gt2:gtopo30 cleaned, compiled, tested, INSTALLED 0932
    gt2:graph cleaned, compiled, tested, INSTALLED 0933
    gt2:reprojection cleaned, compiled, tested, INSTALLED 0933
    gt2:j2se-demos cleaned, compiled, tested, INSTALLED 0934
    gt2:view cleaned, compiled, tested, INSTALLED 0934
    gt2:legend cleaned, compiled, tested, INSTALLED 0934
__ __
| \/ |__ _Apache__ ___
| |\/| / _` \ V / -_) ' \ ~ intelligent projects ~
|_| |_\__,_|\_/\___|_||_| v. 1.0
build:start:
build:
    [echo] looking for modules in: /home/autorun/cvs/geotools/gt/module, /home/autorun/cvs/geotools/gt/plugin, /home/autorun/cvs/geotools/gt/ext
      reporting progress to /home/autorun/cvs/geotools/gt
        [delete] Deleting directory /home/autorun/cvs/geotools/gt/target/test-reports
Starting the reactor...
Our processing order:
geotools-main
geotools-utils
geotools-renderer-sldstyling
geotools-pickle
geotools-sample-data
geotools-mapinfo
geotools-svgsupport
| Building Module geotools-main
| Memory: 3M/5M
Attempting to download geoapi-SNAPSHOT.jar.
Plugin 'maven-deploy-plugin' in project 'geotools-main' is not available
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/module/main/target
clean:
java:prepare-filesystem:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/main/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/module/main/target/classes
    [javac] Compiling 1037 source files to /home/autorun/cvs/geotools/gt/module/main/target/classes
Note: Some input files use or override a deprecated API.
Note: Recompile with -deprecation for details.
    [rmic] RMI Compiling 28 classes to /home/autorun/cvs/geotools/gt/module/main/target/classes
java:jar-resources:
Copying 41 files to /home/autorun/cvs/geotools/gt/module/main/target/classes
test:prepare-filesystem:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/main/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/main/target/test-reports
test:test-resources:
Copying 112 files to /home/autorun/cvs/geotools/gt/module/main/target/test-classes
test:compile:
    [javac] Compiling 147 source files to /home/autorun/cvs/geotools/gt/module/main/target/test-classes
test:test:
    [junit] Running org.geotools.gml.ServiceTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.783 sec
    [junit] Running org.geotools.gml.GmlTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.409 sec
    [junit] Running org.geotools.gml.ProducerTest
    [junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 1.332 sec
    [junit] Running org.geotools.metadata.iso19115.MetaDataTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.77 sec
    [junit] Running org.geotools.metadata.iso19115.ContactTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.684 sec
    [junit] Running org.geotools.gui.tools.ToolListImplTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.69 sec
    [junit] Running org.geotools.gui.swing.tables.FeatureTableModelTest
    [junit] Warning: Cannot convert string "-b&h-lucida-medium-r-normal-sans-*-140-*-*-p-*-iso8859-1" to type FontStruct
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 4.717 sec
    [junit] Running org.geotools.gui.swing.MiscellaneousWidgetTest
    [junit] Tests run: 10, Failures: 0, Errors: 0, Time elapsed: 11.261 sec
    [junit] Running org.geotools.gui.swing.ProgressWindowTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 4.489 sec
    [junit] Running org.geotools.filter.SQLEncoderTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.835 sec
    [junit] Running org.geotools.filter.FilterEqualsTest
    [junit] Tests run: 10, Failures: 0, Errors: 0, Time elapsed: 0.902 sec
    [junit] Running org.geotools.filter.ExpressionTest
    [junit] Tests run: 10, Failures: 0, Errors: 0, Time elapsed: 0.87 sec
    [junit] Running org.geotools.filter.FilterVisitorTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.761 sec
    [junit] Running org.geotools.filter.XMLEncoderTest
    [junit] Tests run: 14, Failures: 0, Errors: 0, Time elapsed: 1.399 sec
    [junit] Running org.geotools.filter.AttributeTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.826 sec
    [junit] Running org.geotools.filter.FilterAttributeExtractorTest
    [junit] Tests run: 8, Failures: 0, Errors: 0, Time elapsed: 0.898 sec
    [junit] Running org.geotools.filter.AreaFunctionTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.822 sec
    [junit] Running org.geotools.filter.FilterTest
    [junit] Tests run: 9, Failures: 0, Errors: 0, Time elapsed: 1.178 sec
    [junit] Running org.geotools.filter.SQLUnpackerTest
    [junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 1.082 sec
    [junit] Running org.geotools.filter.CapabilitiesTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.695 sec
    [junit] Running org.geotools.filter.MathTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.861 sec
    [junit] Running org.geotools.filter.BetweenTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.834 sec
    [junit] Running org.geotools.filter.DOMParserTest
    [junit] Tests run: 15, Failures: 0, Errors: 0, Time elapsed: 1.501 sec
    [junit] Running org.geotools.filter.LiteralTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.792 sec
    [junit] Running org.geotools.filter.ParserTest
    [junit] Tests run: 19, Failures: 0, Errors: 0, Time elapsed: 1.628 sec
    [junit] Running org.geotools.referencing.operation.transform.LocalizationGridTest
    [junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 0.761 sec
    [junit] Running org.geotools.referencing.operation.transform.MathTransformTest
    [junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 10.149 sec
    [junit] Running org.geotools.referencing.operation.ScriptTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.529 sec
    [junit] Running org.geotools.referencing.operation.MatrixTest
    [junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 0.778 sec
    [junit] Running org.geotools.referencing.ParameterTest
    [junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 1.237 sec
    [junit] Running org.geotools.referencing.BasicTest
    [junit] Tests run: 9, Failures: 0, Errors: 0, Time elapsed: 1.413 sec
    [junit] Running org.geotools.gc.SampleTranscoderTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 3.704 sec
    [junit] Running org.geotools.gc.GridCoverageTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 4.052 sec
    [junit] Running org.geotools.gc.GridGeometryTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.909 sec
    [junit] Running org.geotools.math.GeometryTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.767 sec
    [junit] Running org.geotools.styling.XMLEncoderTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 1.441 sec
    [junit] Running org.geotools.styling.SLDStyleTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 1.069 sec
    [junit] Running org.geotools.styling.StyleAttributeExtractorTest
    [junit] Tests run: 12, Failures: 0, Errors: 0, Time elapsed: 1.082 sec
    [junit] Running org.geotools.styling.StyleObjectTest
    [junit] Tests run: 18, Failures: 0, Errors: 0, Time elapsed: 0.892 sec
    [junit] Running org.geotools.styling.TextSymbolTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.953 sec
    [junit] Running org.geotools.styling.StyleFactoryImplTest
    [junit] Tests run: 16, Failures: 0, Errors: 0, Time elapsed: 0.808 sec
    [junit] Running org.geotools.feature.FlatFeatureFactorySpiTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.753 sec
    [junit] Running org.geotools.feature.FeatureFlatTest
    [junit] Tests run: 11, Failures: 0, Errors: 0, Time elapsed: 1.021 sec
    [junit] Running org.geotools.feature.AttributeTypeTest
    [junit] Tests run: 15, Failures: 0, Errors: 0, Time elapsed: 0.918 sec
    [junit] Running org.geotools.feature.FeatureTypeFactoryTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.894 sec
    [junit] Running org.geotools.feature.FeatureCollectionTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.946 sec
    [junit] Running org.geotools.feature.FeatureTypeTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.959 sec
    [junit] Running org.geotools.xml.DOMXPathTest
    [junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.943 sec
    [junit] Running org.geotools.xml.XPathFactoryTest
    [junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.927 sec
    [junit] Running org.geotools.measure.FormatTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.128 sec
    [junit] Running org.geotools.units.UnitTest
    [junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 0.959 sec
    [junit] Running org.geotools.cs.WKTParserTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 1.519 sec
    [junit] Running org.geotools.cs.CreationTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 1.297 sec
    [junit] Running org.geotools.cs.GeodeticCalculatorTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 1.137 sec
    [junit] Running org.geotools.gp.InterpolatorTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 9.009 sec
    [junit] Running org.geotools.gp.OperationTest
    [junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 4.205 sec
    [junit] Running org.geotools.gp.ResampleTest
    [junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 8.859 sec
    [junit] Running org.geotools.ct.PassthroughTransformTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 1.295 sec
    [junit] Running org.geotools.ct.ScriptTest
    [junit] Tests run: 11, Failures: 0, Errors: 0, Time elapsed: 3.058 sec
    [junit] Running org.geotools.ct.TransformationTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.218 sec
    [junit] Running org.geotools.ct.ProjectionTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.942 sec
    [junit] Running org.geotools.ct.GeocentricTransformTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 1.665 sec
    [junit] Running org.geotools.renderer.j2d.RendererTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 6.315 sec
    [junit] Running org.geotools.renderer.geom.GeometryTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 1.616 sec
    [junit] Running org.geotools.renderer.geom.PolygonTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 2.478 sec
    [junit] Running org.geotools.renderer.lite.Rendering2DTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 6.955 sec
    [junit] Running org.geotools.renderer.lite.LiteShapeTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.01 sec
    [junit] Running org.geotools.renderer.array.PointArrayTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 4.225 sec
    [junit] Running org.geotools.io.coverage.PropertyParserTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 3.42 sec
    [junit] Running org.geotools.cv.SampleDimensionTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 2.543 sec
    [junit] Running org.geotools.cv.AdaptersTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 2.972 sec
    [junit] Running org.geotools.cv.ScaledColorSpaceTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.837 sec
    [junit] Running org.geotools.cv.CategoryListTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 1.37 sec
    [junit] Running org.geotools.cv.CategoryTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.186 sec
    [junit] Running org.geotools.data.coverage.grid.test.GridCoverageExchangeFinderTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.696 sec
    [junit] Running org.geotools.data.coverage.grid.file.test.FileMetadataImplTest
    [junit] Tests run: 10, Failures: 0, Errors: 0, Time elapsed: 0.876 sec
    [junit] Running org.geotools.data.coverage.grid.file.test.FSCatalogEntryTest
    [junit] Tests run: 8, Failures: 0, Errors: 0, Time elapsed: 0.814 sec
    [junit] Running org.geotools.data.coverage.grid.stream.test.IOExchangeTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.712 sec
    [junit] Running org.geotools.data.FeatureLockTest
    [junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 0.744 sec
    [junit] Running org.geotools.data.DataUtilitiesTest
    [junit] Tests run: 20, Failures: 0, Errors: 0, Time elapsed: 1.387 sec
    [junit] Running org.geotools.data.collection.CollectionDataStoreTest
    [junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 1.186 sec
    [junit] Running org.geotools.data.jdbc.JDBCDataStoreTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 1.208 sec
    [junit] Running org.geotools.data.DefaultQueryTest
    [junit] Tests run: 9, Failures: 0, Errors: 0, Time elapsed: 0.747 sec
    [junit] Running org.geotools.data.FilteringFeatureReaderTest
    [junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 0.984 sec
    [junit] Running org.geotools.data.AbstractDataSourceTest
    [junit] Tests run: 14, Failures: 0, Errors: 0, Time elapsed: 0.782 sec
    [junit] Running org.geotools.data.DataSourceFinderTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.774 sec
    [junit] Running org.geotools.data.memory.MemoryDataStoreTest
    [junit] Tests run: 32, Failures: 0, Errors: 0, Time elapsed: 1.854 sec
    [junit] Running org.geotools.data.MemoryDataSourceTest
    [junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.936 sec
    [junit] Running org.geotools.data.DatasourceTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.956 sec
    [junit] Running org.geotools.data.MemoryLockingDataSourceTest
    [junit] Tests run: 39, Failures: 0, Errors: 0, Time elapsed: 1.34 sec
    [junit] Running org.geotools.algorithms.classification.EqualClassesTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.684 sec
    [junit] Running org.geotools.algorithms.RobustGeometryPropertiesTest
    [junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 1.017 sec
    [junit] Running org.geotools.resources.NumberParserTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.736 sec
    [junit] Running org.geotools.catalog.QueryTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.866 sec
    [junit] Running org.geotools.catalog.MetadataXPathTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.756 sec
    [junit] Running org.geotools.util.DisjointSetTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.723 sec
    [junit] Running org.geotools.util.WeakHashSetTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 3.286 sec
    [junit] Running org.geotools.util.MonolineFormatterTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.836 sec
    [junit] Running org.geotools.util.WeakValueHashMapTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 2.273 sec
    [junit] Running org.geotools.util.RangeSetTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.726 sec
    [junit] Running org.geotools.map.MapContextTest
    [junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 1.435 sec
    [junit] Running org.geotools.map.MapLayerTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 1.168 sec
    [junit] Running org.geotools.expr.LiteralExprTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.767 sec
    [junit] Running org.geotools.expr.ArithmaticMathExprTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.683 sec
    [echo] merging test reports into higher directory
    [copy] Copying 104 files to /home/autorun/cvs/geotools/gt/target/test-reports
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/module/main/target/main-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/module/main/target/main-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/main-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/module/main/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/main-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Module geotools-utils
| Memory: 36M/67M
Plugin 'maven-deploy-plugin' in project 'geotools-utils' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/module/utils/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/utils/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/module/utils/target/classes
    [javac] Compiling 1 source file to /home/autorun/cvs/geotools/gt/module/utils/target/classes
java:jar-resources:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/utils/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/utils/target/test-reports
test:compile:
    [echo] No test source files to compile.
test:test:
    [echo] No tests to run.
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/module/utils/target/utils-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/module/utils/target/utils-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/utils-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/module/utils/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/utils-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Module geotools-renderer-sldstyling
| Memory: 39M/67M
Artifact /geoapi/jars/geoapi-SNAPSHOT.jar doesn't exists in remote repository, but it exists locally
Plugin 'maven-deploy-plugin' in project 'geotools-renderer-sldstyling' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/module/rendering-styling/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/rendering-styling/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/module/rendering-styling/target/classes
    [echo] No java source files to compile.
java:jar-resources:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/rendering-styling/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/rendering-styling/target/test-reports
Copying 24 files to /home/autorun/cvs/geotools/gt/module/rendering-styling/target/test-classes
test:compile:
    [javac] Compiling 4 source files to /home/autorun/cvs/geotools/gt/module/rendering-styling/target/test-classes
Note: /home/autorun/cvs/geotools/gt/module/rendering-styling/test/org/geotools/styling/RenderingGridCoverageTest.java uses or overrides a deprecated API.
test:test:
    [junit] Running org.geotools.styling.DefaultMarkTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 10.567 sec
    [junit] Running org.geotools.styling.RenderStyleTest
Aug 9, 2004 9:30:22 AM org.geotools.styling.RenderStyleTest performTestOnRenderer
INFO: Comparing pixels between:
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_builder400x350.png
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_400x350.png
Aug 9, 2004 9:30:23 AM org.geotools.styling.RenderStyleTest performTestOnRenderer
INFO: Total pixel differences 112
Aug 9, 2004 9:30:25 AM org.geotools.styling.RenderStyleTest performTestOnRenderer
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_builder400x350.png
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_400x350.png
Aug 9, 2004 9:30:26 AM org.geotools.styling.RenderStyleTest performTestOnRenderer
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_xml400x250.png
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_400x250.png
INFO: Total pixel differences 80
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_xml400x450.png
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_400x450.png
Aug 9, 2004 9:30:27 AM org.geotools.styling.RenderStyleTest performTestOnRenderer
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_xml200x350.png
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_200x350.png
INFO: Total pixel differences 96
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_xml400x350.png
Aug 9, 2004 9:30:28 AM org.geotools.styling.RenderStyleTest performTestOnRenderer
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_xml600x350.png
INFO: RenderStyleTest_org_geotools_renderer_lite_LiteRenderer_600x350.png
INFO: Total pixel differences 103
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_xml400x250.png
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_400x250.png
INFO: Total pixel differences 113
Aug 9, 2004 9:30:29 AM org.geotools.styling.RenderStyleTest performTestOnRenderer
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_xml400x350.png
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_xml200x350.png
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_200x350.png
INFO: Total pixel differences 119
Aug 9, 2004 9:30:30 AM org.geotools.styling.RenderStyleTest performTestOnRenderer
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_xml600x350.png
INFO: RenderStyleTest_org_geotools_renderer_j2d_StyledMapRenderer_600x350.png
    [junit] Tests run: 12, Failures: 0, Errors: 0, Time elapsed: 10.2 sec
    [junit] Running org.geotools.styling.RenderingGridCoverageTest
Aug 9, 2004 9:30:34 AM org.geotools.gp.GridCoverageProcessor getDefault
WARNING: No such "org.geotools.Hysteresis" operation for this processor.
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 4.835 sec
    [junit] Running org.geotools.styling.TextStyleTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 3.795 sec
    [copy] Copying 4 files to /home/autorun/cvs/geotools/gt/target/test-reports
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/module/rendering-styling/target/rendering-styling-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/module/rendering-styling/target/rendering-styling-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/rendering-styling-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/module/rendering-styling/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/rendering-styling-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Module geotools-pickle
| Memory: 36M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-pickle' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/module/pickle/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/pickle/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/module/pickle/target/classes
    [javac] Compiling 4 source files to /home/autorun/cvs/geotools/gt/module/pickle/target/classes
Note: /home/autorun/cvs/geotools/gt/module/pickle/src/org/geotools/data/pickle/GeometryPickler.java uses or overrides a deprecated API.
java:jar-resources:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/pickle/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/pickle/target/test-reports
Copying 1 file to /home/autorun/cvs/geotools/gt/module/pickle/target/test-classes
test:compile:
    [javac] Compiling 1 source file to /home/autorun/cvs/geotools/gt/module/pickle/target/test-classes
test:test:
    [junit] Running org.geotools.data.pickle.PickleTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 2.225 sec
    [copy] Copying 1 file to /home/autorun/cvs/geotools/gt/target/test-reports
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/module/pickle/target/pickle-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/module/pickle/target/pickle-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/pickle-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/module/pickle/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/pickle-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Module geotools-sample-data
| Memory: 46M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-sample-data' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/module/sample-data/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/sample-data/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/module/sample-data/target/classes
java:jar-resources:
Copying 18 files to /home/autorun/cvs/geotools/gt/module/sample-data/target/classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/sample-data/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/sample-data/target/test-reports
test:compile:
test:test:
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/module/sample-data/target/sample-data-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/module/sample-data/target/sample-data-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/sample-data-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/module/sample-data/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/sample-data-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Module geotools-mapinfo
| Memory: 44M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-mapinfo' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/module/mapinfo/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/mapinfo/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/module/mapinfo/target/classes
    [javac] Compiling 3 source files to /home/autorun/cvs/geotools/gt/module/mapinfo/target/classes
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/module/mapinfo/target/classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/mapinfo/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/mapinfo/target/test-reports
Copying 8 files to /home/autorun/cvs/geotools/gt/module/mapinfo/target/test-classes
test:compile:
    [javac] Compiling 6 source files to /home/autorun/cvs/geotools/gt/module/mapinfo/target/test-classes
test:test:
    [junit] Running org.geotools.data.mapinfo.LoadTest
Aug 9, 2004 9:30:50 AM org.geotools.data.mapinfo.MapInfoDataSource readMifHeader
INFO: version [300]
INFO: delimiter [,]
Read 49 features
Aug 9, 2004 9:30:51 AM org.geotools.data.mapinfo.MapInfoDataSource readMifHeader
INFO: version [300]
INFO: Charset [Neutral]
INFO: delimiter [,]
Read 4 features
INFO: version [300]
INFO: delimiter [,]
Read 4 features
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.818 sec
    [junit] Running org.geotools.data.mapinfo.MapInfoDataSourceTest
Testing ability to load file:/home/autorun/cvs/geotools/gt/module/mapinfo/target/test-classes/org/geotools/data/mapinfo/test-data/statepop.mif
Aug 9, 2004 9:30:52 AM org.geotools.data.mapinfo.MapInfoDataSource readMifHeader
INFO: version [300]
INFO: delimiter [,]
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.906 sec
    [copy] Copying 2 files to /home/autorun/cvs/geotools/gt/target/test-reports
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/module/mapinfo/target/mapinfo-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/module/mapinfo/target/mapinfo-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/mapinfo-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/module/mapinfo/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/mapinfo-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Module geotools-svgsupport
| Memory: 26M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-svgsupport' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/module/svgsupport/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/svgsupport/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/module/svgsupport/target/classes
    [javac] Compiling 1 source file to /home/autorun/cvs/geotools/gt/module/svgsupport/target/classes
java:jar-resources:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/svgsupport/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/module/svgsupport/target/test-reports
Copying 8 files to /home/autorun/cvs/geotools/gt/module/svgsupport/target/test-classes
test:compile:
    [javac] Compiling 1 source file to /home/autorun/cvs/geotools/gt/module/svgsupport/target/test-classes
Note: /home/autorun/cvs/geotools/gt/module/svgsupport/test/org/geotools/svg/SVGTest.java uses or overrides a deprecated API.
test:test:
    [junit] Running org.geotools.svg.SVGTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 2.981 sec
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/module/svgsupport/target/svgsupport-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/module/svgsupport/target/svgsupport-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/svgsupport-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/module/svgsupport/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/svgsupport-2.1.x.pom'
jar:install:
mergeTestReports:
geotools-gml
geotools-shapefile
geotools-arcsde
geotools-image
geotools-oraclespatial
geotools-dir
geotools-mysql
geotools-wms
geotools-postgis
geotools-geomedia
geotools-tiger
geotools-vpf
geotools-gtopo30
geotools-arcgrid
| Building Plugin geotools-gml
| Memory: 33M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-gml' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/gml/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/gml/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/gml/target/classes
    [javac] Compiling 2 source files to /home/autorun/cvs/geotools/gt/plugin/gml/target/classes
/home/autorun/cvs/geotools/gt/plugin/gml/src/org/geotools/data/gml/GMLDataStoreFactory.java:10: package org.geotools.data.dir does not exist
import org.geotools.data.dir.FileDataStoreFactorySpi;
/home/autorun/cvs/geotools/gt/plugin/gml/src/org/geotools/data/gml/GMLDataStoreFactory.java:19: cannot resolve symbol
symbol : class FileDataStoreFactorySpi location: class org.geotools.data.gml.GMLDataStoreFactory
public class GMLDataStoreFactory implements FileDataStoreFactorySpi {
/home/autorun/cvs/geotools/gt/plugin/gml/src/org/geotools/data/gml/GMLDataStoreFactory.java:62: cannot resolve symbol
symbol : class Param location: class org.geotools.data.gml.GMLDataStoreFactory
    private static final Param URLP = new Param("url", URL.class,
/home/autorun/cvs/geotools/gt/plugin/gml/src/org/geotools/data/gml/GMLDataStoreFactory.java:67: cannot resolve symbol
    public Param getParametersInfo() {
/home/autorun/cvs/geotools/gt/plugin/gml/src/org/geotools/data/gml/GMLDataStore.java:9: package org.geotools.data.dir does not exist
import org.geotools.data.dir.AbstractFileDataStore;
/home/autorun/cvs/geotools/gt/plugin/gml/src/org/geotools/data/gml/GMLDataStore.java:20: cannot resolve symbol
symbol : class AbstractFileDataStore location: class org.geotools.data.gml.GMLDataStore
public class GMLDataStore extends AbstractFileDataStore {
/home/autorun/cvs/geotools/gt/plugin/gml/src/org/geotools/data/gml/GMLDataStoreFactory.java:68: cannot resolve symbol
        return new Param { URLP, };
8 errors
| Building Plugin geotools-shapefile
| Memory: 37M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-shapefile' is not available
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/shapefile/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/shapefile/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/shapefile/target/classes
    [javac] Compiling 21 source files to /home/autorun/cvs/geotools/gt/plugin/shapefile/target/classes
java:jar-resources:
Copying 3 files to /home/autorun/cvs/geotools/gt/plugin/shapefile/target/classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/shapefile/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/shapefile/target/test-reports
Copying 8 files to /home/autorun/cvs/geotools/gt/plugin/shapefile/target/test-classes
test:compile:
    [javac] Compiling 10 source files to /home/autorun/cvs/geotools/gt/plugin/shapefile/target/test-classes
test:test:
    [junit] Running org.geotools.data.shapefile.TestCaseSupportTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.854 sec
    [junit] Running org.geotools.data.shapefile.ShapefileTest
    [junit] Tests run: 10, Failures: 0, Errors: 0, Time elapsed: 1.403 sec
    [junit] Running org.geotools.data.shapefile.ServiceTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.8 sec
    [junit] Running org.geotools.data.shapefile.shp.PolygonHandlerTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.908 sec
    [junit] Running org.geotools.data.shapefile.ShapefileReadWriteTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 2.796 sec
    [junit] Running org.geotools.data.shapefile.ShapefileDataStoreTest
    [junit] Tests run: 10, Failures: 0, Errors: 0, Time elapsed: 3.805 sec
    [junit] Running org.geotools.data.shapefile.ShapefileDataSourceTest
    [junit] Tests run: 10, Failures: 0, Errors: 0, Time elapsed: 2.46 sec
    [junit] Running org.geotools.data.shapefile.DbaseFileTest
    [junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 1.272 sec
    [copy] Copying 8 files to /home/autorun/cvs/geotools/gt/target/test-reports
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/plugin/shapefile/target/shapefile-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/plugin/shapefile/target/shapefile-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/shapefile-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/plugin/shapefile/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/shapefile-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Plugin geotools-arcsde
| Memory: 47M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-arcsde' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/arcsde/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/arcsde/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/arcsde/target/classes
    [javac] Compiling 16 source files to /home/autorun/cvs/geotools/gt/plugin/arcsde/target/classes
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/plugin/arcsde/target/classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/arcsde/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/arcsde/target/test-reports
Copying 11 files to /home/autorun/cvs/geotools/gt/plugin/arcsde/target/test-classes
test:compile:
    [javac] Compiling 6 source files to /home/autorun/cvs/geotools/gt/plugin/arcsde/target/test-classes
Note: /home/autorun/cvs/geotools/gt/plugin/arcsde/test/org/geotools/data/arcsde/GeometryBuilderTest.java uses or overrides a deprecated API.
test:test:
    [junit] Running org.geotools.data.arcsde.GeometryBuilderTest
    [junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 1.436 sec
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/plugin/arcsde/target/arcsde-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/plugin/arcsde/target/arcsde-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/arcsde-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/plugin/arcsde/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/arcsde-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Plugin geotools-image
| Memory: 21M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-image' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/image/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/image/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/image/target/classes
    [javac] Compiling 6 source files to /home/autorun/cvs/geotools/gt/plugin/image/target/classes
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/plugin/image/target/classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/image/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/image/target/test-reports
Copying 2 files to /home/autorun/cvs/geotools/gt/plugin/image/target/test-classes
test:compile:
    [javac] Compiling 4 source files to /home/autorun/cvs/geotools/gt/plugin/image/target/test-classes
test:test:
    [junit] Running org.geotools.coverage.WorldImageFormatTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.781 sec
    [junit] Running org.geotools.coverage.WorldImageWriterTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.731 sec
    [junit] Running org.geotools.coverage.WorldImageReaderTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 5.391 sec
    [copy] Copying 3 files to /home/autorun/cvs/geotools/gt/target/test-reports
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/plugin/image/target/image-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/plugin/image/target/image-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/image-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/plugin/image/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/image-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Plugin geotools-oraclespatial
| Memory: 28M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-oraclespatial' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/oraclespatial/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/oraclespatial/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/oraclespatial/target/classes
    [javac] Compiling 19 source files to /home/autorun/cvs/geotools/gt/plugin/oraclespatial/target/classes
java:jar-resources:
Copying 2 files to /home/autorun/cvs/geotools/gt/plugin/oraclespatial/target/classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/oraclespatial/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/oraclespatial/target/test-reports
Copying 1 file to /home/autorun/cvs/geotools/gt/plugin/oraclespatial/target/test-classes
test:compile:
    [javac] Compiling 7 source files to /home/autorun/cvs/geotools/gt/plugin/oraclespatial/target/test-classes
test:test:
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/plugin/oraclespatial/target/oracle-spatial-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/plugin/oraclespatial/target/oracle-spatial-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/oracle-spatial-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/plugin/oraclespatial/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/oracle-spatial-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Plugin geotools-dir
| Memory: 39M/59M
Attempting to download gml-2.1.x.jar.
WARNING: Failed to download gml-2.1.x.jar.
| Building Plugin geotools-mysql
| Memory: 39M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-mysql' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/mysql/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/mysql/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/mysql/target/classes
    [javac] Compiling 9 source files to /home/autorun/cvs/geotools/gt/plugin/mysql/target/classes
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/plugin/mysql/target/classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/mysql/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/mysql/target/test-reports
Copying 2 files to /home/autorun/cvs/geotools/gt/plugin/mysql/target/test-classes
test:compile:
    [javac] Compiling 7 source files to /home/autorun/cvs/geotools/gt/plugin/mysql/target/test-classes
test:test:
    [junit] Running org.geotools.filter.SQLEncoderMySQLTest
exporting GeometryFilter
    [junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 0.198 sec
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/plugin/mysql/target/mysql-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/plugin/mysql/target/mysql-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/mysql-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/plugin/mysql/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/mysql-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Plugin geotools-wms
| Memory: 49M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-wms' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/wms/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/wms/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/wms/target/classes
    [javac] Compiling 53 source files to /home/autorun/cvs/geotools/gt/plugin/wms/target/classes
Note: /home/autorun/cvs/geotools/gt/plugin/wms/src/org/geotools/data/wms/gce/WMSReader.java uses or overrides a deprecated API.
java:jar-resources:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/wms/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/wms/target/test-reports
test:compile:
    [javac] Compiling 2 source files to /home/autorun/cvs/geotools/gt/plugin/wms/target/test-classes
test:test:
    [junit] Running org.geotools.data.wms.test.WebMapServerTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 2.759 sec
    [junit] Running org.geotools.data.wms.gce.test.WMSReaderTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 5.095 sec
jar:jar:
    [echo] Warning: shortDescription is greater than 49 characters - trimming for specification title.
    [jar] Building jar: /home/autorun/cvs/geotools/gt/plugin/wms/target/wms-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/plugin/wms/target/wms-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/wms-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/plugin/wms/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/wms-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Plugin geotools-postgis
| Memory: 26M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-postgis' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/postgis/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/postgis/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/postgis/target/classes
    [javac] Compiling 13 source files to /home/autorun/cvs/geotools/gt/plugin/postgis/target/classes
Note: /home/autorun/cvs/geotools/gt/plugin/postgis/src/org/geotools/data/postgis/PostgisDataStoreFactory.java uses or overrides a deprecated API.
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/plugin/postgis/target/classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/postgis/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/postgis/target/test-reports
Copying 1 file to /home/autorun/cvs/geotools/gt/plugin/postgis/target/test-classes
test:compile:
    [javac] Compiling 5 source files to /home/autorun/cvs/geotools/gt/plugin/postgis/target/test-classes
test:test:
    [junit] Running org.geotools.filter.SQLEncoderPostgisTest
    [junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 0.926 sec
    [junit] Running org.geotools.data.postgis.PostgisDataStoreFactoryTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.219 sec
    [junit] Running org.geotools.data.postgis.WKBEncoderTest
    [junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.76 sec
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/plugin/postgis/target/postgis-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/plugin/postgis/target/postgis-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/postgis-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/plugin/postgis/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/postgis-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Plugin geotools-geomedia
| Memory: 36M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-geomedia' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/geomedia/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/geomedia/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/geomedia/target/classes
    [javac] Compiling 9 source files to /home/autorun/cvs/geotools/gt/plugin/geomedia/target/classes
Note: /home/autorun/cvs/geotools/gt/plugin/geomedia/src/org/geotools/data/geomedia/GeoMediaDataStoreFactory.java uses or overrides a deprecated API.
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/plugin/geomedia/target/classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/geomedia/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/geomedia/target/test-reports
test:compile:
test:test:
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/plugin/geomedia/target/geomedia-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/plugin/geomedia/target/geomedia-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/geomedia-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/plugin/geomedia/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/geomedia-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Plugin geotools-tiger
| Memory: 41M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-tiger' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/tiger/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/tiger/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/tiger/target/classes
    [javac] Compiling 7 source files to /home/autorun/cvs/geotools/gt/plugin/tiger/target/classes
/home/autorun/cvs/geotools/gt/plugin/tiger/src/org/geotools/data/tiger/TigerDataStore.java:51: cannot access org.opengis.catalog.Catalog
file org/opengis/catalog/Catalog.class not found
public class TigerDataStore extends AbstractDataStore {
/home/autorun/cvs/geotools/gt/plugin/tiger/src/org/geotools/data/tiger/TigerDataStore.java:82: an enclosing instance that contains org.geotools.data.tiger.TigerDataStore.TigerFilenameFilter is required
        String list = directory.list(new TigerFilenameFilter());
/home/autorun/cvs/geotools/gt/plugin/tiger/src/org/geotools/data/tiger/TigerDataStoreFactory.java:69: incompatible types
found : org.geotools.data.tiger.TigerDataStore
required: org.geotools.data.DataStore
            return new TigerDataStore(file); ^
/home/autorun/cvs/geotools/gt/plugin/tiger/src/org/geotools/data/tiger/TigerDataStoreFactory.java:102: incompatible types
        return new TigerDataStore(dirName);
Note: /home/autorun/cvs/geotools/gt/plugin/tiger/src/org/geotools/data/tiger/TigerDataStoreFactory.java uses or overrides a deprecated API.
4 errors
| Building Plugin geotools-vpf
| Memory: 45M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-vpf' is not available
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/vpf/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/vpf/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/vpf/target/classes
    [javac] Compiling 54 source files to /home/autorun/cvs/geotools/gt/plugin/vpf/target/classes
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/plugin/vpf/target/classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/vpf/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/vpf/target/test-reports
Copying 4 files to /home/autorun/cvs/geotools/gt/plugin/vpf/target/test-classes
test:compile:
    [javac] Compiling 7 source files to /home/autorun/cvs/geotools/gt/plugin/vpf/target/test-classes
test:test:
    [junit] Running org.geotools.data.vpf.io.TableColumnDefTest
    [junit] Tests run: 10, Failures: 0, Errors: 0, Time elapsed: 0.773 sec
    [junit] Running org.geotools.data.vpf.io.TableRowTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.726 sec
    [junit] Running org.geotools.data.vpf.io.TableHeaderTest
    [junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 0.754 sec
    [junit] Running org.geotools.data.vpf.io.TableInputStreamTest
    [junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 0.804 sec
    [junit] Running org.geotools.data.vpf.io.RowFieldTest
    [junit] Tests run: 8, Failures: 0, Errors: 0, Time elapsed: 0.71 sec
    [junit] Running org.geotools.data.vpf.io.VPFDateTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.783 sec
    [junit] Running org.geotools.data.vpf.util.DataUtilsTest
    [junit] Tests run: 7, Failures: 0, Errors: 1, Time elapsed: 0.705 sec
    [junit] [ERROR] TEST org.geotools.data.vpf.util.DataUtilsTest FAILED
| Building Plugin geotools-gtopo30
| Memory: 55M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-gtopo30' is not available
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/plugin/gtopo30/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/classes
    [javac] Compiling 4 source files to /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/classes
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/test-reports
Copying 7 files to /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/test-classes
test:compile:
    [javac] Compiling 6 source files to /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/test-classes
Note: /home/autorun/cvs/geotools/gt/plugin/gtopo30/test/org/geotools/data/gtopo30/ServiceTest.java uses or overrides a deprecated API.
test:test:
    [junit] Running org.geotools.data.gtopo30.ServiceTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.907 sec
    [junit] Running org.geotools.data.gtopo30.GT30DemTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 4.681 sec
    [junit] Running org.geotools.data.gtopo30.GT30HeaderTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.725 sec
    [junit] Running org.geotools.data.gtopo30.GT30StatTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.746 sec
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/plugin/gtopo30/target/gtopo30-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/plugin/gtopo30/target/gtopo30-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/gtopo30-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/plugin/gtopo30/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/gtopo30-2.1.x.pom'
jar:install:
mergeTestReports:
| Building Plugin geotools-arcgrid
| Memory: 35M/59M
Attempting to download view-2.1.x.jar.
WARNING: Failed to download view-2.1.x.jar.
geotools-graph
geotools-reprojection
geotools-j2se-demos
geotools-validation
geotools-view
geotools-legend
| Building geotools-graph
| Memory: 32M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-graph' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/ext/graph/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/graph/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/ext/graph/target/classes
    [javac] Compiling 95 source files to /home/autorun/cvs/geotools/gt/ext/graph/target/classes
java:jar-resources:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/graph/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/graph/target/test-reports
test:compile:
    [javac] Compiling 46 source files to /home/autorun/cvs/geotools/gt/ext/graph/target/test-classes
test:test:
    [junit] Running org.geotools.graph.build.basic.BasicGraphBuilderTest
    [junit] Tests run: 11, Failures: 0, Errors: 0, Time elapsed: 0.731 sec
    [junit] Running org.geotools.graph.build.basic.BasicDirectedGraphBuilderTest
    [junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 0.729 sec
    [junit] Running org.geotools.graph.build.opt.OptDirectedGraphBuilderTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.729 sec
    [junit] Running org.geotools.graph.build.opt.OptGraphBuilderTest
    [junit] Tests run: 9, Failures: 0, Errors: 0, Time elapsed: 0.715 sec
    [junit] Running org.geotools.graph.io.standard.OptDirectedGraphSerializerTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.931 sec
    [junit] Running org.geotools.graph.io.standard.DirectedGraphSerializerTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 1.023 sec
    [junit] Running org.geotools.graph.io.standard.BasicGraphSerializerTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.988 sec
    [junit] Running org.geotools.graph.io.standard.OptGraphSerializerTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.932 sec
    [junit] Running org.geotools.graph.structure.basic.BasicGraphableTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.699 sec
    [junit] Running org.geotools.graph.structure.basic.BasicGraphTest
    [junit] Tests run: 11, Failures: 0, Errors: 0, Time elapsed: 0.734 sec
    [junit] Running org.geotools.graph.structure.basic.BasicEdgeTest
    [junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 0.707 sec
    [junit] Running org.geotools.graph.structure.basic.BasicNodeTest
    [junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 0.709 sec
    [junit] Running org.geotools.graph.structure.basic.BasicDirectedEdgeTest
    [junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.763 sec
    [junit] Running org.geotools.graph.structure.basic.BasicDirectedNodeTest
    [junit] Tests run: 20, Failures: 0, Errors: 0, Time elapsed: 0.724 sec
    [junit] Running org.geotools.graph.structure.opt.OptEdgeTest
    [junit] Tests run: 6, Failures: 0, Errors: 0, Time elapsed: 0.723 sec
    [junit] Running org.geotools.graph.structure.opt.OptNodeTest
    [junit] Running org.geotools.graph.structure.opt.OptDirectedEdgeTest
    [junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.708 sec
    [junit] Running org.geotools.graph.structure.opt.OptDirectedNodeTest
    [junit] Tests run: 20, Failures: 0, Errors: 0, Time elapsed: 0.721 sec
    [junit] Running org.geotools.graph.linegraph.OptLineGraphGeneratorTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.76 sec
    [junit] Running org.geotools.graph.linegraph.LineGraphGeneratorTest
    [junit] Running org.geotools.graph.linegraph.OptDirectedLineGraphGeneratorTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.779 sec
    [junit] Running org.geotools.graph.linegraph.DirectedLineGraphGeneratorTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.762 sec
    [junit] Running org.geotools.graph.traverse.standard.DepthFirstTopologicalIteratorTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.763 sec
    [junit] Running org.geotools.graph.traverse.standard.DijkstraIteratorTest
    [junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.847 sec
    [junit] Running org.geotools.graph.traverse.standard.DepthFirstIteratorTest
    [junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.787 sec
    [junit] Running org.geotools.graph.traverse.standard.BreadthFirstTopologicalIteratorTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.748 sec
    [junit] Running org.geotools.graph.traverse.standard.DirectedDepthFirstIteratorTest
    [junit] Tests run: 8, Failures: 0, Errors: 0, Time elapsed: 0.804 sec
    [junit] Running org.geotools.graph.traverse.standard.BreadthFirstIteratorTest
    [junit] Tests run: 7, Failures: 0, Errors: 0, Time elapsed: 0.783 sec
    [junit] Running org.geotools.graph.traverse.standard.NoBifurcationIteratorTest
    [junit] Tests run: 5, Failures: 0, Errors: 0, Time elapsed: 0.77 sec
    [junit] Running org.geotools.graph.traverse.basic.SimpleGraphWalkerTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.708 sec
    [junit] Running org.geotools.graph.path.WalkTest
    [junit] Tests run: 8, Failures: 0, Errors: 0, Time elapsed: 0.792 sec
    [junit] Running org.geotools.graph.util.GraphPartitionerTest
    [junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 0.78 sec
    [junit] Running org.geotools.graph.util.GraphFuserTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 0.842 sec
    [junit] Running org.geotools.graph.util.CycleDetectorTest
    [junit] Running org.geotools.graph.util.DijkstraShortestPathFinderTest
    [junit] Tests run: 3, Failures: 0, Errors: 0, Time elapsed: 0.784 sec
    [copy] Copying 35 files to /home/autorun/cvs/geotools/gt/target/test-reports
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/ext/graph/target/graph-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/ext/graph/target/graph-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/graph-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/ext/graph/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/graph-2.1.x.pom'
jar:install:
mergeTestReports:
| Building geotools-reprojection
| Memory: 47M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-reprojection' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/ext/reprojection/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/reprojection/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/ext/reprojection/target/classes
    [javac] Compiling 3 source files to /home/autorun/cvs/geotools/gt/ext/reprojection/target/classes
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/ext/reprojection/target/classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/reprojection/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/reprojection/target/test-reports
test:compile:
    [javac] Compiling 1 source file to /home/autorun/cvs/geotools/gt/ext/reprojection/target/test-classes
Note: /home/autorun/cvs/geotools/gt/ext/reprojection/test/org/geotools/reprojection/ReprojectionServiceTest.java uses or overrides a deprecated API.
test:test:
    [junit] Running org.geotools.reprojection.ReprojectionServiceTest
    [junit] Tests run: 4, Failures: 0, Errors: 0, Time elapsed: 1.378 sec
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/ext/reprojection/target/reprojection-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/ext/reprojection/target/reprojection-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/reprojection-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/ext/reprojection/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/reprojection-2.1.x.pom'
jar:install:
mergeTestReports:
| Building geotools-j2se-demos
| Memory: 55M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-j2se-demos' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/ext/j2se-demos/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/j2se-demos/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/ext/j2se-demos/target/classes
    [javac] Compiling 8 source files to /home/autorun/cvs/geotools/gt/ext/j2se-demos/target/classes
Note: /home/autorun/cvs/geotools/gt/ext/j2se-demos/src/org/geotools/data/property/PropertyDataStoreFactory.java uses or overrides a deprecated API.
java:jar-resources:
Copying 1 file to /home/autorun/cvs/geotools/gt/ext/j2se-demos/target/classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/j2se-demos/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/j2se-demos/target/test-reports
test:compile:
test:test:
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/ext/j2se-demos/target/j2se-demos-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/ext/j2se-demos/target/j2se-demos-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/j2se-demos-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/ext/j2se-demos/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/j2se-demos-2.1.x.pom'
jar:install:
mergeTestReports:
| Building geotools-validation
| Memory: 31M/59M
Attempting to download dir_ds-2.1.x.jar.
WARNING: Failed to download dir_ds-2.1.x.jar.
| Building geotools-view
| Memory: 28M/59M
Plugin 'maven-deploy-plugin' in project 'geotools-view' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/ext/view/target
clean:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/view/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/ext/view/target/classes
java:jar-resources:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/view/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/view/target/test-reports
test:compile:
test:test:
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/ext/view/target/view-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/ext/view/target/view-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/view-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/ext/view/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/view-2.1.x.pom'
jar:install:
mergeTestReports:
| Building geotools-legend
| Memory: 32M/59M
Attempting to download geoapi-SNAPSHOT.jar.
Plugin 'maven-deploy-plugin' in project 'geotools-legend' is not available
build:end:
build:start:
build:log:
clean:clean:
    [delete] Deleting directory /home/autorun/cvs/geotools/gt/ext/legend/target
clean:
java:prepare-filesystem:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/legend/target/classes
java:compile:
    [echo] Compiling to /home/autorun/cvs/geotools/gt/ext/legend/target/classes
    [javac] Compiling 80 source files to /home/autorun/cvs/geotools/gt/ext/legend/target/classes
Note: /home/autorun/cvs/geotools/gt/ext/legend/src/org/geotools/renderer/LegendIconMaker.java uses or overrides a deprecated API.
Note: Recompile with -deprecation for details.
java:jar-resources:
test:prepare-filesystem:
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/legend/target/test-classes
    [mkdir] Created dir: /home/autorun/cvs/geotools/gt/ext/legend/target/test-reports
test:test-resources:
Copying 14 files to /home/autorun/cvs/geotools/gt/ext/legend/target/test-classes
test:compile:
    [javac] Compiling 2 source files to /home/autorun/cvs/geotools/gt/ext/legend/target/test-classes
Note: Some input files use or override a deprecated API.
test:test:
    [junit] Running org.geotools.gui.swing.LegendEditorTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 2.681 sec
    [junit] Running org.geotools.gui.swing.LegendTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 4.088 sec
jar:jar:
    [jar] Building jar: /home/autorun/cvs/geotools/gt/ext/legend/target/legend-2.1.x.jar
Copying: from '/home/autorun/cvs/geotools/gt/ext/legend/target/legend-2.1.x.jar' to: '/home/autorun/.maven/repository/gt2/jars/legend-2.1.x.jar'
Copying: from '/home/autorun/cvs/geotools/gt/ext/legend/project.xml' to: '/home/autorun/.maven/repository/gt2/poms/legend-2.1.x.pom'
jar:install:
mergeTestReports:
build:end:
    [echo] BUILD REPORT (from buildReport.txt):
  Sucessfull modules should read 'cleaned, compiled, tested, INSTALLED HHMM'
      GeoTools2 module build report 20040809
    gt2:main cleaned, compiled, tested, INSTALLED 0928
    gt2:utils cleaned, compiled, tested, INSTALLED 0928
    gt2:rendering-styling cleaned, compiled, tested, INSTALLED 0930
    gt2:pickle cleaned, compiled, tested, INSTALLED 0930
    gt2:sample-data cleaned, compiled, tested, INSTALLED 0930
    gt2:mapinfo cleaned, compiled, tested, INSTALLED 0930
    gt2:svgsupport cleaned, compiled, tested, INSTALLED 0930
    gt2:gml cleaned
    gt2:shapefile cleaned, compiled, tested, INSTALLED 0931
    gt2:arcsde cleaned, compiled, tested, INSTALLED 0931
    gt2:image cleaned, compiled, tested, INSTALLED 0931
    gt2:oracle-spatial cleaned, compiled, tested, INSTALLED 0931
    gt2:mysql cleaned, compiled, tested, INSTALLED 0931
    gt2:wms cleaned, compiled, tested, INSTALLED 0932
    gt2:postgis cleaned, compiled, tested, INSTALLED 0932
    gt2:geomedia cleaned, compiled, tested, INSTALLED 0932
    gt2:tiger cleaned
    gt2:vpf cleaned, compiled
    gt2:gtopo30 cleaned, compiled, tested, INSTALLED 0932
    gt2:graph cleaned, compiled, tested, INSTALLED 0933
    gt2:reprojection cleaned, compiled, tested, INSTALLED 0933
    gt2:j2se-demos cleaned, compiled, tested, INSTALLED 0934
    gt2:view cleaned, compiled, tested, INSTALLED 0934
    gt2:legend cleaned, compiled, tested, INSTALLED 0934
  If some modules failed to INSTALL, look for problems from the TOP DOWN as
  failures lower in the list will probaly be caused by ones higher up.
  If modules cleanded and compiled but were not tested look in the
  /target/test-reports direcotry of your module for details.
  You can debug problems from the module directory using 'maven java:compile',
  'maven test' and 'maven jar:install'.
  These build results are available in buildResults.txt
  Maven always says 'Build Sucessful', please check the above report.
      BUILD SUCCESSFUL
Total time: 12 minutes 51 seconds
Finished at: Mon Aug 09 09:34:20 PDT 2004
