Looks like we are having a similar problem with 17.x. Perhaps there is something special about 1st-time builds that consumes more memory than usual?
Torben
On Fri, Oct 14, 2016 at 6:22 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Success! Build #3 passed without any extra JVM args. Was the extra
memory really needed? A mystery.On 15/10/16 12:44, Ben Caradoc-Davies wrote:
This fixed the build. We have some new commits on 16.x, so I have undone
this change to see if the deploy step passes without it.On 15/10/16 10:00, Ben Caradoc-Davies wrote:
Failed in the deploy step. I set -Xmx1024m and kicked it. I seem to
recall that new builds sometimes require a little help (and more memory)
to get past the first build. We can then remove the JVM option.On 15/10/16 05:18, monitor@anonymised.com…3839… wrote:
See <http://ares.boundlessgeo.com/jenkins/job/geotools-16.x/1/>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
GeoTools-Devel mailing list
GeoTools-Devel@anonymised.com66…sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
