[Geoserver-devel] [Geotools-devel] GEOT-5329: Proposal to avoid Date-shifting due to Timezones
I have created a new pull request for this topic consisting of one commit only.
Regarding the GeoServer part (sort of cross-posting):
I will create a corresponding pull request. The GeoServer implementation (org.geoserver.wfs.xml.xs.DateBinding) is a subclass of the GeoTools implementation (org.geotools.xs.bindings.XSDateBinding, one of the classes changed by me). I see no reason for its existence. Maybe for historical reasons? I will just delete it and amend the registration code bringing it into play (org.geoserver.wfs.xml.v1_1_0.WFSConfiguration).
Ok?
Best regards,
Andreas
2016-02-15 9:30 GMT+01:00 Andrea Aime <andrea.aime@anonymised.com>:
On Mon, Feb 15, 2016 at 9:21 AM, Andreas Watermeyer <Andreas.Watermeyer@anonymised.com> wrote:
I am currently quite busy, but I really like to see this solved, too.
I also appreciate your support so I will give it a try right now.
I hope it will not break other things, so close before code freeze.
It would be nice if somebody somebody could help me if I have question
regarding the start up parameters.
It’s going to be a busy week for everybody (people wake up when they hear
“feature freeze” and suddenly remember those things they need to get in
since a months ago :-p), but ask away, we’ll see what we can do :slight_smile:
now) we should revert, otherwise if it does… should your patch be
controlled
by the same system hint?
Yes, I will also provide a PR for that issue, introducing the same
guard condition.
I suppose a new SNAPSHOT of GT has to be available in order to be able
to use the new constant in GS.
Is a new SNAPSHOT released every night? Is it possible to release a
SNAPSHOT manually?
Nightly builds are released daily out of code already merged into the branch.
But also feel free to build a snapshot of yours and make it available for
download for others to try out
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Andreas Watermeyer
office: +49 (0)221 820 07 14
ITS Telco Services GmbH
GIS Services & Solutions
Telecommunications Division
Dillenburger Str. 77
D-51105 Köln
Tel.: +49 (0)221 820 07 00
Fax : +49 (0)221 820 07 22
Mail: info@anonymised.com
Web : http://www.its-telco.de
Sitz der Gesellschaft: Köln
Amtsgericht Köln, HRB 59310
Geschäftsführer: Gunnar Haack, Ralf Petersilka, Michael Schnepf, Kai Schriewer, Ludger Schulte
Diese E-Mail enthält vertrauliche Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
This e-mail may contain confidential information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail. Any unauthorised copying, disclosure or distribution of the material in this e-mail is strictly forbidden.
