I expect you wanted this for the geoserver-devel list
by all means filter the list of formats as appropriate for the layer being published.
On 22 September 2015 at 08:33, Stefano Costa <stefano.costa@anonymised.com> wrote:
Dear all,
I would like to hear your opinion on changing the behavior of the Layer Preview page’s GML links.As it is now, the GML link printed right next to the OpenLayers and KML links in the Common Formats column issues a WFS 1.0 request with no outputFormat parameter in it, which means GML2 is picked as output format.
How do you feel about having the GML link pick GML 3.2, or at least GML 3.1, as output format?
One good reason to do it, besides GML2 being ancient, is that Complex Features seem to break the GML2 encoder, so clicking on the GML link for any app-schema layer will result in the following exception:
java.lang.ClassCastException: org.geotools.feature.type.ComplexFeatureTypeImpl cannot be cast to org.opengis.feature.simple.SimpleFeatureType org.geotools.feature.type.ComplexFeatureTypeImpl cannot be cast to org.opengis.feature.simple.SimpleFeatureType
Do you see any drawbacks in making GML3 the default?
Best regards, Stefano Costa == GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information. == Dott. Stefano Costa Senior Software Engineer GeoSolutions S.A.S. Via Poggio alle Viti 1187 55054 Massarosa (LU) Italy phone: +39 0584 962313 fax: +39 0584 1660272 [http://www.geo-solutions.it](http://www.geo-solutions.it) [http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it) ------------------------------------------------------- AVVERTENZE AI SENSI DEL D.Lgs. 196/2003 Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003. The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
GeoTools-Devel mailing list
GeoTools-Devel@anonymised.coms.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Jody Garnett
