On Windows the system page seems to query the temperature again and again, even by the message text that is not the meaning.
20 marrask. 16:38:02 WARN [windows.WmiQueryHandler] - COM exception querying MSAcpi_ThermalZoneTemperature, which might not be on your system. Will not attempt to query it again. Error was -2147217405: Failed to enumerate results.
20 marrask. 16:38:10 WARN [windows.WmiQueryHandler] - COM exception querying MSAcpi_ThermalZoneTemperature, which might not be on your system. Will not attempt to query it again. Error was -2147217405: Failed to enumerate results.
For the paging file skipping is successful and utility makes just one failing request.
-Jukka-
Lähettäjä: Ian Turton <ijturton@…403…>
Lähetetty: perjantai 20. marraskuuta 2020 16.30
Vastaanottaja: Jody Garnett <jody.garnett@…403…>
Kopio: Geoserver-devel geoserver-devel@lists.sourceforge.net; Geotools-Devel list geotools-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] [Geotools-devel] Starting the Release for GeoServer 2.18.1 / GeoTools 24.1
I’m seeing a lot of warnings about “2020-11-20 14:27:16,927 WARN [linux.LinuxFileSystem] - Failed to get information to use statvfs. path: /media/ian/windows10vm, Error code: 13” when looking at the system status pages but nothing else obviously wrong.
Ian
On Fri, 20 Nov 2020 at 07:57, Jody Garnett <jody.garnett@…403…> wrote:
Alessandro:
All good so far: tested bin download and docs, with ysld extension.
Noticed one odd thing, probably not new? When visiting the server status page the logs are filled up with a block of INFO:
INFO: ===============================================================================
INFO: Marlin software rasterizer = ENABLED
INFO: Version = [marlin-0.9.3-Unsafe]
INFO: sun.java2d.renderer = org.marlin.pisces.MarlinRenderingEngine
INFO: sun.java2d.renderer.useThreadLocal = true
INFO: sun.java2d.renderer.useRef = soft
INFO: sun.java2d.renderer.edges = 4096
INFO: sun.java2d.renderer.pixelWidth = 4096
INFO: sun.java2d.renderer.pixelHeight = 2176
Importantly the System Status information is working correctly, this was not the case for 2.18.0 on macOS 11.
Thanks for making the release!
aside: I have an additional “state of geoserver” presentation to share for the release announcements
Jody Garnett
On Thu, 19 Nov 2020 at 09:22, Alessandro Parma <alessandro.parma@…1268…> wrote:
Hi All, Jody
Artifacts are available for testing here any feedback is welcome.
On Wed, Nov 18, 2020 at 9:10 AM Alessandro Parma <alessandro.parma@…1268…> wrote:
Hi All,
Just to let you know that I’m starting the release procedure for
GeoServer 2.18.1
GeoWebCache 1.18.1
GeoTools 24.1
I’ll keep you posted on the progress
Alessandro Parma
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.Alessandro Parma
DevOps EngineerGeoSolutions S.A.S.
Via di Montramito 3/A
fax: +39 0584 1660272http://www.geo-solutions.it
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Alessandro Parma
GeoTools-Devel mailing list
GeoTools-Devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Ian Turton
