[Geoserver-devel] [Geotools-devel] Suggesting some change on epsg extension and fallback mechanism
Martin Desruisseaux ha scritto:
I just noticed the following page:
http://docs.codehaus.org/display/GEOSDOC/Custom+projection+definition+in+Geoserver+1.5.0+(onwards)
Since Geoserver 1.5 searchs for "epsg.properties" file into the "$datadir/user_projections" directory, should we define a system property to be used by FactoryUsingWKT in order to search in a particular directory? The "org/geotools/referencing/factory/epsg" directory would be the default if no system property was found. It would avoid the need to create a subclass in Geoserver, and provide a common hook for Geoserver and uDig.
Hum... in Geoserver I really have a fall back property file in the classpath (used when there is none provided by the user, and equal to the one included in epsg-extensions), so lookup is a little more complex. But yeah, in general that seems a good idea.
As a side note, would "$datadir/user_crs" be a better directory name than "$datadir/user_projections"? ProjectedCRS is just a particular kind of CRS, and "projection" has yet an other meaning in ISO 19111.
You're right, user_crs should be a better one. We would have to update
code and docs. Cc'ing geoserver devel to gather more feedback.
