[Geoserver-devel] [Geotools-devel] WFS bug?
Kick ass! :slight_smile: It works in uDig now. I’ve tested Geoserver 1.7.5 and DM Solutions demo mapserver. Thanks for the quick fix.
Jesse
On Thu, Jul 30, 2009 at 2:06 PM, Jesse Eichar <jesse.eichar@anonymised.com> wrote:
THanks I will try it out right now
Jesse
On Thu, Jul 30, 2009 at 2:00 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
Hi Jesse,
as I suspected, the namespace URI were being set as the schemaLocation instead of the DescribeFT URL.
I’ve committed on trunk for http://jira.codehaus.org/browse/GEOT-2640. Tell me when you have a chance to try it out. You’ll have to build gt-wfs and update it on udig.
Gabriel
Jesse Eichar wrote:
Yes I got the exception in uDig. I am just letting you know how to setup the environment that I used. I was using uDig trunk straight from the repo.
Jesse
On Thu, Jul 30, 2009 at 12:57 PM, Gabriel Roldan <groldan@anonymised.com mailto:[groldan@anonymised.com](mailto:groldan@anonymised.com)> wrote:
But you got the exception in udig right?
Jesse Eichar wrote:
Hi Grabriel, The Geoserver I used was directly downloaded and
started. Absolutely no configuration done at all. Just the
default geoserver 1.7.5
Jesse
On Thu, Jul 30, 2009 at 12:05 PM, Gabriel Roldan
<groldan@anonymised.com mailto:[groldan@anonymised.com](mailto:groldan@anonymised.com.1501...)
<mailto:groldan@anonymised.com mailto:[groldan@anonymised.com](mailto:groldan@anonymised.com)>> wrote:
I’ve seen that before. Guess it’s a bug in the WFS datastore,
like
it’s setting the namespace URI as the FT schema location… I’ll
take a look and get back to you
Jesse Eichar wrote:
I tried uDig trunk out today and when I tried to load a
geoserver 1.7.5 WFS layer I got the exception listed
below. I
see a couple areas where things couple go wrong:
  1. Incorrect use of StreamingRenderer. No changes has taken
    place in the use of the streaming renderer as far as I know.
    Maybe some options were added that are required?
  2. Incorrect parameters for the WFS datastore. My
    params are:
    {WFSDataaStoreFactory:PROTOCOL=null,
    WFSDataStoreFactory:GET_CAPABILITIES_URL=http://localhost:8080/geoserver/wfs?VERSION=1.0.0&REQUEST=GetCapabilities&SERVICE=WFS&
    <http://localhost:8080/geoserver/wfs?VERSION=1.0.0&REQUEST=GetCapabilities&SERVICE=WFS&>
    <http://localhost:8080/geoserver/wfs?VERSION=1.0.0&REQUEST=GetCapabilities&SERVICE=WFS&>>
    <http://localhost:8080/geoserver/wfs?VERSION=1.0.0&REQUEST=GetCapabilities&SERVICE=WFS&>>>,
    WFSDataStoreFactory:TRY_GZIP=true,
    WFSDataStoreFactory:LENIENT=true} 3. There is an error in
    WFSDatastore
Any ideas if I am doing something wrong or if has been a
regression in the WFSDatastore?
Jesse
Exception is:
java.lang.Exception: Error rendering feature
at
org.geotools.renderer.lite.StreamingRenderer.drawOptimized(StreamingRenderer.java:1815)
at
org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1725)
at
org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:670)
at
org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:502)
at
net.refractions.udig.render.internal.feature.basic.BasicFeatureRenderer.render(BasicFeatureRenderer.java:331)
at
net.refractions.udig.render.internal.feature.basic.BasicFeatureRenderer.render(BasicFeatureRenderer.java:203)
at
net.refractions.udig.project.internal.render.impl.RenderJob.startRendering(RenderJob.java:108)
at
net.refractions.udig.project.internal.render.impl.RenderJob.run(RenderJob.java:213)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Caused by: java.util.NoSuchElementException: Could not aquire
feature:java.io.IOException: java.io.FileNotFoundException:
http://openplans.org/spearfish
at
org.geotools.data.store.NoContentIterator.next(NoContentIterator.java:56)
at
org.geotools.data.store.NoContentIterator.next(NoContentIterator.java:41)
at
org.geotools.renderer.lite.StreamingRenderer.drawOptimized(StreamingRenderer.java:1807)
… 8 more
Caused by: java.io.IOException:
at org.geotools.xml.gml.FCBuffer.hasNext(FCBuffer.java:326)
at
org.geotools.data.wfs.v1_0_0.WFSFeatureReader.loadElement(WFSFeatureReader.java:189)
at
org.geotools.data.wfs.v1_0_0.WFSFeatureReader.hasNext(WFSFeatureReader.java:178)
at
org.geotools.data.ReTypeFeatureReader.hasNext(ReTypeFeatureReader.java:192)
at
org.geotools.data.wfs.v1_0_0.NonStrictWFSStrategy.createFeatureReaderGET(NonStrictWFSStrategy.java:134)
at
org.geotools.data.wfs.v1_0_0.NonStrictWFSStrategy.createFeatureReader(NonStrictWFSStrategy.java:101)
at
org.geotools.data.wfs.v1_0_0.NonStrictWFSStrategy.getFeatureReader(NonStrictWFSStrategy.java:72)
at
org.geotools.data.wfs.v1_0_0.WFS_1_0_0_DataStore.getFeatureReader(WFS_1_0_0_DataStore.java:729)
at
org.geotools.data.DefaultFeatureResults.reader(DefaultFeatureResults.java:210)
at
org.geotools.data.store.DataFeatureCollection.openIterator(DataFeatureCollection.java:229)
at
org.geotools.data.store.DataFeatureCollection.iterator(DataFeatureCollection.java:199)
at
org.geotools.renderer.lite.StreamingRenderer.drawOptimized(StreamingRenderer.java:1791)
… 8 more
Caused by: java.io.FileNotFoundException:
at
org.geotools.xml.SchemaFactory.getRealInstance(SchemaFactory.java:319)
at
org.geotools.xml.SchemaFactory.getInstance(SchemaFactory.java:277)
at
org.geotools.xml.handlers.ElementHandlerFactory.startPrefixMapping(ElementHandlerFactory.java:86)
at
org.geotools.xml.XMLSAXHandler.startElement(XMLSAXHandler.java:359)
at
org.apache.xerces.parsers.AbstractSAXParser.startElement(Unknown
Source)
at
org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanStartElement(Unknown
Source)
at
org.apache.xerces.impl.XMLNSDocumentScannerImpl$NSContentDispatcher.scanRootElementHook(Unknown
Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown
Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown
Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown
Source)
Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at
org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at
org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown
Source)
at org.apache.xerces.jaxp.SAXParserImpl.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:176)
at
org.geotools.xml.DocumentFactory.getInstance(DocumentFactory.java:140)
at
org.geotools.data.wfs.v1_0_0.WFSFeatureReader.run(WFSFeatureReader.java:125)
at
sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1185)
at
org.apache.xerces.impl.XMLEntityManager.setupCurrentEntity(Unknown
Source)
at
org.apache.xerces.impl.XMLVersionDetector.determineDocVersion(Unknown
Source)
Source)
Source)
at
at
Source)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:255)
at
org.geotools.xml.SchemaFactory.getRealInstance(SchemaFactory.java:317)
… 17 more
net.refractions.udig.project.render.RenderException: Problem
rendering: Error rendering feature
at
net.refractions.udig.render.internal.feature.basic.BasicFeatureRenderer.render(BasicFeatureRenderer.java:359)
at
at
at
Caused by: java.lang.Exception: Error rendering feature
at
at
at
at
at
… 4 more
at
at
at
… 8 more
at
at
at
at
at
at
at
at
at
at
at
… 8 more
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
Source)
at
at
Source)
at
at
at
at
Source)
at
Source)
Source)
Source)
at
at
Source)
at
… 17 more
Let Crystal Reports handle the reporting - Free Crystal
Reports
2008 30-Day trial. Simplify your report design,
integration and
deployment - and focus on what you do best, core application
coding. Discover what’s new with Crystal Reports now.
http://p.sf.net/sfu/bobj-july
Geotools-devel mailing list
Geotools-devel@anonymised.comeforge.net
mailto:[Geotools-devel@lists.sourceforge.net](mailto:Geotools-devel@anonymised.comts.sourceforge.net)
<mailto:Geotools-devel@lists.sourceforge.net
mailto:[Geotools-devel@lists.sourceforge.net](mailto:Geotools-devel@anonymised.comts.sourceforge.net)>
https://lists.sourceforge.net/lists/listinfo/geotools-devel
