GeoTools / GeoServer Meeting 2012-10-29
Participants
- Alessio Fabiani
- Andrea Aime
- Ben Caradoc-Davies
- Justin Deoliveira
- Jody Garnett
Agenda
* OpenJDK 7 build server (yay!)
* WMS Client Conformance Testing
* GeoTools 9.0-M0 release
* Timed release (GSIP 77) policy refinements, move to sphinx?
* GeoPackage / sqlite / jdeolive hint hint
* FeatureCollection thing is at 377 errors (so likely to finish up)
* Dropping xerces (and friends)
* User list report
* geoserver-extra-builds
* geotools-extra-builds
AA: ml page, add the two above
JG: list build servers here http://docs.codehaus.org/display/GEOTOOLS/Home (done!)
- windows build server: office.geo-solutions.it/jenkins/
- OpenJDK 7: http://aaime.no-ip.org/jenkins/
- Sonar: http://aaime.no-ip.org/sonar/
OWS9, WMS 1.3.0 CITE tests for clients.
Client talking to proxy which checks, interactive.
Geotools WMS client and uDig reference
Jody will provide some info about the results (issues, reports, something)
Once GetFeatureInfo fixed, run scripts to do the release (using the scripts for master, mind!)
* Stable: "new minor core functionality" -> "new minor non-core functionality"?
* For maintenance, should the timed release policy be in sphinx?
* Backports of core changes in first two weeks to evaluate and detect regressions.
AA: put the document in sphinx (Andrea Aime)
No requirements on spatialite at the moment at the moment,
sql-lite natively index geometries?
Store tile pyramids and vector data in a package
Known issues win win64 build of drivers
FeatureCollection thing is at 354 errors (so likely to finish up)
Likely to finish this week:
- https://github.com/geotools/geotools/tree/featurecollection_cleanup
- https://github.com/geotools/geotools/blob/featurecollection_cleanup/modules/library/api/src/main/java/org/geotools/feature/FeatureCollection.java
Is anyone ready?
a) Use ListFeatureCollection if add is required
b) Use FeatureIterator is iterator.close() is required
Seems like lots of manual work without much of a fuss.
Make a GeoServer branch so that things get fixed
Justin: cleaning up the explicit deps on Xerces using the one in the JDK
Last issue: app-schema resolver. Ben?
app-schema-resolver: move validation support to test and port to new non-xerces api - BCD/RA (and Justin to send draft patch to Ben)
Other? JDOM, streaming parsers, Xalan
WPS/CSW uses xalan-serializer out of laziness
4th dimension / Measures Coordinates JDBC PostGIS / Oracle
- Andrea did support for 2.5 D (more general)
- Justin patched for measures
Oracle
- Martin did work to support 2.5 D
- SDO needs patching for measures, but missing SDOTest and Implementation
- Niels / Ben has instructions for how to set up 3D test fixture for app-schema
From the user list
user list topics: no evidence on something being generally wrong
mostly one question per issue but a few with more entries:
* various SLD questions
* app-schema stuff
* REST configuration problems
* OpenLayers troubles, mostly off-topic
Next meeting: Monday 12 November 2012, 13:00 UTC
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
