[Geoserver-devel] GeoTools / GeoServer Meeting 2013-10-14
Attending
Ben Caradoc-Davies
Andrea Aime
Jukka Rahkonen
Jody Garnett
Alessio Fabiani
Agenda
- Release 10.1/2.4.1
- CITE breakage
- Shape "ng" and Tutorials
- OSGeo Update
- FOSS4G followup
Actions:
- update develoepers guide with list of build servers :slight_smile:
Release 10.1/2.4.1
Q: Is this the first release on new build server?
A: No 2.4.0 was released by Justin on new build server.
Q: GeoWebCache?
A: Use 1.5.0-beta release?
   Upgrade to 1.5.0 final? What changes are there?
Schedule:
- Wednesday GeoTools
- Thursday GeoServer
- Anouncement Friday 18th as per scehdule
CITE breakage
Q: Held up CITE breakage?
A: Seem it has not been run in 26 days, perhaps not configured correctly
2.4-cite-all triggers the other builds, but it does not have a build trigger itself -> How to fix? Once a day, or triggered by the nightly build maybe?
Something is up, details pending bug report from user list?
https://jira.codehaus.org/browse/GEOT-4595
(will have a look next weekend)
Q: Can tutorials be run as a unit test?
A: Perhaps we can run a regression test, ie pipe the output to a string and check against expected output?
OSGeo Update
There ia board meeting Friday?
Q: Anything for the GeoTools?
A: Nope ...
Q: Anything for GeoServer?
A: Nope ...
Related questions from mailing list:
- collaboration of companies. Yep - sign as normal.
- use in thesis - normal LGPL use have fun
FOSS4G followup
Andrea/Jody record again the presentation?
A: happy that the slides are up ..
Ben wanted a link to http://blog.cleverelephant.ca/2013/10/being-open-source-citizen.html
Presentations mentioning GeoServer: http://2013.foss4g.org/conf/programme/search/?q=geoserver
Chat and Communication
Blog posts:
- http://blog.geoserver.org/2013/10/02/geoserver-foss4g-2013/
- http://blog.geoserver.org/2013/10/02/geoserver-2-4-0-release-highlights/
- http://geotoolsnews.blogspot.com.au/2013/10/randomized-fill.html
- http://geotools.org <-- still does not list blogs :frowning:
Conversations
- Importer see email list, waiting on final REST API
- WCS 2.0 is ready - need time to write the proposal
- PNG Speed up - pretty impressive
- image mosaic, sidecar file to describe footprint with out an alpha channel
- Jody reports Boulder NetCDF crew (Unidata) interested in Andrea's NetCDF work (please talk to us)
- Some questions on users mailing list on 2.4 upgrades, not many have upgraded?
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
As discussed at Monday's meeting.
On 14/10/13 21:43, Ben.Caradoc-Davies@anonymised.com wrote:
Q: GeoWebCache?
Software Engineer
On Mon, Oct 14, 2013 at 7:15 PM, Ben Caradoc-Davies <
> Q: GeoWebCache?
As far as I know there were no changes between 1.5-beta and 1.5.0, although
Kevin can confirm. Regardless I would think that 2.4.x should change 1.5.0
or 1.5-SNAPSHOT.
Software Engineer
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most
from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60135031&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
*Justin Deoliveira*
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive <https://twitter.com/j_deolive&gt;
Both are master and 2.4.x now using gwc 1.5.0; I am comfortable with having a snapshot dependency on master, but I would like to avoid it on stable.
Kind regards,
Ben.
although Kevin can confirm. Regardless I would think that 2.4.x should
change 1.5.0 or 1.5-SNAPSHOT.
Software Engineer
Justin,
another issue that came up at Monday's meeting is the CITE test breakage and lack of triggers for the jobs. I have been kicking them manually but still encountering some failures (looks like a Jenkins problem not a config). Also do you have any opinion about the best approach for triggering (see below)?
Kind regards,
Ben.
CITE breakage
Software Engineer
On Mon, Oct 14, 2013 at 8:00 PM, Ben Caradoc-Davies <
stable.
Agreed, I would say hold off moving to a snapshot until it is necessary to
do so due to active development of gwc and geoserver that needs to happen
in conjunction.
Kind regards,
Ben.
Software Engineer
*Justin Deoliveira*
Yeah, I noticed the cite jobs are failing, my guess is that i didn’t set up the new server properly. It is on my list to look into. I’ll try to do that soon in the next few days.
As for the job trigger, i would say a simple nightly trigger should do?
On Mon, Oct 14, 2013 at 8:06 PM, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com.> wrote:
Justin,
another issue that came up at Monday’s meeting is the CITE test breakage and lack of triggers for the jobs. I have been kicking them manually but still encountering some failures (looks like a Jenkins problem not a config). Also do you have any opinion about the best approach for triggering (see below)?
Kind regards,
Ben.
CITE breakage
2.4-cite-all triggers the other builds, but it does not have a build trigger itself → How to fix? Once a day, or triggered by the nightly build maybe?
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
Justin Deoliveira
@j_deolive
<Ben.Caradoc-Davies@anonymised.com <mailto:Ben.Caradoc-Davies@anonymised.com>> wrote:
    on stable.
to do so due to active development of gwc and geoserver that needs to
happen in conjunction.
Agreed. We had a bad time with Gabriel and Kevin away, but with their active engagement we should be able to address any integration problems that arise from master depending on a GWC SNAPSHOT.
Kind regards,
Software Engineer
On 15/10/13 10:08, Justin Deoliveira wrote:
Yeah, I noticed the cite jobs are failing, my guess is that i didn't set
up the new server properly. It is on my list to look into. I'll try to
That would be great! CITE failures are blocking the release train; I hope to release GT 10.1 on Wednesday (my tomorrow, your day after tomorrow) and GS 2.4.1 on Thursday, with announcements on Friday as scheduled.
Yes, please! release manager can always kick as required. A regular nightly trigger will keep us honest. :slight_smile:
Kind regards,
Software Engineer
On Mon, Oct 14, 2013 at 8:13 PM, Ben Caradoc-Davies <
Well folks are also encouraged to run the tests locally as well. All it
takes is cloning this repo:
  https://github.com/geoserver/geoserver-cite-tools
And following the instructions in the readme.
I am seeing some issues on the build server with the wfs-1.1 tests... they
seem to be hanging at the end of the test run. Will try to dig deeper
tomorrow.
Triggers set.
Kind regards,
Software Engineer
*Justin Deoliveira*
Right, there were no changes from 1.5.0-beta to 1.5.0-final.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
Kevin Smith
Junior Software Engineer | Boundless
ksmith@anonymised.com
+1-778-785-7459
@boundlessgeo
On Mon, Oct 14, 2013 at 7:15 PM, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
As discussed at Monday’s meeting.
Q: GeoWebCache?
As far as I know there were no changes between 1.5-beta and 1.5.0, although Kevin can confirm. Regardless I would think that 2.4.x should change 1.5.0 or 1.5-SNAPSHOT.
Software Engineer
Justin Deoliveira
@j_deolive
