GeoTools / GeoServer Meeting 2013-11-26
Attending
Andrea Aime
Ben Caradoc-Davies
Jody Garnett
Alessio Fabiani
Jukka Rahkonen
Agenda
- New PNG encoder
- CAS plugin breakage in 2.4.1/2.4.2
- Bug fix code sprint
Actions:
- AA: Candidate list of fixes that should be easier to fix
New PNG encoder
Refer to discussion on the ml - GSIP to make the encoder as the default
Quick GSIP to cover changing the default encoding options, and double check tasks (docs etc...)
Discussion: adding to master as a non default option would not of required proposal.
Justin is the maintainer? But also way busy (Jody refers)
There is a patch in a ticket and a pull request (might re-introduce the web gui breakage though)
Code sprint
- December 6th (Ben and Simone busy) Tom was visible
- December 13th -> Andrea, Simone, Jody, Ben, Alessio
- December 20th (Ben away)
Notes:
- Ben wants to work on docs and demo requests
- Jukka may have a try with docs. Raster pre-processing --> tutorials!
Random Discussion
Q: layer identifiers?
No idea, is it in the docs?
Something to do with group layers, may be able to subst in group layer for root.
Q: monitor reports?
Not working for Jody out of the box, need to confirm with fresh install before reporting bugs.
Q: GetFeatureInfo work?
Andrea looking at making this pluggable, rather than current switch logic. (e.g. LayerIdentifier.canHandle)
Q: uDig and LocationTech?
uDig finished rename, will swap to 9.0-M1 next and squish remaining IP issues.
Update to a recent version of GeoTools sometime after that?
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
