[Geoserver-devel] GeoTools / GeoServer Meeting 2015-06-09
Attending
Ben Caradoc-Davies
Jody Garnett
Kevin Smith
Andrew Ross
Agenda
- Release 12.4 / 1.6.2 / 2.6.4
- GeoServer Dev Guide Change
- vecmath done - jai next?
- AppSchema Test Failures
- MongoDB DataStore
- Pull Request Roundup
Actions
- JG: Tag 14-M0 release in GitHub
- BCD: Release 12.4 / 1.6.2 / 2.6.4 next week! (thanks Ben)
- JG/BCD: Send PMC/PSC refresh emails to developer lists
- JG: follow up with gabriel about blob store pull request
- JG: MongoDB datastore request
- KS: kevin to follow up on pull request #707
Actions from last meeting
- Jody: Ask Niels and Christian to confirm their GeoFence REST API
approach and write a proposal if required [DONE]
Release GeoTools 12.4 / GeoWebCache 1.6.2 / GeoServer 2.6.4
- https://github.com/geoserver/geoserver/wiki/Release-Schedule
- Call for volunteers? Release is next week ... Ben!
- Kevin needs to release GWC 1.6.2 with a couple patches (tile cache fixes, backports and doc fixes)
Aside: Change to jira has a few hickups; and the 14-M0 release was not tagged in GitHub!
- https://github.com/geoserver/geoserver/wiki/GSIP-129
- Main change: Update the dev guide to remove reference to short / long term roadmap planning.
http://docs.geoserver.org/latest/en/developer/policies/psc.html
- Relax two months suggestion to six months to match geotools
- Would like to require a test case. currently we recommend it only.
Refresh the PSC Committee list. Ben/Jody will send to email list.
Jody will update GSIP-129 with the 6 month timeframe.
vecmath replacement is done, and delivered as part of 14-M0 / 2.8-M0 - yay! Great cross team effort :slight_smile:
Next up is JAI?
- we need to establish scope to determine what is needed
- we should issue a call for participation / fundraise a replacement
- Jody: Call for participation on GeoTools blog
- Andrew: Call for participation on LocationTech channels
http://ares.boundlessgeo.com/jenkins/view/geoserver/job/geoserver-master-app-schema-online/
Boundless has been unable to setup an Oracle to run 3D tests against?
https://osgeo-org.atlassian.net/browse/GEOS-7062
Can we disable these tests for the jenkins build?
Q: Can we disable by remove the oracle test fixture?
- BCD: yes, remove ~/.geoserver/oracle.properties and build with -pl '!app-schema-oracle-test'
- see https://osgeo-org.atlassian.net/browse/GEOS-6883
MongoDB DataStore
Boundless would like to donate MongoDB datastore as a geotools unsupported module.
Just a heads up, Jody will send an email request later in the week.
Kevin: Some JDBCConfig tests have been backported that have not been implemented. So master and 2.7.x are not building.
Jody: Good thing it is a community module so our build is still going :slight_smile: Do you want to mark them as @Ignore?
https://github.com/geoserver/geoserver/pull/1101
- ben will merge!
https://github.com/geoserver/geoserver/pull/1098
- jody can provide a quick review; but would like a second opinion :slight_smile:
https://github.com/geoserver/geoserver/pull/1095
- kevin exposing some new functionality in geoserver UI
- aaime will want to review this one
https://github.com/geoserver/geoserver/pull/1094
- waiting on test case
https://github.com/geoserver/geoserver/pull/1073
- looks like waiting on a response from groldan
- jody will follow up with gabriel
Many old pull requests should be closed (so they can be rebased etc...).
Example: https://github.com/geoserver/geoserver/pull/707
- kevin will follow up on this one :slight_smile:
https://github.com/geotools/geotools/pull/856
- remove gt-wfs module? waiting on aaime QA review of gt-wfs-ng
https://github.com/geotools/geotools/pull/808
https://github.com/geotools/geotools/pull/860
- ianturton and aaime are figuring this out on the email list!?
- give ianturton another week before closing 808?
https://github.com/geotools/geotools/pull/868
- bring in the new driver?
- Jody would like to see this merged ... I will ask on the mailing list.
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
