GeoTools / GeoServer Meeting 2015-07-07
Attending
Ben Caradoc-Davies
Jukka Rahkonen
Kevin Smith
Torben Barsballe
Agenda
- Security
- Pull requests
- ESRI WMS cascading problem
Actions
AA: Create Jira components Security (Authentication) and Security (Authorization) to replace Security
Actions from last meeting
AA: Create Security (Authentication) and Security (Authorization) to
replace Security [NOT DONE]
BCD: email user list: "SECURITY: Remote file disclosure vulnerability
[GEOS-7032]" [DONE]
BCD: add Vulnerability component to GeoServer Jira [DONE]
Security
- Discussion about our improved response to vulnerability reports
- Thanks to Torben for the fix for GEOS-7095!
Pull requests
Reviewed and merged:
refresh psc list (GSIP 129)
https://github.com/geoserver/geoserver/pull/1133
responsible disclosure (GSIP-129)
https://github.com/geoserver/geoserver/pull/1134
Clarification on our expectations for submitting fixes (GSIP 129)
https://github.com/geoserver/geoserver/pull/1135
Moved WCS 1.1 schema to GeoTools
https://github.com/geoserver/geoserver/pull/1129
[GEOS-7095] Fix for exploitable bypass for XXE fix
https://github.com/geoserver/geoserver/pull/1130
[GEOS-7102] Importer support for non-JDBC databases
https://github.com/geoserver/geoserver/pull/1136
developers guide tutorial review and cleanup (GSIP-129)
https://github.com/geoserver/geoserver/pull/1131
- Jukka, from the mapserver users list:
ESRI has decided not to follow the standard and has closed the bug, NIM104744, we submitted about not decoding a plus symbol ‘+’ to a space. Their solution is for everyone else to encode all spaces as %20 and to ignore http://tools.ietf.org/html/rfc3986. They have closed the bug and listed it as a known limit.
http://support.esri.com/en/bugs/nimbus/TklNMTA0NzQ0
So, in order for Mapserver to consume ESRI WMS services, with spaces in the name, the spaces have to be encoded as %20.
- Jukka noted that this can cause problems with cascading WMS
- Ben suggested adding a note to the user guide
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
