[Geoserver-devel] GeoTools / GeoServer Meeting 2015-08-04
Attending
Ben Caradoc-Davies
Jukka Rahkonen
Andrea Aime
Kevin Smith
Jody Garnett
Torben Barsballe
Agenda
- Release managers
- Code Freeze
- Proposals
- WCS 1.1 DescribeCoverage/GetCapabilities Question
- CITE
- Remote execution vulneraability follow-up
Actions
- Jody: release GeoServer 2.8-beta (et al)
- Jody / Victoria Office: release GeoServer 2.6.5 (et al)
Actions from last meeting
- Torben: merge GEOS-7095 fix backports to 2.7.x, 2.6.x, and 2.5.x [DONE]
- Kevin: submit port-scan fix and backport [DONE]
- Create Jira components Security (Authentication) and Security
(Authorization) to replace Security [DONE]
General Discussion
- source forge is back - yay
- CITE - take to email
- gsconfig is "open", if you need commit access ask :slight_smile:
- state of geoserver, round up from proposals (nodata, curves, build service, windows build servie, java 8, etc...)
Release managers
https://github.com/geoserver/geoserver/wiki/Release-Schedule
Volunteers:
- 2.8 beta - Jody
- 2.6.5 last - Jody / Victoria Office
Email discussion about "bonus" releases with other projects.
GeoNode will want to release a 2.7.x sometime in the beginning september. Use a bit of common sense, don't release too close to an official release of the same version.
Code Freeze
August 18th.
Jody will remind the GeoTools email list.
Andrea will remind the GeoTools email list.
Anything else we are desprately waiting for something to get in?
- AA: shapefile thing that broken? DBF filter pull request ...
- KS: LayerGroup proposal (if there is time ...). Could we do the API change now? And do the implementation later ...
Proposals
Which ones are are trying to make the code freeze? Assume all of them ...
GeoTools:
- Constrast enhancement: some feedback on API breakage, see email discussion.
- z-ordering: Q: FeatureType.getSortBy() vs. vendor option? A: keep consistent, non SLD options go in vendor options.
- SourceForge exit strategy: keep this around if needed later
- Resolve GeoAPI 3.0.0 Incompatibilities: no interested sponsor for this work
- Views Management removal: was this implemented?
- Maven Central: think this is stuck on JAI dependency
- Add delete support on StructuredGridCoverage2DReader: has this been implemented?
- ComplexFeature Parsing and Building Support by Adam Brown. This is used in wfs-ng. Rini worked on it last year. Niels completed work on it this year, and Ben merged the final PR in May (should announce for GeoTools master 14-M1; was in 14-M0 but unannounced). Jira issue is resolved. Just need to update the proposal page [DONE].
https://github.com/geotools/geotools/wiki/complexfeature-parsing-and-building-support
https://github.com/geotools/geotools/pull/841
https://osgeo-org.atlassian.net/browse/GEOT-4147
GeoServer:
https://github.com/geoserver/geoserver/wiki/Proposals
- dev guide cleanup: approved, in progress
- layergroup: approved, kevin is busy
New community modules created, rest are in progressed.
Jody volunteered to test (was hoping to test gsconfig).
https://osgeo-org.atlassian.net/browse/GEOS-7039
    * Ask about this for bart.
    * Q: If we include the prefix will we break everything? A: Check the naming rules in the spec. Perhaps use
https://osgeo-org.atlassian.net/browse/GEOS-6984
    * monitoring is a bit orphaned
    * Q: Should this go to community? A: the monitoring api is in active so we keep it in the mix. Audit mode generates files ...
    * The hibernate module is more a proof of concept - so it could go to community.
CITE
Thanks for the email Andrea, look at setting up jobs on ares.
Yes we do not expect things to pass yet.
Check back after the code freeze :slight_smile:
Remote execution vulnerability follow-up
Merged. Kevin reports that the nightly is not building cleanly so we cannot test a nightly.
Action:
- Jody is going to test gsconfig, and will reach out to gsconfig community.
- Kevin wants to backport to 2.7 - and will get a bunch of QA from boundless.
- GEOS-7139 JBoss security fix conflict: Torben has a potential fix incoming. Q: Does Commons VFS also respond to this protocol? Q: gs-importer includes Commons VFS. Does this open up a tomcat server to vfs URLs?
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
  • GEOS-7139 JBoss security fix conflict: Torben has a potential fix incoming.
More details added to as a comment on GEOS-7139.
Torben
On Tue, Aug 4, 2015 at 1:31 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Attending
Ben Caradoc-Davies
Jukka Rahkonen
Andrea Aime
Kevin Smith
Jody Garnett
Torben Barsballe
Agenda
  • Release managers
  • Code Freeze
  • Proposals
  • WCS 1.1 DescribeCoverage/GetCapabilities Question
  • CITE
  • Remote execution vulneraability follow-up
Actions
  • Jody: release GeoServer 2.8-beta (et al)
  • Jody / Victoria Office: release GeoServer 2.6.5 (et al)
  • Torben: merge GEOS-7095 fix backports to 2.7.x, 2.6.x, and 2.5.x [DONE]
  • Kevin: submit port-scan fix and backport [DONE]
  • Create Jira components Security (Authentication) and Security
General Discussion
  • source forge is back - yay
  • CITE - take to email
  • gsconfig is “open”, if you need commit access ask :slight_smile:
  • state of geoserver, round up from proposals (nodata, curves, build
    service, windows build servie, java 8, etc…)
Release managers
Volunteers:
  • 2.8 beta - Jody
  • 2.6.5 last - Jody / Victoria Office
Email discussion about “bonus” releases with other projects.
september. Use a bit of common sense, don’t release too close to an
Code Freeze
August 18th.
  • AA: shapefile thing that broken? DBF filter pull request …
  • KS: LayerGroup proposal (if there is time …). Could we do the API
    change now? And do the implementation later …
Proposals
Which ones are are trying to make the code freeze? Assume all of them …
GeoTools:
  • Constrast enhancement: some feedback on API breakage, see email
    discussion.
  • z-ordering: Q: FeatureType.getSortBy() vs. vendor option? A: keep
  • SourceForge exit strategy: keep this around if needed later
  • Resolve GeoAPI 3.0.0 Incompatibilities: no interested sponsor for this
    work
  • Views Management removal: was this implemented?
  • Maven Central: think this is stuck on JAI dependency
  • Add delete support on StructuredGridCoverage2DReader: has this been
    implemented?
  • ComplexFeature Parsing and Building Support by Adam Brown. This is
GeoServer:
  • dev guide cleanup: approved, in progress
  • layergroup: approved, kevin is busy
  • Ask about this for bart.
  • Q: If we include the prefix will we break everything? A: Check the
  • monitoring is a bit orphaned
  • Q: Should this go to community? A: the monitoring api is in active
    so we keep it in the mix. Audit mode generates files …
  • The hibernate module is more a proof of concept - so it could go
    to community.
CITE
Action:
  • Jody is going to test gsconfig, and will reach out to gsconfig community.
  • Kevin wants to backport to 2.7 - and will get a bunch of QA from
    boundless.
    vfs URLs?
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Geoserver-devel mailing list
Fixed this and re-ran the GWC and GS master nightly jobs on ares so the
master nightly builds should have these fixes.
  Kevin Michael Smith
  smithkm@anonymised.com
Thanks Kevin,
I will pass on the note to gsconfig project. Let’s hear back from testing and then back port to stable.
Kevin Michael Smith
Jody Garnett
On Tue, Aug 4, 2015 at 11:00 PM, Torben Barsballe <
incoming.
*A: *No. The vfs:// protocol is unique to JBOSS. Commons VFS uses
conventional URLs/protocols with its own resolvers etc.
vfs URLs?
*A: *No, see above
Thanks for testing Torben!
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Excellent
Ing. Andrea Aime
@geowolf
Technical Lead
