GeoTools / GeoServer Meeting 2015-10-06
Attending
Ben Caradoc-Davies
Jody Garnett
Torben Barsballe
Jukka Rahkonen
Andrea Aime
Kevin Smith
Agenda
- Daylight Saving Time
- Build infrastructure
- FOSS4G report
- Release Update
- Perpendicular offset
- Java 8 switch?
- Pull Request Roundup
- CITE tests please
Actions
Actions from meetings:
- jody: geotools blog post (sigh)
new actions:
- Ben: next meeting invite has a time change
- Ben: GML client library blog post
- Andrea: Send Java 7 switch master email (yay!)
- Kevin: proposal for geotools Java 8 functional interfaces ..
- Jody: run fossdem vs victoria numbers, default assumption is victoria
Ben has moved to 8:30am in NZDT (which is much kinder).
Andrea is leaving DST later on Oct 25th? So move the meeting Yes ...
Nov 3rd meeting will be rescheduled:
http://www.timeanddate.com/worldclock/meetingtime.html?iso=20151103&p1=215&p2=256&p3=264&p4=101
From 3 November move meeting one hour later UTC:
http://www.timeanddate.com/worldclock/meetingdetails.html?year=2015&month=11&day=3&hour=20&min=30&sec=0&p1=215&p2=256&p3=264&p4=101
New meeting time from 3 November 20:30 UTC:
http://www.timeanddate.com/worldclock/fixedtime.html?msg=New+PSC%2FPMC+Meeting+time&iso=20151103T2030&p1=%3A
Trying to change over master, was stuck on credentials.
Got it sorted now, master is switching over geotools -> geowebcache -> geoserver.
When that works we will change DNS setting over.
Andrea and Ben have been sent admin credentials, any other PSC members need access please ask.
Thanks to Dave Kesley, Devon Tucker for fixing.
FOSS4G report
Anything else to say? Andrea did not get to see any presentations (ha ha).
Presentations going online today (incase you did not see anything).
- https://www.meci.co.kr/societyevent/FOSS4G2015/program/program_1.asp?sMenu=pro1
Videos? not yet soon.
GeoSolutions did a blog post, boundless should do one shortly, may wish to link to them from the "about geoserver" section of the release notes.
Release Update
The build servers have been on fire, Jody has not anounced GeoTools yet (or sent emails).
Help writing/review - link to feature blog posts etc... this was "due" September 30th. Ben to write GML client library blog post.
Q: GeoServer 2.7.3 last month? Not yet ..
Q: 2.7.3 will go out this month (and then we can do security announcement).
Simone may still be volunteering? May still be in conjunction GeoNode
Due to repo change this release may be more exciting then usual.
GeoWebCache automation? Great speed up but release is still manual (not on ares).
Every two years this is a feature request
Andrea working on it, will master. Is it suitable for backporting? Both SLD parsers already supporting it so maybe.
Q: JTS 1.14 is released to maven? Should we update master? Martin is directly releasing to maven now!
Java 8 switch?
Yes please, ares is "ready"? Check with kevin.
Master is available lets go! After build issue is fixed...
More autoclosable
- Store, grid Readers, FeatureIterators
- Proposal add close() method implementation to interfaces to calls to dispose()
https://docs.oracle.com/javase/tutorial/java/IandI/defaultmethods.html
This sounds great! Do you need or want a proposal?
Streams/Closures:
- kevin is all happy about it
- do a pass to mark thse as functional, and default methods to line up with formal functional interfaces
- make proposal to list the interfaces to hit? Kevin is happy to take a run at it...
GeoServer wicket/closures?
- can we use this approach to cut down on boilerplate of inner classes
- example: https://github.com/rodrigouchoa/wicket-lambda and https://github.com/todvora/wicket-lambdamodel
Code Sprint Planning
Do we want to try and join fossdem, need answer by friday.
Victoria or fossdem, cheaper to fly to victoria? okay.
Kind of depends on fundraising, goal is two people.
Jody will run the numbers and report to geoserver-devel, if we do not get an answer by Friday that is our answer.
https://github.com/geoserver/geoserver/pull/551 Legend Graphics
- andrea reviewed 1.5 years ago, torben fixed the wicket feedback
- can we merge now? need rebase/merge ... wait for build server to work.
https://github.com/geoserver/geoserver/pull/1248
kevin has some UI updates coming on checkbox UI fixes.
CITE tests please
When ares works again, cite is next on our list (sad).
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
