[Geoserver-devel] GeoTools / GeoServer Meeting 2015-11-03
Attending
Ben Caradoc-Davies
Ian Turton
Andrea Aime
Jody Garnett
Torben Barsballe
Kevin Smith
Jukka Rahkonen
Jeff Brower
Brad Hards
Agenda
- CITE tests and build infrastructure
- Java 8
- Code sprints
- ImageProcessing (OpenCV, ImageJ, GeoAI)
Actions
- Andrea whitelist winbuild instead of subscribing
- Jody: check CITE test problem with boundless IT
- Ben: call for volunteers to migrate master to Java 8 [DONE]
- Jody: for Victoria code sprint, reach out to BC government, vivid solutions, etc...
- Ben: make a wiki page for the Victoria code sprint [DONE]
- Andrea : fill wiki page for code sprint
Actions from last meeting
- Victoria Office: move master to reference artifactory directly
See email! Apparently we all missed it.
Winbuild: failing, has not been notifying the list since August.
What do we need? 2.8.x and master are not getting tested!
- check ares to see if port ... trying to connect a service?
- startup starts jetty, then polls port until it gets a response, gets a 404 and dies
http://ares.boundlessgeo.com/jenkins/view/testing-cite/job/2.8-cite-wfs-1.0/33/consoleFull
<head>
   <meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1"/>
   <title>Error 404 NOT_FOUND</title>
</head>
- when did this start? October 21st ...
- funny - the 2.7.x branch actively starts and works?
- Check if each branch uses a different a port?
   2.7.x polling port 11010
   2.8.x polling port 11010
- Check version of Java used?
- action: check with boundless IT
Java 8
Waiting for CITE tests working - so this activity is blocked.
Agreed to move JDK and source+target for master.
Need a champion for this activity, recommend changing CITE, then online tests, then master. And organize response.
Action: call for volunteers.
Travis status:
- https://travis-ci.org/geotools/geotools (good)
- https://travis-ci.org/geoserver/geoserver (dunno)
Code Sprints
There are two code sprints on the radar:
* Feb code sprint in Victoria :slight_smile:
* France code sprint a week in Feb:
   http://doodle.com/poll/ii5cu9et58vghkts
Approach:
1. make a wiki page (action: jody and ben)
    http://wiki.osgeo.org/wiki/Victoria_Code_Sprint_2016
2. put the topic on the next board meeting (action: andrea)
    http://wiki.osgeo.org/wiki/Board_Meeting_2015-11-12
Ideas for wiki page:
- Present as a maintenace activity, rather than a community build activity.
Sponsors ideas:
- OSGeo
- Credit GeoSolutions and Boundless for staff time
- Local: BC Government? vivid solutions, etc...
Concerns:
- concerned about cost (see sponsorship)
- time is close to code freeze? Could we do this mid January
- may be a bit of scramble to get sponorship in order
- action: Put January as primary date, mid Feb as fallback plan.
OpenCV Discussion
Jeff Bower has a proposal sent out, Andrea has had a quick glance at the proposal.
Discussion:
- possible replacement for native JAI replacment? Ie implement JAI Operators we care about in terms of OpenCV (Scale, Translate, General Affine, Warp, Crop, Lookup) and then give the a higher priority so they are used if OpenCV plugin they are used.
- discussion focused on WMS optimization above, Jeff's customers may be using WPS for "image analyitics" - so they may be using WPS?!
- standard operations may be worse because of latency in calling JAI operations via an accelerator.
- concern about moving data on and off GPU? OpenCV can be configured to stay on CPU
- note: GIS procesing is not normal image processing - requires region of interest (similar to a mask), and 'no data' (some values should not be processed).
- OpenCV has some support for the above :slight_smile:
ImageProcessing
To review - Java Advanced Imaging is "end of life" and we are looking at stratagies to replace.
JAI
- key feature is the tile based processing engine, you set up your processing chain (kind of like functional programming) and the engine will bring in raster data a chunk at a time allowing processing of files larger than memory.
- no_data and region of interest support has been added as additional operations via JAI-EXT for the processing engine.
Alternatives:
1. OpenCV (see above)
- http://opencv.org/
- BSD license, C/C++ codebase with bindings for Java
- Use OpenCL to share work with CPU/GPU
- Does it have the ability to work data larger then memory? Need to check ...
2. ImageJ
- had a look, seems to be comparable to JAI (ie it is an image processing engine)
- Eclipse Science Working Group is starting in on this one (and may have room for collaboration)
- Found the engine here: http://imagej.net/ImgLib2
- Could not see any support for working with raster data larger than memory. Has region of interest (ROI) support, not sure about no_data.
- At least one nD dimensional data format.
- has high level operators (feaure extractions etc...)
3. JAI Replacement
- Need a project name for JAI replacement, then start fund raising
- Interest from Boundless, GeoSolutions, LocationTech, H2Gis too
- would like work though OSGeo and LocationTech
- mostly focused on the technical requirements
- name? JAI-NG, GTAI, GeoAI, JSCIP (Java Scalable Image Processing) JAI-15, OpenJImaging, OpenJI? OpenJAI? JIOpen? GeoNee
- No use of JAI interfaces ... because Oracle
- "Java" is a trademark
- This is a *lot* of work, both in the project, and in migrating GeoTools and GeoServer.
- Q: How well does GeoTools protect downstream projects? Pretty good (except for direct rendering path and some WPS). Remaining code is hidden behind "image worker".
- Note: RenderedImage is a Java class, not PlanarImage which is the JAI subclass.
4. GeoTrellis
- requires data to be broken into tiles before use, making use of sparc to handle concurrent processing.
- Not sure about no_data and ROI support.
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
OpenCL support is of interest, but tends towards the CUDA direction, requiring a high degree of device specific
knowledge. With the exception of Intel, most of the companies supporting OpenCL are either non-CPU architecture (GPU)
or embedded system device manufacturers (FPGA, SoC, ARM, etc although earlier this year ARM did join the OpenMP ARB).
A key for high performance OpenCV is that it supports OpenMP. This means that (i) code with OpenMP pragmas runs
unmodified on x86, c66x, PPC, or any other multicore CPU and (ii) and can be enabled by setting #defines and compiler
flags (e.g. -fopenmp for gcc).
OpenCV has ROI support but would need to be modified for no_data (null) pixels and virtual bitmaps.
-Jeff
Attending
Ben Caradoc-Davies
Ian Turton
Andrea Aime
Jody Garnett
Torben Barsballe
Kevin Smith
Jukka Rahkonen
Jeff Brower
Brad Hards
Agenda
- Java 8
- Code sprints
Actions
solutions, etc...
404 and dies
<head>
</head>
Java 8
Travis status:
Code Sprints
Approach:
Sponsors ideas:
- OSGeo
Concerns:
OpenCV Discussion
proposal.
Discussion:
stay on CPU
be processed).
ImageProcessing
JAI
larger than memory.
Alternatives:
check ...
2. ImageJ
processing engine)
3. JAI Replacement
subclass.
4. GeoTrellis
Director
New Zealand
Geoserver-devel mailing list
Thanks for the clarifications Jeff, and taking part in last nights meeting. I am going to reply to your other thread with respect to engaging the community.
On 4 November 2015 at 02:49, Jeff Brower <jbrower@anonymised.com> wrote:
  • Use OpenCL to share work with CPU/GPU
-Jeff
Attending
Ben Caradoc-Davies
Ian Turton
Andrea Aime
Jody Garnett
Torben Barsballe
Kevin Smith
Jukka Rahkonen
Jeff Brower
Brad Hards
Agenda
  • CITE tests and build infrastructure
  • Java 8
  • Code sprints
  • ImageProcessing (OpenCV, ImageJ, GeoAI)
Actions
  • Andrea whitelist winbuild instead of subscribing
  • Jody: check CITE test problem with boundless IT
  • Ben: call for volunteers to migrate master to Java 8 [DONE]
  • Jody: for Victoria code sprint, reach out to BC government, vivid
    solutions, etc…
  • Ben: make a wiki page for the Victoria code sprint [DONE]
  • Andrea : fill wiki page for code sprint
  • Victoria Office: move master to reference artifactory directly
Error 404 NOT_FOUND
  • when did this start? October 21st …
  • funny - the 2.7.x branch actively starts and works?
  • Check if each branch uses a different a port?
  • Check version of Java used?
  • action: check with boundless IT
Java 8
Travis status:
Code Sprints
Approach:
  • Present as a maintenace activity, rather than a community build activity.
Sponsors ideas:
  • OSGeo
  • Credit GeoSolutions and Boundless for staff time
  • Local: BC Government? vivid solutions, etc…
Concerns:
  • concerned about cost (see sponsorship)
  • time is close to code freeze? Could we do this mid January
  • may be a bit of scramble to get sponorship in order
  • action: Put January as primary date, mid Feb as fallback plan.
OpenCV Discussion
proposal.
Discussion:
  • possible replacement for native JAI replacment? Ie implement JAI
  • discussion focused on WMS optimization above, Jeff’s customers may be
    using WPS for “image analyitics” - so they may be using WPS?!
  • standard operations may be worse because of latency in calling JAI
  • concern about moving data on and off GPU? OpenCV can be configured to
    stay on CPU
  • note: GIS procesing is not normal image processing - requires region
    of interest (similar to a mask), and ‘no data’ (some values should not
    be processed).
  • OpenCV has some support for the above :slight_smile:
ImageProcessing
To review - Java Advanced Imaging is “end of life” and we are looking at
JAI
  • key feature is the tile based processing engine, you set up your
    larger than memory.
  • no_data and region of interest support has been added as additional
Alternatives:
  • http://opencv.org/
  • BSD license, C/C++ codebase with bindings for Java
  • Does it have the ability to work data larger then memory? Need to
    check …
  1. ImageJ
  • had a look, seems to be comparable to JAI (ie it is an image
    processing engine)
  • Eclipse Science Working Group is starting in on this one (and may have
  • Found the engine here: http://imagej.net/ImgLib2
  • Could not see any support for working with raster data larger than
  • At least one nD dimensional data format.
  • has high level operators (feaure extractions etc…)
  1. JAI Replacement
  • Need a project name for JAI replacement, then start fund raising
  • Interest from Boundless, GeoSolutions, LocationTech, H2Gis too
  • would like work though OSGeo and LocationTech
  • mostly focused on the technical requirements
  • name? JAI-NG, GTAI, GeoAI, JSCIP (Java Scalable Image Processing)
  • No use of JAI interfaces … because Oracle
  • “Java” is a trademark
  • This is a lot of work, both in the project, and in migrating
  • Q: How well does GeoTools protect downstream projects? Pretty good
    hidden behind “image worker”.
  • Note: RenderedImage is a Java class, not PlanarImage which is the JAI
    subclass.
  1. GeoTrellis
  • requires data to be broken into tiles before use, making use of sparc
  • Not sure about no_data and ROI support.
Ben Caradoc-Davies <ben@anonymised.com.>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Jody Garnett
Jody-
Thanks. I see your other reply. I have been reading about JAI-EXT and will have some questions shortly.
-Jeff
-Jeff
Attending
Ben Caradoc-Davies
Ian Turton
Andrea Aime
Jody Garnett
Torben Barsballe
Kevin Smith
Jukka Rahkonen
Jeff Brower
Brad Hards
Agenda
  • Java 8
  • Code sprints
Actions
    solutions, etc…
Error 404 NOT_FOUND
Java 8
Travis status:
Code Sprints
Approach:
Sponsors ideas:
  • OSGeo
Concerns:
OpenCV Discussion
proposal.
Discussion:
    stay on CPU
    be processed).
ImageProcessing
JAI
    larger than memory.
Alternatives:
    check …
  1. ImageJ
    processing engine)
  1. JAI Replacement
    subclass.
  1. GeoTrellis
Director
New Zealand
–Jody Garnett
Ciao Jeff,
the main problem I saw when I played with OpenCV was that ROIs can only be rectangles but we usually need
generic shapes.
Any thoughts on that?
-Jeff
Attending
Ben Caradoc-Davies
Ian Turton
Andrea Aime
Jody Garnett
Torben Barsballe
Kevin Smith
Jukka Rahkonen
Jeff Brower
Brad Hards
Agenda
  • Java 8
  • Code sprints
Actions
    solutions, etc…
Error 404 NOT_FOUND
Java 8
Travis status:
Code Sprints
Approach:
Sponsors ideas:
  • OSGeo
Concerns:
OpenCV Discussion
proposal.
Discussion:
    stay on CPU
    be processed).
ImageProcessing
JAI
    larger than memory.
Alternatives:
    check …
  1. ImageJ
    processing engine)
  1. JAI Replacement
    subclass.
  1. GeoTrellis
Director
New Zealand
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
Simone-
need generic shapes.
To make it do-able without extra APIs to create and apply masks (and without hijacking the mask parameter present in
many opencv APIs) would require mods to OpenCV source. We can consider to do mods like this with #ifdef GEOSERVER or
similar. We have taken that approach before when adding functionality. I would have to look and see if ROI is
currently handled in a central code location and applied uniformly across APIs. OpenCV is well-written, so that's
likely.
It sounds like non-rectangular ROIs and null pixels may go hand-in-hand. One thing for sure though, irregular ROIs
will affect performance. But that's the fun part.
-Jeff
-Jeff
> Attending
> Ben Caradoc-Davies
> Ian Turton
> Andrea Aime
> Jody Garnett
> Torben Barsballe
> Kevin Smith
> Jukka Rahkonen
> Jeff Brower
> Brad Hards
> Agenda
> - Java 8
> - Code sprints
> Actions
> solutions, etc...
> 404 and dies
> <head>
> </head>
> Java 8
> Travis status:
> Code Sprints
> Approach:
activity.
> Sponsors ideas:
> - OSGeo
> Concerns:
> OpenCV Discussion
> proposal.
> Discussion:
> stay on CPU
> be processed).
> ImageProcessing
> JAI
> larger than memory.
> Alternatives:
> check ...
> 2. ImageJ
> processing engine)
> 3. JAI Replacement
> subclass.
> 4. GeoTrellis
> Director
> New Zealand
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Code Sprints
Approach:
Sponsors ideas:
- OSGeo
Concerns:
OSGeo has provided the following guideline:
http://wiki.osgeo.org/wiki/Code_Sprint_Guidelines
On Mon, Nov 9, 2015 at 9:16 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Approach:
I guess I mixed stuff up, though I had to create the page. Anyways, here is
a straw man of
a page for the sprint:
http://wiki.osgeo.org/wiki/GeoServer_Code_Sprint_2016
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
talking with Simone he suggested that we could try to crowdfund the sprint:
http://www.crowdfunding.com/
We could open a project on kickstarter or something, advertise on blog post,
company blog posts, and so on, and try to get some funding that way?
With OSGeo hopefully padding it some.
On Tue, Nov 10, 2015 at 9:50 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
I guess I mixed stuff up, though I had to create the page. Anyways, here is a straw man of
Ing. Andrea Aime
@geowolf
Technical Lead
Approach:
Ing. Andrea Aime
@geowolf
Technical Lead
Jody,
CITE tests are still failing. Have you heard back from Boundless IT?
Kind regards,
Ben.
Actions
404 and dies
<head>
</head>
Director
New Zealand
Thank you Andrea that looks great. Meeting with the board is Thursday so we have a bit of time.
On Mon, Nov 9, 2015 at 9:16 PM, Jody Garnett <jody.garnett@…403…> wrote:
Approach:
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks for setting that up, it allowed me to discuss the sprint with the board today. Although I was not in position to ask for sponsorship until we set a budget.
On 10 November 2015 at 08:50, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Approach:
Hum… any updates? The stable release next week is going to get blocked by this.
Well, unless Ben wants to run the CITE tests manually…
On Tue, Nov 10, 2015 at 7:06 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Jody,
Kind regards,
Ben.
Actions
Error 404 NOT_FOUND - when did this start? October 21st ... - funny - the 2.7.x branch actively starts and works? - Check if each branch uses a different a port? 2.7.x polling port 11010 2.8.x polling port 11010 - Check version of Java used? - action: check with boundless IT
Director
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
Tom Ingold (CCeed) has been working on this.
Checking my email from him it looks like:
a) We found the script
b) Fixed port issue so Jetty will start
c) Have a log4j conflict preventing geoserver from running.
Tom what is the log4j conflict, could we fix it on the geoserver side and make your job easier?
On 13 November 2015 at 12:23, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
Jody,
Kind regards,
Ben.
Actions
Director
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
I have updated this, and starting to fill in the OSGeo Funding request information at the bottom of the page.
The guidelines on that page indicate they like to match funds. I will try and ascribe a value to in-kind contributions of venue etc…
Jody
On 10 November 2015 at 00:50, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Approach:
