GeoTools / GeoServer Meeting 2015-12-01
Attending
Ben Caradoc-Davies
Kevin Smith
Jody Garnett
Jukka Rahkonen
Ian Turton
Niels Charlier
Torben Barsballe
Andrea Aime
Agenda
- PSC changes
- uDig problems with Boundless Maven repository
- Resource API migration
- Jetty / Spring version upgrade
- Java 8 change
Actions
- Jody: update GeoServer PSC list [DONE]
- Ben: email Ian and Brad to ask if interested in joining PSC
- Ben: merge ResourceStore changes
- Ben: switch GeoServer and GeoTools master to Java 8
- Kevin: switch GeoWebcache master to Java 8
- Ian Turton to release GeoServer this month
- Jody: release milestone
Actions from last meeting
- Jody: merge GeoTools PR #1030 and backport to 14.x for 14.1/2.8.1 [DEFERRED see #1055]
- Jody: merge GeoTools PR #1048 for 14.x for 14.1 release [DONE]
- Ben: release 14.1/2.8.1 [DONE]
- Alessio: release 2.7.4
- Ben: simplify Jira workflow for GeoTools and GeoServer [DONE]
- Jody: call for nominations for PSC on mailing list
- Jody: nominate Kevin Smith for PSC on mailing list [DONE]
- Kevin: GeoTools / GeoServer - change from snapshot to main (to prevent HTTP 409). Kevin will prepare pull request [DONE]
PSC changes
- Kevin Smith joins the GeoServer PSC
- Phil Scadden steps down from the GeoServer PSC
- Ask for user representative?
- Look for individuals who has been active on the user mailing list?
a) Ian Turton
b) Brad Hards
- Action [Done] Update https://github.com/geoserver/geoserver/blob/master/doc/en/developer/source/policies/psc.rst
- Action: email Ian and Brad to ask for interest
- Should be solved
- Original repo failed in september
- Http redirect and http proxy pointing to artifactoryonline did not work out as replacement
- Now repo.boundlessgeo.com/main DNS changed to directly reference artifactory online
- uDig repo may not yet have been restored?
ResourceStore API migration
Here is the wiki page:
* https://github.com/geoserver/geoserver/wiki/Cleaning%20up%20File%20References
https://github.com/geoserver/geoserver/pull/1346
https://github.com/GeoWebCache/geowebcache/pull/354
- This is not a new proposal, it is the "second half" of the proposal
https://github.com/geoserver/geoserver/wiki/GSIP-106
https://github.com/geoserver/geoserver/wiki/ResourceStore-API-Examples
- Large pull request exceeds GitHub limits, last 57 files show no changes (so look at individual commits!)
- GitHub support apologise, plan to implement a warning notice
Niels:
- This can use extra testing during review/merge (request a couple of hours testing before merge)
- Or apply to master and ask for nightly-build testing
- Include in a milestone? Yes.
Discussion:
- Jody: Consider testing this with new version of spring / jetty?
- Ian: how to tell what caused failure?
- Niels: no more pending changes - this is good to go
- Resolution of base directory access question? Via GeoServerResourceLoader.
Q: try-with-resource syntax? Could not fix for rest module due to pom.xml setting. A: fix it!
Q: Ben can you review and merge? A: yes!
Spring appears low risk:
- applied to master, low-risk to backport.
Jetty requires testing:
- Boundless uses Jetty 7.6.13.v20130916 (we jumping to 9.2 so it does not help)
- Jody will volunteer to make a milestone release. Send to user list.
- After testing of milestone, we can make decision about backport
Q: Do we know Justin's timeframe? Ask on mailing list ...
Java 8
Ben++!!!
Volunteers to switch the codebase to java 8.
Action:[Kevin] Confirm ares has OpenJDK and Oracle Java 8?
Warning: build times with java 8 are slower ...
Release Schedule
- https://github.com/geoserver/geoserver/wiki/Release-Schedule
Ian volunteers for 2015-12-18 GeoTools 13.5 / GeoServer 2.7.5.
Pull requests
https://github.com/geotools/geotools/pull/1051
- waiting on feedback
https://github.com/geotools/geotools/pull/1057
- having some trouble communicating design with ahuarte47, fixes in isolation address the specific issue, but break the larger design (for example loading features into memory to count). Continue reviewing pull request, consider breakout IRC meeting if needed.
Sprint
Reminder sign up here, deadline Dec 10th:
- https://wiki.osgeo.org/wiki/GeoServer_Code_Sprint_2016
Discussion
- Defer Java 8 upgrade until after milestone to avoid entanglements
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
