GeoTools / GeoServer Meeting 2016-05-03
Attending
Ben Caradoc-Davies
Torben Barsballe
Kevin Smith
Jukka Rahkonen
Niels Charlier
Ian Turton
Apologies
Brad Hards
Andrea Aime
Jody Garnett (FOSS4G-NA)
Agenda
- Release of 15-RC1 / 1.9-RC1 / 2.9-RC1
- FOSS4G-NA
- Hazelcast/JDBConfig clustering issues
Actions
- Jody to report back from FOSS4G-NA
Actions from last meeting
[None]
Release of 15-RC1 / 2.9-RC1
- Tested on Windows 7 VM
works for Ian and Jukka too
- Can anyone test on other Windows?
- Seems safe, looking for validation
- Otherwise everything is ready and will announce soon
- Jukka is upgrading to Windows 10 but it is not yet ready for testing, will try tomorrow.
FOSS4G-NA
- FOSS4G-NA underway
- Jody to report back at next meeting
Hazelcast/JDBConfig clustering issues caused by HTTP 302 response and unique wicket resource IDs
http://osgeo-org.1560.x6.nabble.com/Hazelcast-JDBConfig-clustering-issues-caused-by-HTTP-302-response-and-unique-wicket-resource-IDs-td5263213.html
- Discussed options
- Turn off unique wicket IDs only if Hazelcast in use
- Requires restart?
- Unknown
- Agreed to make unique wicket resource IDs configurable
- Hazelcast plugin to disable unique wicket resource IDs
Pull requests
- The committee worked through outstanding pull requests (all GeoTools, about a quarter of GeoServer)
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
- Discussed options
- Requires restart?
Ben, to answer your question from the meeting on Monday.
It does require a restart to change the mode.
Kind Regards
Niels
- Discussed options
- Requires restart?
Thanks for the confirmation, Niels. Are there any docs or UI components that require should mention this? I do not think that there is anywhere a user could toggle the plugin status in the UI, but it might be worth mentioning in the docs that installing the plugin will disable Wicket unique resource IDs and why, and the security impact.
Kind regards,
Director
New Zealand
Hello Ben
I added documentation to the PR. Is it what you had in mind?
Regards
Niels
Hello Ben
Regards
Niels
Yes, that looks great. Just what I had in mind.
Kind regards,
Director
New Zealand
