[Geoserver-devel] GeoTools / GeoServer Meeting 2017-10-03
Attending
Ben Caradoc-Davies
Brad Hards
Jody Garnett
Kevin Smith
Torben Barsballe
Jukka Rahkonen
Apologies# Agenda- Build server and CITE tests
  • 2.12 release
  • Dependency management around “WPS required”
  • GWC Status
  • Java 9 compatibility GSIP Review / Discussion
Actions- Ben: Send email to arrange a CITE test breakout meeting
  • All: Review swagger docs, fix outstanding errors
  • Ben and Jody: add GWC refactoring comments to email thread
Previous Meeting actions- (done) Torben: Get ssh access to provide build box with “geotools” git user?
  • (done) Torben: Swagger try enum + Reference Approach on core, send example to list and ask for help on extensions
  • (done) Kevin: Create a GSIP placeholder page for next release about bundling API docs and User docs as optional extensions for GeoServer
  • (done) Torben and Jody: 2.12 RC1 (Week of Sept 25)
  • Ian (and Kevin?): 2.12 Release (Week of Oct 2)
  • (done) Jody: Update release schedule
build.geoserver.org:
  • Where are at with the builder server?
  • See RC1 release retrospective email
  • What else needs to be done?
  • CITE Tests need to be migrated from ares
  • They are running, but are not working, …
  • The moment they run we can shut off ares
  • Action: Ben: Send email to arrange a CITE test breakout meeting
  • Mac Build Box
  • Currently manual, using qgis build server, which should be shut off “soon”
  • Download numbers show mac is still used, but not very much
  • Q: Can we move notifications? Yes…
  • 2.12 branch jobs should be sending email notifications to the list
  • Check if there is a way to bulk change notifications?
  • What about the databases?
  • PostGIS - is failing on a legitimate build failure since mid september
  • this is working on ares, so we have a problem here
  • Oracle - working
  • App-schema jobs are working
  • All the other online tests seem to be cheerful
repo.boundlessgeo.com:
  • We have not seen a lazy saturday failure recently, turned off big-stop-the-world backup solution
2.12 release
See Torben’s “retrospective” email:
  • Q: Should we consider moving downloads to github?
  • Torben tried this manually, there is a github api to do this
  • Q: For historic releases
  • Consider releasing to both for a year, and then stop using sourceforge …
  • Does GitHub track download stats
  • Kevin is going to go check as one GWC release was made on sourceforge
  • Yes see - https://help.github.com/articles/getting-the-download-count-for-your-releases/
Testing priorities from beta:
  • (done) Mac DMG use - tested, now avoid conflict with system JAI
  • REST API Resource, format xml or json has problem with metadata request getting confused
Swagger docs:
  • Torben did a full pass on docs, match actual code!
  • Quiet-on-not-found parameter, used internally for testing, not documented on purpose (will make a note to the rst docs).
  • All the core stuff has been merged in for RC1
  • Extension docs
  • Outstanding pull requests, need to be reviewed merged, and backported
  • Action: Jody to review outstanding extension swagger docs
  • Markdown Examples
  • DataStore examples are the priority
  • Style examples
  • Add Layer example, this is not intuitive
  • Q: Will this be ready for 2.12 release?
  • Depends on Ian calling time
  • We noticed that the build server swagger doc builds report failures, but do not result in a failed build!
  • tried updating to the new maven plugin, did not help, made it worse
  • These are actual valid failure, for example the datastore page
  • Action: All: Review swagger docs, fix outstanding errors
GeoServer 2.12 release critical path:
  • Verify security vulnerability (reported against 2.8)
  • GWC GEOS-7713
  • Swagger docs fix errors, nice to have - should not hold up release
Problem:
  • WPS and GeoWebCache have a strange dependency relationship
  • This occurs in a number of spots where an extension requires WPS be installed, just to access the geotools process
  • GeoPkg depends on MBTiles depends on WPS to depend on gt-process
  • GeoTools gt-process was split up into gt-process (API), gt-process-geometry, gt-process-feature, gt-process-raster
Q: Can these extensions depend directly on gt-process?
  • gs-mbtiles extensions depends on
  • both gs-wps and gs-wps-test
  • gridset information form GWC
  • geopackage:
  • Andrea: the module needs to be split into 4 jars core store, wms output format, wfs output format, wps (in January 2017, before including gpkg into the core)
  • The reading side of geopackage was merged into core for the 2.12-RC1
Q: Can “core” depend directly on gt-process so that gs-wps only adds the WPS protocol?
Strategy discussion:
  • Proposal: Pull up tile stuff into geotools?
  • For common use between geowebcache and mbtile (also vector tiles?)
  • gt-tile has this from WMS-C tile client implementation
  • Proposal: Move the generic tile discussion out of mbtile into its own module, or to core, …
  • Extensions depend on gt-process, rather than gs-process?
GWC Status
GWC mailing list notes a general code cleanup is scheduled:
  • Pay down technical debt, boundless is looking into options if anyone is interested :slight_smile:
  • Make the codebase livable, easier to work with …
Feedback:
  • Jody: The LISAsoft pull request made a distinct module for the GUI, making the codebase far easier to work with (and made it possible to deploy without the GUI).
  • Ben: Duplication between GeoServer GWC class functionality between core
  • Jody: A pass through for code consistency would help, it is obvious that the code has been written piecemeal feature by feature
  • Separate out the GUI from the REST API (wicket - for sharing with GeoServer, or just FDL templates)
Please provide feedback to the email thread …
  • Action: Ben and Jody to add GWC refactoring comments to email thread
See: https://github.com/geotools/geotools/wiki/FactoryRegistry-Refactoring-for-Java-9-Compatibility
There are several API changes, hence the GSIP:
  • Java 9 requires service provide factory to only work with image operations
  • GeoTools used this for Factories:
  • any object with a no argument constructor
  • If the object had a constructor supporting hints it would be called, and the results stored in a registry based on the hints to avoid duplicate instances
  • Jody likes this because the API break makes it clear that a change has occurred!
  • ServiceRegistry → FactoryRegistry
  • We are using GeoTools “Factory” everywhere to be clear this is an API change
  • What does this look like for client code?
  • If you use a FactoryFinder - no change!
  • Change targets GeoTools 19 (current master)
  • API breaking so will not be backported
  • If you implement a Factory should be no change
  • Oracle is dropping support for 32-bit https://stackoverflow.com/questions/46356345/can-java-9-run-on-a-32-bit-os
  • Windows installer requires 32-bit at the moment (does it?)
How to handle users upgrading to Java 9?
  • Ask them to wait …
  • Issue a milestone and ask them to test …
Would this make GeoTools require Java 9?
  • No, the ServiceLocator (used for classpath lookup) has been available since Java 6 (and is the preferred way to do this thing, rather than the image operator ServiceRegistry we have been using)
  • Note this may allow a subset of GeoTools to work on Android (which also uses ServiceLocator)
Ben Caradoc-Davies [<ben@anonymised.com>](mailto:ben@anonymised.com)
Director
Transient Software Limited [<http://transient.nz/>](http://transient.nz/)
New Zealand
