Attending
Ben Caradoc-Davies
Jukka Rahkonen
Kevin Smith
Apologies
Torben Barsballe
Agenda- GeoServer branding guidelines out of date
- Jenkins geotools-master-online-postgis build
Actions- Ben: Discuss Jenkins geotools-master-online-postgis build with Torben
Previous meeting actions- Andrea: Create Proposal for formatting - google style approach [DONE]
Jody: Call for vote on Units proposal [DONE]
Jody: Submit “State of GeoServer” for FOSS4G 2018
GeoServer branding guidelines are out of date- Discussed on GeoWebCache list
Guidelines refer to OpenGeo
https://github.com/geoserver/geoserver/wiki/GeoServer_BrandingGuide.pdf
Kevin asked user to make a proposal
Permit variant that says “Powered by GeoServer” or “Works with GeoServer”?
Common use case is a script represented by a square icon, possibly defaced in corner to indicate “script” or “plugin”
The Jenkins geotools-master-online-postgis build has been broken for six months:
https://build.geoserver.org/view/geotools/job/geotools-master-online-postgis/556/consoleText
After recent fixes, down to three different failures:
Exception opening port H2 TCP Server (tcp://172.16.1.87:9092) (port may be in use)
PSQLException: ERROR: permission denied to create extension “hstore” Hint: Must be superuser to create this extension.
org.postgresql.util.PSQLException: ERROR: type “jsonb” does not exist
Solution to (2) is likely to add “create extension hstore;” to database setup script.
Action: Ben to discuss with Torben
Ben Caradoc-Davies [<ben@anonymised.com>](mailto:ben@anonymised.com)
Director
Transient Software Limited [<https://transient.nz/>](https://transient.nz/)
New Zealand
