Participants
Kevin Smith
Nuno Oliveira
Torben Barsballe
Jody Garnett
Jukka Rahkonen
Actions- Torben: update the Java 11 GSIP with links to email discussion
Torben: install jdk 11 on build.geoserver.org
Jody: add a “preflight” checklist for people attending
Start email list discussion on GWC Site / GS Docs and GitHub Pages
Actions From Last Meeting- Jody: to request funding from board (done)
All: Please promote via twitter etc (done)
Jody: Action schedule breakout meeting for the above time (moved to email)
Agenda- OSGeo Updates
Code Sprint
GeoServer Doc & GeoWebCache site hosting
OSGeo Updates
Code sprint approved:
- $2000 approved, will update sprint page to list OSGeo as host
Jody commented on osgeo todo about CITE tests:
Code Sprint
Wiki:
Finances:
We have 2-3 sponsors now, and OSGeo hosting
Priority: airfare > accommodation > catering
Participants:
- We are down 12 people
Andrea has been adding a bunch of useful information on the mailing lists
One concern: Build times
Need to capture discussion in an organized place
Sprint plan stages (from email), goal is to have something “shippable” at the end of each stage:
build and run in JDK 11
Everything in our stack (jaitools, jai-ext, imageio-ext, geotools, geowebcache, geoserver) builds and run without any flag added, off the classpath (it’s ok to have warnings). This will allow us to get JDK 11 builds going. -
Compile: Andrea has made considerable progress here, to mirror you need to check out and build locally all the dependencies
Pass tests: This may require updating some dependencies
(this can be split up) -
Reduce warnings from Dependency Analysis Tools
Get as much as possible build and run without warnings. -
This cannot be automated, and is y we have so many people in the sprint!
Module repackage
Add automatic module descriptors, eliminate split packages in library projects -
Repackage
make sure we can run a true module app depending on the automatic modules (idea, we could use the demo module, already depending on many of the others, and make that one a true module?).
Adjust imports and the like as needed in all projects, try to collect migration scripts to help others do the same.
org.opengis repackage
Swich gt-api away from using org.opengis package, upgrade everything else to follow -
repackage
update emf models and regenerate
How to coordinate across teams with 8 hour time difference:
If possible teams could work independently
Spring 5 upgrade could happen concurrently with logging upgrade? More generally, dependency updates between GeoTools and GeoServer
Making test cases work
Fixing
We need to coordinate a hand over of work from one team to the next
commit everything to shared branch
Hangout with the next person taking over
Use a spreadsheet to communicate status, progress
Use gitter to communicate early and often, stuck for 15 mins ask for help!
Actions for this week:
Torben is going to update the GSIP with links to discussion
Jody is done the GeoTools proposal
Torben install jdk 11 on build.geoserver.org
JDK 11
Need to check out all the branches on each project and build locally
Read the proposals:
Required reading:
Meeting notes / Documents / Order of operations above (Action: Capture this as a standalone document)
Recommended:
Core Java SE 9 for the Impatient (Chapter 15. The Java Platform Module System)
Background:
The server “wedge” running this stuff is decommissioned:
this is too big for githubpages? (Limit is 1G, docs currently ~7G due to point versions from releases)
We could only publish stable, maintenance, master
Alternative publish to S3
github pages
need to update build box
Discussion:
Jody prefers github pages so that everyone can edit, maintain
https://stackoverflow.com/questions/15347808/display-javadocs-on-github
docs.geoserver.org has already been migrated to S3? DNS not changed over yet.
swagger docs don’t like being hosted statically, need to investigate and see if there is a workaround.
Action:
- Email lists on this discussion
