[Geoserver-devel] GeoTools/GeoServer meeting minutes August 7th 2018
GeoTools / GeoServer Meeting 2018-08-07
Attending
Andrea Aime
Torben Barsballe
Kevin Smith
Jukka Rahkonen
Actions- Torben: We need a wiki page for GeoServer (Spring 5 upgrade etc…)
  • Jody: We need news announcement for the Java 18.9 sprint, asking for participants and sponsorship
  • Jody: OSGeo sprint page for Java 18.9
  • Andrea: one wiki page for jai-ext, imageio-ext, jai and imageio themselves
Topics- Windows build almost there
  • GeoWebCache reformat
  • M support in stores and OGC services
  • Security
  • Chit chat
GT and GWC building
GS needs a review, see “GWC tests failing on Windows, race condition and suggested fix” on the list.
AppVeyor build on GeoServer PRs? No objections.
Will be done in the next two weekends
Parallel JTS and GeoTools/GeoServer work. JTS almost ready to merge, Nuno can work from snapshot then. Then coordinated release.
https://github.com/locationtech/jts/pull/293
  • Feedback addressed
  • Waiting on travis
Security
Private/non archived mailing list is up. We can change the documentation to make people post to it, it will get in a moderation queue, we just need to tell OSGeo who’s gonna administer it.
https://trac.osgeo.org/osgeo/ticket/2187
Andrea and Jody volunteered to be mailing list administrators.
We have found a tool that runs automated check for outstanding vulnerables via our dependencies.
Brad has been working hard on this.
Jenkins:
  • Is it possible to set up a “private” jenkins build? Jenkins matrix security. Build takes some time, so nightly build
  • Some of the Jenkins plugins are out of date, can we schedule update?
Chit chat
Schedule Java roadmap code sprint upgrade. Idea, semi-distributed, one meeting point in north america, one in europe, one in oceania (more to come if we have other participants?)
Timing?
  • September - January is the window, after Java 18.9 release, before Java 8 EOL
  • Late October/ Early November?
Action:
  • Jody: We need news announcement, asking for participants and sponsorship
  • Torben: We need a wiki page for GeoServer (Spring 5 upgrade etc…)
Discussion:
  • A lot of coordination will be required
  • GeoTools - hard break with no possibility for backwards compatibility? (forced package renaming or different collection of jars)
  • So much work to do, some of it can be done in parallel
  • JaxB, can depend standalone
  • JAI, we had a failure on java version number parsing. Not sure about a way forward.
  • Shapefile memory map cleanup, used reflection so many be in trouble. Will need to research workaround…
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
