Attending- Torben Barsballe
Andrea Aime
Alessio Fabiani
Actions from Last Meeting- [Torben] Donate geoserver-exts FileGBD Importer format as a community module [WIP]
Actions- Torben: Investigate GWC website - post GWC Release update
Torben: Investigate cite wcs on the build server
Andrea: Ask on mailing list for 2.14.3 release volunteers
Agenda- GeoServer 2.15.0 released
Continued QA work
GeoServer 2.14.3 release scheduled for Mar 18 - request for volunteers
cite-wcs-1.0 issues
GeoTools 21.0 and GeoServer 2.15.0 released
Blog posts:
http://blog.geoserver.org/2019/03/02/geoserver-2-15-0-released/
http://geotoolsnews.blogspot.com/2019/03/geotools-210-released.html
Continued QA work
Spotbugs up to rank 15 and default threshold.
GeoTools graduated to grade C on lgtm: https://lgtm.com/projects/g/geotools/geotools/alerts/?mode=tree
GeoServer and GeoWebCache also merged, will take some time to show up on lgtm
Next steps?
Check for Deprecated
Check for unnecessary casts
Check for diamond operators (generics)
Checkstyle integration
Java 11 GeoServer build keeps on failing, will try to split it in two, one normal build, one QA only build (latter not running community modules, since they are not checked by QA anyways)
We need volunteers. Ask on mailing list (AA)
cite-wcs-1.0 issues
Runs, hang for 10 hours, pass! (clogging the build queue)
Error happening in the logs at the begnning of tests: 2019-03-04 17:41:22.140
Second error showing in the logs: Mar 05, 2019 3:36:46
Try doing jstack on GS + Cite while the test is running & stuck
