Attending
Jody Garnett
Torben Barsballe
Andrea Aime
Actions- Torben to check potential missing OGR package
Torben will repost PostGIS build failure to email list
Andrea will raise Java 11 test tolerance for GeoTools build (done)
Jody to take “geoserver security” idea to mailing list
Jody will continue to pursue maven repo for GeoTools, has reached out to osgeo projects.
Agenda- Build failures in 2.15.
OGR Build Failure
App Schema Build Failrure
GeoTools Java 11 Failure
Sys Admin
Security Topics
Deprecation effort update
GeoTools care and feeding
PostGIS install has been moved to apollo-slave-01 in advance of apollo-slave-02 being decommissioned.
OGR Build Failure
Due to build server change, new build node has ogr2ogr available (old did not) but missing some library.
App-schema
App-schema postgis also failing, possibly due to the different postgis version
Failed tests: testNestedFilterEncoding(org.geoserver.test.FeatureChainingWfsTest)
testNestedFiltersEncoding(org.geoserver.test.NestedIdSupportTest)
testClientPropertiesFilter(org.geoserver.test.SimpleAttributeFeatureChainWfsTest): expected:<[1]> but was:<[0]>
testNestedFilterEncoding(org.geoserver.test.SimpleAttributeFeatureChainWfsTest): expected:<Filter.INCLUDE> but was:<[ gml:name = GUNTHORPE FORMATION ]>
Updated to same version of PostGIS, so not that…
Action:
- torben will repost to email list
GeoTools Java 11 Test Failures
Caused by a difference in how Fonts are rendered between Java 11 and Java 8. Requires a change in the test tolerance. Do we need Java 11 reference images? Hopefully not as font rendering changes across operating systems.
Action:
- Andrea has relaxed the tolerance 10% … looks ike it now passes
Sys Admin
Build server discussion, reducing to one slave to reduce operation costs.
SAC has changed download.osgeo.org - we use for webdav currently and the maven deploy “wagon” for webdav is unsupported?
Any interest in setting up Nexus or Artifactory?
Action: Jody will continue to pursue maven repo for GeoTools, has reached out to osgeo projects.
Security Topics
Security incoming:
Some new reports came in from Gremwell
A good idea on one of them
Remaining items require funding …
GitHub is reporting vulnerabilities in dependencies
How to fund security fixes:
Currently depend on custom or product interest in fixing
Those reporting bugs show no direct interest in funding fix (they already funded QA check and are thus contributing …)
Not sure about “Donation” button for OSGeo or “sprint” style sponsorship
Tends to under value open source
Treats security like a charity concern rather that than a core value
Discussion on how QGIS and SAC does small contracts
Check if this interrupts business model for those selling GeoServer support
Action:
Distribute via OSGeo similar to how SAC operates where … available developers is the constraint
Adding to “fund” get visibility into security email list as issues are reported
Can address via commercial support (fast lane)
Wait for fund to afford a small contract (slow lane)
Deprecation effort update- GeoTools ready, green: https://github.com/geotools/geotools/pull/2309
Idea: QA page mention how to deal with deprecations
JTS update? Jody did not get back to that …
GeoWebCache ready, green: https://github.com/GeoWebCache/geowebcache/pull/747
GeoServer still needs java 11 deprecation handling: https://github.com/geoserver/geoserver/pull/3449
Use suppress warning if you cannot dodge (example implementing a deprecated method)
@SuppressWarning(“deprecation”)
Java 8 fix? new Integer(int) → Integer.valueOf( int )
Issues found in deprecation:
Deprecated methods/objects with no comment and no replacement
Deprecations in impl classes but the interface mandates the method without deprecating it
Deprecations pointing to replacement that are also deprecated and with no replacement
" * @deprecated Replacement to be determined."
Deprecating API, providing replacement, and leaving hundreds of calling points in the codebase, losing the best occasion to check if the deprecation and replacement actually make sense.
Deprecated with replacement indications making no sense. Remember to be clear, deprecation is not a reminder to yourself but something affecting users which need to move to a non deprecated approach.
Deprecated because normally it should not be used, but there are some legit cases to do so… just add a comment for it instead of deprecating
Deprecating a method because maybe in the future you will remove it (there were such deprecations 10+ years old, face it, you’re not clarvoyant)
GeoTools Care and Feeding
Dependency updates:
JTS upgrade was left out of 1.15.0, wait for deprecation PRs
Units library upgrade from email, for master only …
ImageN may be ready this release cycle …
Process API stable?:
Core API is map based (input and result maps, process descriptors) and is quite stable
RenderingTransform API interface describes “invertability” that is not captured in the process descriptors
Discussion of using a bean (with annotating attributes rather than annoting a function)
Approach is fine, we can make a factory for that, but does not change the core Process API
