GeoTools / GeoServer PMC meeting - 2019-05-14## Attending
Torben Barsballe
Ian Turton
Jody Garnett
Jukka Rahkonen
James Hughes
Andrea Aime
Kevin Smith
Actions from Last Meeting- Torben to check potential missing OGR package [DONE]
Torben will repost PostGIS build failure to email list [DONE - no response]
Andrea will raise Java 11 test tolerance for GeoTools build [DONE]
Jody to take “geoserver security” idea to mailing list [DONE- no response]
Jody will continue to pursue maven repo for GeoTools, has reached out to osgeo projects. [DONE - no response]
Agenda- Build Server
Release
ImageN Update
Cross project PR checks
PR templates
Switching from Jira to Github for issue tracking
Chit chat
Actions
Torben: Report back to Mailing List about Nightly Build status tomorrow
Jody: Talk to OSGeo about setting up a forum (Discourse?) on OSGeo hardware for discussion (done #2306)
Build Server
Build server in maintenance, taken offline and being rebuilt using Jenkins 2. Taking longer than estimated (to set up mavn, java, etc…).
Blocking:
Nightly builds is the real pain point keeping all PRs from being merged
Can we prioritize just this point as a blocker? “yes”
Twitter complained about not having access to community module builds (huh!)
Options:
Consider balancing this across GeoSolutions / OSGeo hardware?
GeoSolutions offers dedicated hardware for nightly builds.
OSGeo could also provision hardware (and may have some already).
Jody: To ask what is available.
Scale back to only compile community modules, make it obvious in docs that you need to compile this stuff yourself → noope!
Note these downloads are transient were not really expected to be kept
Release
Release next week? May 18th +/-:
Blocked by Build Server!
May 16th: Kevin, James Hughes (requests backup), Torben helps with build server
If not we will have to reschedule when build server is available
James is looking at the jira release script during the sprint.
Initially adapt readme instructions?
release notes? Edit file before you make the release.
May consider porting the geoserver release script for GWC?
- Kevin is comfortable with the Ruby Script, but hard for others …
GeoServer website release automation ideas / discussion.
ImageN Update
Code base is up:
IP review ongoing:
Update is a search and replace to change package names, and everything else compiles.
We need to coordinate this across our roadmap.
Q: How to handle JAI-EXT?
Option 1: Search and replace on master, subsequent releases use ImageN
Option 2: Add an imagen-ext module to ImageN project
Roadmap research:
- Make a branch on all the projects and try it out
Q: JAI SPI?
- One method that registry everything …
Q: How is it working on Java 11?
- It does not compile, when it uses Java 8 classes those codec
Codecs:
Are in a seperate jar, we would make that only work in Java 8
Java 11 already has a TIFF codec
Q: How to handle classses JAI with static methods?
Options A: Keep JAI as is (a bit odd but it is done already!)
Options B: Make ImageN, and then make JAI extend ImageN (and deprecate JAI).
Q: tutorials and examples
- We got it - https://github.com/eclipse/imagen/pull/11
Q: ImageN stuff to go out?
Not in general as we want an open source copy
Specifically looking up internationalization in the jre/ext folder ← need to remove
Remote is based on RMI ← keep for those migrating?
Renderable ← keep for those migrating?
Q: JAI-EXT functionality to go in now?
concurrent registry
based on Java stuff ← read write locks!
title cache is slow
based on synchronized
Switch to Java concurrent would be the key improvement
new concurrent tile cache?
Uses Google Cache Concurrent
import com.google.common.cache.Cache;
import com.google.common.cache.CacheBuilder;
import com.google.common.cache.RemovalCause;
import com.google.common.cache.RemovalListener;
import com.google.common.cache.RemovalNotification;
import com.google.common.cache.Weigher;
performance is much better under concurrent load
scales a lot better under concurrent load
cleans up the titles from a specific image much faster
If we had a build server we could set this up …
discussion covering how difficult this is:
Need a geotools PR to be tested in GWC and GeoServer
Example from Checkstyle https://github.com/checkstyle/checkstyle/pull/6762 (uses Circle-CI for regression testing)
James is considering looking at that this week …
PR templates
What are PR templates?
https://github.com/geoserver/geoserver/pull/3490
Twitter feedback that we make it too difficult …
Mailing lists are too old, request forum that they do not need to sign in …
Move to stack exchange? We are already https://gis.stackexchange.com/questions/tagged/geoserver
That is a Q&A format so not quite the same
Not flooded by email (like user list)
Want to make the question without any delay
OSGeo hosts NextCloud (which does offer Forum)
Also folks expect a chat (like slack or gitter)
Twitter also offered to set up a forum https://discourse.mozilla.org/
New account to report bug on Jira is too difficult …
Can we make it use OSGeo user id ← probably longer delay? Bad idea …
Assume folks have a GitHub account github issues may work
GitHub issues did not allow attachments previously
GitHub issues now support attachments (this was a blocker):
White list of file types (images, pdf, zip)
25 MB size limit
Offer of 5 days to port issues …
Discussion:
At least we are not IRC
We do not really need more “participation” we need more “developers”
Andrea is not sold, but not totally against …
Action:
- Jody ask osgeo about hosting forum software (#2306)
Chit chat
Happy Tuesday everyone…
