[Geoserver-devel] GeoTools / GeoServer PMC meeting - 2019-06-11
Attending
Torben Barsballe
Jukka Rahkonen
Jody Garnett
Kevin Smith
Actions from Last Meeting- Blog post Join the GeoServer team at FOSS4G 2019 Bucharest
  • Jody will look into private repo for geoserver organization.
  • Looks like $7 a month “pro” account for our gtbuildergh
  • Jody will start in on release scripts next week in a limited capacity [WIP]
  • Torben - Build Server - PostGIS [Done], CITE, GeoTools cert [Done]
Agenda- build server update
  • Release
  • ogc hackathon next week
  • security
  • pull request roundup
Actions- Torben: Restore build server email updates
  • Jody: Private repository will go pay $7 a month just to get it done
Build Server Update- Workers ran out of disk space and blew up
  • Andrea turned off email updates? Can we turn that back on…
  • PostGIS is passing
  • Oracle - test was failing, any interest in restoring
  • not going to restore unless we have a volunteer to fix
  • drop down to community module?
  • SQLServer - test was failing, any interest in restoring
  • CITE tests - in progress?
  • no update from Andrea
  • Windows box, no update …
Release
Maintenance Release May:
GeoTools / GeoWebCache - completed manually last week
GeoServer - in progress
  • will try via build server
  • unsure if windows build box will be ready in time
Stable release June:
  • Torben has some availability
OGC Hackathon next week
Andrea is attending in person:
  • Any update?
Jody is attending remotely:
  • It is only two days, not really worth traveling …
  • Intends to focus on geotools client for “new” protocols
FOSS4G Prep- See blog post for activities
Security- Discussion of use of GitHub security advisories, to communicate with downstream projects
PR Roundup- MapML preview - needs docs :slight_smile:
Waiting on geotools/geotools#2426
I think we will need to ask Andrea as owner of gtbuildergh to create pro account + private repository.
Sidebar: team account for geoserver … amounted to $9 per user per month, or $404 a month :slight_smile:
Why do we need that? And who’s paying?
I set up the account as a courtesy, but someone else can set up a similar one too.
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Build Server Update
  • Workers ran out of disk space and blew up
I sent a mail with instructions to turn back on, just need to add back the smtp server host name.
Are we in a position to turn them back on? Unclear from the meeting logs.
What fails and how? To my knowledge there is a single 3D related test failing that can be set to @anonymised.com
Recently tested on an Oracle 12c.
I hope this is a joke.
Same as above
I did not look at them, not sure when I’ll have them time. The people that denied a CITE upgrade code sprint for years should
probably look into it, the current CITE infrastructure is something nobody is up to speed with.
  • Any update?
Using my spare time to see if I can setup a annotated support for OGC API services (Spring MVC like) without having to break
the rest of GeoServer in the process. So far it’s just on paper, I hope to try out something next weekend, but it’s
not very likely, as my daughter has to go through a bunch of school exams these two weeks.
Given I’ll be there with my under-powered Windows notebook I’ll probably try to participate with the most
effective way, which is, taking part to as many meetings as possible, coding as little as possible.
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Tried to check the logs, there are none? Just an indication that the build is turned off.
It was failing on the previous Jenkins instance, and I’m pretty sure it had been failing for quite a while with no one caring. Looking at the history of the job on the mailing list, it was consistently failing around May 2018, until someone disabled the job. I don’t know if it ever got restored after that - I don’t see any “Build is back to normal” mails after the last failure, so I don’t think it did…
We don’t have Oracle or SQL Server set up against the new one yet (and the old logs aren’t readily available). If no one cares enough about those extensions to fix the failing builds after a year, I’m not sure how worthwhile it is to actually spin up Oracle and SQL Server instances to test against.
Torben
On Tue, Jun 11, 2019 at 2:29 PM Andrea Aime <andrea.aime@anonymised.com> wrote:
On Tue, Jun 11, 2019 at 10:25 PM Andrea Aime <andrea.aime@anonymised.com> wrote:
We would like to version some of the build configuration in a private repository. We can make a PSC motion to expense it too OSGeo.
Yes of course.
Hi Torben,
as said I’ve been running the Oracle test suite this week while I was fixing the issue with the prepared statements dialects and
got a single failure, which could easily be marked as ignore. Is one failing test that can be ignored ground for for not setting
up the build again?
The SQL server one I have not run in ages, tried quickly but could not get remote connections running (tried several guides,
still not working, not sure where the issue is). May try again later down the road, I’m going through a couple of difficult
weeks right now.
On Wed, Jun 12, 2019 at 12:00 AM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Hi Andrea,
If people are actually going to pay attention to the tests and disably/fix them where applicable, then yes, it seems perfectly reasonable to try and get them running.
My point was - last time they broke, around a year ago, no one seemed to care enough to do so, and no one tried fixing them in the intervening time either. So if thats just going to happen again, then an Oracle instance isn’t that useful.
Torben
On Tue, Jun 11, 2019 at 11:17 PM Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Torben,
up the build again?
weeks right now.
Torben
What fails and how? To my knowledge there is a single 3D related test failing that can be set to @anonymised.comnore.
I’d like to know if Oracle fails. It’s not about caring per se, my “maintainership” just extended well beyond my limits, to the point that a “I’ll do it later” might as well mean “one year later” or worse.
If I mark that test as ignored or fix it, would you setup the tests again?
Hi Andrea
Yes, as long as there is actually interest in the test, then I can look into getting it set up.I can’t give any useful timeline for when the oracle test will be up and running, as acquiring an oracle instance is going to be a bit more annoying than PostGIS (and getting the windows build box up is probably higher priority).
Torben
On Wed, Jun 12, 2019 at 9:44 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
On Wed, Jun 12, 2019 at 6:24 PM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hi Andrea,
Agreed. If it’s any help, I’ve been successfully running a docker image, much easier to setup that other means I’ve tried in the past.
I believe I’ve followed this article, but it’s been months, not 100% sure:
https://dzone.com/articles/oracle-12c-image-installation-in-docker
A docker image could be much simpler - I’ll look into it, thanks.
Torben
On Wed, Jun 12, 2019 at 10:10 AM Andrea Aime <andrea.aime@anonymised.com268…> wrote:
On Wed, Jun 12, 2019 at 6:51 PM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hi Andrea
