[Geoserver-devel] GeoTools / GeoServer PMC meeting - 2019-06-25
Attending
Torben Barsballe
Kevin Smith
Jukka Rahkonen
Jody Garnett
Andrea Aime
Actions from Last Meeting- Torben: Restore build server email updates [DONE]
  • Jody: Private repository will go pay $7 a month just to get it done [Won’t Do]
Agenda- Travis CI - JDK 11 builds failing
  • Build Server - Repository, Cite Tests
  • Report from OGC Hackaton and ogcapi module
  • CITE Test Upgrade planning/interest
Actions- Jody: CITE Test upgrade page & proposal
https://travis-ci.community/t/install-of-oraclejdk11-is-failing-11-0-3-12/3887
We basically will just need to wait for Travis to fix the issue.
Q: How do we want to handle backports / etc while waiting for a fix
A: Merge it if it is important, and let Jenkins verify
Build Server
Mostlying work :slight_smile:
  • CITE still needs love
Release:
  • Torben will update release scripts while doing the 2.15.2 release this week
Q: Push compiled binaries to GitHub?
A: No, SourceForge has better metrics.
Online Tests:
  • AppSchema broken - geotools PostGIS DB user needs elevated permissions
  • Oracle, MySQL - Pending availability
Report from OGC Hackathon and ogcapi module
London:
  • ogc features api - template used by others (formally wfs-3…)
  • ogc maps and tiles api - may show up as one or two services
  • ogc coverage api
  • ogc processes api
  • ogc catalog api - or records …
Each protocol:
  • tiny “core” + “extensions”
  • core:
  • feature - notion of collection
  • filter on space and time
  • filter on attribute - only do equality comparison
  • CRS:84
  • huh: no required output format …
  • huh: no schemas … yet :slight_smile:
  • extension:
  • html, gml, geojson
  • described by open api documents that link to each other …
  • clients:
  • dynamic from open api document
  • generated from open api document
  • following links that have well-known relationships
Caution - not ready to implement yet
  • only ogc features api has a spec right now
  • everything else is ideas and test-bed prototypes
Suggestions in engineering report:
  • Suggest filtering using (E)CQL the way GeoServer does it
  • Consider: filter general on any attributes VS declare upfront attributes that are queriables
  • anything else is more than a month old …
Other activity:
  • processes group was active and tried implementing their ideas
  • map and tiles
  • considering adding as an extension to features or coverages (to visualize)
  • vector tiles? An add on for features … see wfs3 prototype
  • But what about process output etc…
  • But what about only doing maps (no feature or coverage access)
  • STAC tried to get compatible with wfs3 so no idea if they are going to keep pace …
  • Limited overlap with ogc coverage api? …
  • community module ogc api started
  • new dispatcher similar to spring MVC one … and still supports dispatcher callback and thread locals “geoserver” approach …
https://github.com/geoserver/geoserver/blob/master/src/community/ogcapi/src/main/java/org/geoserver/api/features/FeatureService.java
Updated the maintenance wiki page:
Any feedback or can we have a vote and start this?
This is of course tentative pending any party expressing interest….
Discussion:
  • ogc provides docker image for cite tests
  • Needs a minimum of orchestration to setup cite test image and geoserver image
  • This kind of means planet federal has the access needed to set this up with jenkins
    (so deployment may not be part of contract phase…)
  • Idea: overlay geoserver over ogc cite docker image
  • Idea: use official cite engine, would require cite test geoserver image to be internet accessible …
Action:
  • Jody: update CITE-Test-Upgrade with above options (docker …)
  • Jody: make a proposal for PSC to approve starting this …
