[Geoserver-devel] GeoTools / GeoServer PMC meeting - 2019-07-09
Attending
Torben Barsballe
Ian Turton
Andrea Aime
Kevin Smith
Jody
Actions from Last Meeting- Travis CI - JDK 11 builds failing [FIXED]
  • Build Server - Repository, Cite Tests
  • Report from OGC Hackathon and ogcapi module (discussed)
  • CITE Test Upgrade planning/interest (did not see action here?)
Agenda- 2.14.5 Release
  • Build server instability
  • EPSG database update
  • FOSS4G talks and workshops
  • Azure blobstore
Actions- Torben: Disable colored output in Maven
2.14.5 Release
Ian as release manager, Andrea as sidekick to build GWC.
2.15.x nightly failure: https://build.geoserver.org/view/geoserver/job/geoserver-2.15.x-nightly/163/console
2.15.x java 11, missing classes:
https://build.geoserver.org/job/geoserver-2.15.x-java11/184/console
Causes for the two above currently unknown.
Weird output, probably related to colored output. See also https://issues.jenkins-ci.org/browse/JENKINS-44543
We’re on 9.6 on master.
What about backporting the database update? Yes, no? Let’s talk about it in a month.
Will ask on the user list for tests
Schedule: https://2019.foss4g.org/schedule/presentations/
  • schedule is moving around a bit still
  • andrea is double booked :slight_smile:
Labs:
  • Introduction to OGC services, with examples from GeoServer
  • Thu 4:00 pm - 5:30 pm
Presentations
  • State of GeoServer 2.16
  • Should release an RC by about then :slight_smile:
  • collaborate on google doc
  • Action: Jody make a copy from 2.15
  • GeoServer Feature Frenzy
  • Existing talk based on chat from user list, example Oracle
  • Or pull together functionality with we think is fun/exciting/cool
  • Action: Jody create a copy from prior presentation
Workshops:
  • Documentation Workshop
  • teaching from GeoServer documentation guide
  • QGIS and GDAL also using sphinx
  • Discussion:
  • CC not mentioned in sphinx-footer
  • Update sphinx theme for GeoServer to be a read-the-doc clone as per GDAL code-sprint update
  • Also: https://github.com/OSGeo/gdal/pull/1579
  • GeoTools Developer Workshop
  • Is in good shape
  • GeoServer Developer Workshop
  • IDE/Setup challenges from FOSS4GNA
  • Add a section for ResoruceStore use
Azure blobstore
New blobstore for GWC to store tiles in Azure blobs. Careful about:
  • Deletions, to delete each blob one has to issues a separate request
  • Deletions are just “marking for deletion”, recreating the same blob/container right away will fail
On master, add it to the war, on stable available but not included by default.
Maven color keycodes in Jenkins seem to be successfully disabled now (via MAVEN_OPTS=" -Dstyle.color=never")
On Tue, Jul 9, 2019 at 10:40 AM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Attending
Torben Barsballe
Ian Turton
Andrea Aime
Kevin Smith
Jody
  • Azure blobstore
2.14.5 Release
Labs:
Presentations
Workshops:
  • Discussion:
  • Is in good shape
Azure blobstore
Excellent thanks Torben!
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
