[Geoserver-devel] GeoTools / GeoServer PMC meeting - 2020-07-21
Attending
Andrea Aime
Torben Barsballe
Jody Garnett
Kevin Smith
Gabriel Roldan
Actions from last meeting:- N/A
Agenda- Release Update
  • CITE Testing
  • Unchecked warnings cleanup/diamond
  • Gabe update in microserve experiment
Release Update
Release announcements:
Release was uneventful, which was great.
Also updated geoserver website to remove foss4g 2020 and fundraising note.
CITE Testing
There is a big PR to review:
General feedback:
  • devops focus on server
  • weaker for local testing
  • May be hard on windows (due to use of docker on windows being hard to setup)
Notes:
  • This is large for github, you need to checkout locally to review
  • Q: Are their instructions for the developers guide?
Action:
  • Jody to test this on macOS (where docker should function)
  • Ask on the email list for windows test, and any instructions…
Planning:
  • distributed code sprint to actually pass the tests, during the fall?
  • Jody has some time and can set this up
Group QA activity from last meet, idea/inspiration from Andrea :slight_smile:
Now a public branch:
Approach:
  1. Clean up warnings module by module
  2. Use diamond this is a good way to get involved in GeoTools, making the codebase much easier to read :slight_smile:
BEFORE:
List properties = new ArrayList();
FIX:
List properties = new ArrayList<>();
Gabriel update in microserve experiment
Working on camptocamp repository: https://github.com/camptocamp/geoserver-microservices
  • Break out into docker per service
  • Going to try JMS with JDBCConfig / JDBCStore (for diskless)
I noticed in testing the final war that … it was much bigger than previously.
Turns out a xsd transitive dependency was bringing in everything to allow it to operate as an eclipse plugin.
Since we do not generally want GeoServer to include an IDE I have reverted the change:
I was also annoyed and opened up a bug ticket to ask if xsd is still available as a library (it seems to be under quite active development as an eclipse plugin).
Thanks to James for joining the hunt to figure out the transitive dependency issue and help determine a course of action.
Jody Garnett
