Attending
Andrea Aime
Jody Garnett
Jukka Rahkonen
Torben Barsballe
Kevin Smith
Actions from last meeting:- [DONE] Torben: Vote on Datastore Parameter proposal
- All: Volunteer for releases - [DONE] 2.18.1 in November, 2.17.4 in December
Agenda1. Travis CI replacement
December release volunteer
Unchecked branches status update
Java 11 modules units issue
Releasing or fixing an old branch
Actions- Jody: Create Ticket/Wiki for tracking Travis CI replacement
https://github.com/geotools/geotools/wiki/Migrate-Travis-builds
- Andrea: ask for a December release volunteer on list
Cost of using Travis CI vs cost of migrating builds.
What do we need to migrate:
GeoServer → java 8, java 11, and QA builds
GeoTools → java 8, java 11, and QA builds
Linux environment available in github actions so this can be migrated
These should be “simple” to migrate, nothing complicated
GeoTools database builds
sqlserver, oracle, mysql 5, mysql 8
GeoServer documentation build
requires sphinx, so “not simple”
GeoTools documentation build
Note: unlikely to be effective, as sphinx not installed
GeoServer package build
Should be “simple” to migrate
Options:
Pay Travis
We have budget, we could look at value for paying
github Actions
Databases make of well-known service “postgis service”,is there an equivalent for Oracle, sqlserver and mysql 5/8?
Also worried about using only one tool, and everyone is switching to them.
Jenkins
The approach of adding a jenkins pipeline build to repository is important to allow anyone to work on this
Circle CI, we have had mixed success with the Windows build, and there is a time limit (think 50 minutes). GeoNode is using CircleCI. Apparently we’d get 4 concurrent builds for Linux.
Azure Pipelines is also an option.
GDAL migrated to GitHub Actions with https://github.com/OSGeo/gdal/pull/3194 and https://github.com/OSGeo/gdal/pull/3198
https://github.com/geoserver/geoserver/wiki/Release-Schedule
Need a volunteer. Let’s ask on the list.
GeoTools: merged! Instructions here: https://docs.geotools.org/latest/developer/conventions/code/qa.html#javac
GeoWebCache: merged!
GeoServer: ongoing. https://github.com/geoserver/geoserver/pull/4567 Andrea currently working on WFS. EMF models source of warnings as collections have no generics in place, for the time being, they are being suppressed (IntelliJ seems to have a cleanup removing unnecessary annotations, if we fix the EMF models later).
GeoTools Java 11 modules units issue
Coming down to NetCDF use of units preventing startup:
Previously a hack using reflection was used to configure a DefaultFormatter
We need a new approach
Ongoing PR (breaks existing tests, removes code that can parse NetCDF units)
https://github.com/geotools/geotools/pull/3232 (nope!)
Some notes on how to possibly handle it in the javadoc of the class:
And in this ticket:
https://osgeo-org.atlassian.net/browse/GEOT-6709
https://github.com/unitsofmeasurement/uom-se/issues/201
We updated to Indriya 2.0.2 earlier in the year:
Discussion:
Can this fix be confined just to netCDF? I know units are used in more locations …. Nope.
GeoToolsUnitsFormatter may need to wrap, rather than configure, … but may not have required visibility access
Need someone familiar with units to do the job, might need funding
Given funding it’s not a problem, it’s just not easy given how many things changed.
Jody would like to release:
GT 19.x / GWC 1.13.x / GS 2.13.x
I do not want to bother folks with pull-request against these
Some build changes to osgeo repo needed
Q: Do we backport between all the releases? 22.x, 21.x, 20.x … 19.x?
Not needed, PRs to 19.x can be clear … anyone needing 20.x can cherry-pick if needed to get that branch to build again also.
