Attending
Andrea Aime
Jody Garnett
Kevin Smith
Torben Barsballe
Actions from last meeting:- [In Progress] Torben: Write dependency backport details a bit more clearly in our developer guide
Agenda1. Getting ready for 2.19 release
gt-http client
Budget
Cleaning up modules: arcsde, s3-geotiff
XML cleanup
CITE tests update
ActionsN/A
Looking at https://github.com/geoserver/geoserver/wiki/Release-Schedule
Marked down for March 1st, Jody plans to take a revision and setup the new branches and build jobs. Please get any changes in before this date
Much improved with release bundling being part of the build checks now
Any community modules ready to be extensions?
Jody will check about geopackage again (waiting on customer interest, so if you care speak up)
Jody would like to remove gt-validation (it is already done from test clean up branch)
gt-http client
The pr is active:
Addressing split package issue last week
We want to get this ready asap as it’s blocking the other cleanup branches
Maven related build failures
Experiencing a number of failures due to Maven jar downloads.
Jenkins geoserver master failure, restarting, …
Mark/Brad already tried to reconfigure wagon-http for Azure, does not seem to be enough:
Disable connection pooling fully?
Shall we split the workflows so that we can restart one build at a time, e.g.: https://github.com/geotools/geotools/blob/master/.github/workflows/linux.yml
https://github.com/geoserver/geoserver/blob/master/.github/workflows/linux.yml -
We might be able to create a workflow template so that we can share configuration between workflows after splitting up: https://docs.github.com/en/actions/learn-github-actions/sharing-workflows-with-your-organization#creating-a-workflow-template
Not sure if this will actually work - it seems to be more aimed at sharing workflows between projects, but we may be able to adapt it to our needs
Small fix to ensure ~/.m2/repository used consistently applied to linux.yml, same needed for macos, and windows build should use what?
Budget
Budget request sent to OSGeo:
In general osgeo is providing less funds this year:
- Looks like 2k for projects that requested funds, 500 for those who did not email
Q: Should GeoCat end proposal for windows installer? A: yes
Cleaning up modules: arcsde, s3-geotiff, script
Already discussed about dropping arcsde support completely. → +1
JoshFix/GeoSolution “cog” improvements for image mosaic replacement is taking over from s3-geotiff. Can we remove s3-geotiff community module → yes
Remove gs-script as unmaintained.
XML cleanup
Mark proposed format cleanup proposed, similar to code cleanup.
Autoformat xml files
Yes: pom.xml and perhaps spring context files
No: xml schemas (use direct from ogc)
Proposed formatter does a dom based pretty print:
Get comments, but new-lines get removed
Use comments if we need to separate blocks of xml
Consider search replace multiple newlines with a comment
creates , tabs → 4 spaces
Try out eclipse formatter as an alternative
Would allow greater control, perhaps preserve newlines
CITE tests update
Believe we managed to pay GeoSolutions the remainder of the contract at the last day of 2020.
- Andrea will confirm
Scheduled to resume working on this next week.
Chit chat- varargs: https://github.com/geotools/geotools/pull/3317
Array of Object is fine - great!
Caution for array of primitives
Looks great for feature visitor
These are going to make for a great geotools release
Do we need to make a note in the update instructions?
Perhaps a code example
For inlined code examples the refactor will have already fixed them
