GeoTools / GeoServer PMC meeting - 2021-02-16### Attending#
Kevin Smith
Torben Barsballe
Gabriel Roldan
Michel Gabriel
Andrea Aime
Jody Garnett
Jukka Rahkonnen
### Actions from last meeting:# - None### Agenda#
2.17.5 release without manager
Adding 2x gridsets to GWC
ogc/osgeo/asf sprint pre-planning
Installer GSIP
ServiceProvider GSIP
GeoServer-Cloud project
Pull-request roundup ahead of release candidate
### Actions#
Gabe/Jody to have a relaxed release of 2.17.5 (over the weekend?)
Kevin: Review GWC Gridset x2 pull request
Jody/Gabriel: Write up GSIP for GeoServer-Cloud project
Torben: Try zhCN translation to see if it is published
Sent a mail to the list asking for help
Jody is doing 2.19-RC, asking for Andrea to help with blog post
GeoSolutions can do 2.19.0 final
Gabe/Jody to have a relaxed release over the weekend ← thanks Gabe!
Action: Gabe to answer email thread
Adding 2x gridsets to GWC#
Review:
Introduce 512px tiles as a possible alternative for the default gridsets
Does not change resolution, only tilesize, so fonts will be small
In GeoServer, DPI is format option, not a full parameter for gwc to pick up on this
GeoWebCache has an open issue to support GeoServer’s DPI format option
Action: Kevin to review this PR
This is a minimal PR, it would be nice to do the default ogc tilesets but that will be for later:
- there is an open ticket for gridset alias on this topic
ogc/osgeo/asf sprint pre-planning#
Tomorrow starts with meetings:
Sprint 101 intro 7-9 am
Product Patch: 5 mins on what we want to do, Andrea
Andrea working on ogc-api-maps, general cleanup
Also MapML plugin
Jody getting in the way, or otherwise be helpful
will write tests cases and developer docs if otherwise ignored
Can we make json testing better
Michel ogc-api-maps, theming font-end, …
Map preview, breadcrumbs, customize styling
Freemarker templates, need to figure this out
Template in src code right now landingpage.ftl
contrast with getfeatureinfo which is dataset/workspace/instance specific in the data directory
Todo: check data directory workspace for landingpage.ftl as well
## Installer GSIP-198#
https://github.com/geoserver/geoserver/wiki/GSIP-198
Discussion on difference wrappers?
Java Service Launcher, 64-bits is proposed
This is public domain, so free to distribute, …
https://github.com/geoserver/geoserver/wiki/GISP-199
Discussion direction:
Contributor agreement, pull-request, bug report …
Relax description to allow for participation on more than just coding level
User list participation, stack exchange etc…
Writing documentation
Consider tagging providers: “core”, “coding”, “docs”, “user-list”, … ?
Make this align with Ian’s presentation on particpation
Q: About individual consultants?
A: Just send a PR request on how you want to be listed…
## GeoServer-Cloud project#Review of project:
CLA is going to be provided by C2C (yay)
v.02 released, available for quick start tests
https://github.com/camptocamp/geoserver-microservices/releases/tag/v0.2.0
Q: Project name? Cloud? microservices?
“cloud native geoserver” may have some confusion
package org.geoserver.cloud presently
Consider microservices? Not all approaches use this (lambdas etc…)
Proposing one of:
Q: How to contribute to GeoServer github group?
See email discussion following geofence example
GSIP or email? Don’t care …
If you do a GSIP can be simple / short …
Process is OSGeo Software Grant signed by camptocamp
Action:
- Jody and Gabe to write up a GSIP for the record
## Pull-request roundup ahead of release candidate#
GeoTools: https://github.com/geotools/geotools/pulls
https://github.com/geotools/geotools/pull/2804 this is stuck again, will benefit from allow-list / block-list, …
https://github.com/geotools/geotools/pull/3152 mbstyle doc update, better than what is there now
https://github.com/geotools/geotools/pull/3338 geojson library change from Ian?
Check with Ian … and perhaps James?
Andrea will try for varargs api change
GeoWebCache: https://github.com/GeoWebCache/geowebcache/pulls
https://github.com/GeoWebCache/geowebcache/pull/924 discussed above
https://github.com/GeoWebCache/geowebcache/pull/893 update maven repositories
Jody to rebase and update Pr
https://github.com/GeoWebCache/geowebcache/pull/844 Enable setting of title, abstract and keywords on Grid and GridSet
From march 2020, waiting on review …
GeoServer: https://github.com/geoserver/geoserver/pulls
Other translations got deleted due to neglect …
sphinx has built-in support for internationalization …
docs.geoserver.org/zhCN/index.html ← is this where it would end up?
Language is in the URL, so it should copy over …
Action:
Torben: merge and see if shows up …
The PR is broken, so this is stuck …
Add standardDeviation classification for raster in sldService module
Waiting on update …
https://github.com/geoserver/geoserver/pull/4483 Basic Auth external services
review and no followup …
Work still ongoing … some of the optional tests are not working (the newer tests…)
See WIP jobs here: https://build.geoserver.org/view/testing-cite-new/ (ets-*)
QA tests for geoserver should arrive shortly and make release candidate
