[Geoserver-devel] GeoTools / GeoServer PMC meeting - 2021-03-16
Attending
Kevin Smith
Torben Barsballe
Andrea Aime
Jody Garnett
Actions from last meeting:- [DONE] Jody/Gabriel: Write up GSIP for GeoServer-Cloud project
  • [DONE] Torben: Try zhCN translation to see if it is published
  • Release blog post - Start a branch / pr to work on this
Agenda1. Meeting Time change for next meeting
  1. Freemarker upgrade backport
  2. Backporting 512px gridsets, backport
  3. SortPom, third time’s the charm?
  4. 2.19.0 release in two days
  5. Packaging/assemblies, how to make that better
  6. Chit chat
Actions- Move meeting time discussion to mailing list
Move it back one hour (To 16:30 UTC) as we usually do?
Andrea: +1
Torben: +1
Kevin: +1
Jody +1
Continue discussion/voting on list
Discussion: Should we try to switch to a different time zone with daylight savings time built-in?
  • No, several countries are proposing getting rid of DST, so anything we put in place would likely have to change soon anyway.
  • UTC is always clear anyways.
Some nice improvements, but some folks may need to update templates (for backwards compatibility).
Strictly additive change, not shown by defaults.
Jody +1
Kevin +1
See email for ongoing saga …
Please do this just to fix tabs vs spaces :slight_smile:
Q: Brad asks about 2 spaces vs 4 spaces
Sidebar for applicationContext.xml formatting:
  • Checking “spotless” to see if it works with parallel build?
  • Most applicationContext.xml files uses 4 spaces…
Andrea, Jody, Kevin, Torben → 2 spaces everywhere for XML files (all XML files)
Q: Any last moment changes incoming?
  • Not that we are aware of…
Q: Is any help needed?
  • Blog post from last time should be good …
Q: Were all the packaging issues address?
  • We think so, but worth checking pre-release artifacts
Discussion:
  • Windows installer will show up later, using whatever the latest release is
Packaging/assemblies, how to make that better- Packaging side on GeoCat side improved
  • Markdown in HTML
  • Logo in SVG
  • GeoTools
  • Use JTS style ant script to run the quickstart in the release.
  • Extensions: recent extensions broke other extensions …
  • proposals: Move assemblies to the individual extensions to make things self contained
  • Multimodule extensions will need to determine which submodule to host the assembly descriptor(s) on a case-by-case basis
  • How to copy all the zips to release folder?
  • Use copy-resources maven build step to releases/pom.xml
  • Copy from extensions//target/<bundle.zip> to release/target/<bundle.zip>
  • Can we add integration testing? ← yes
  • Maven integration test step does this
  • Examples using jetty on how to do this (usually used to test multiple wars working together)
  • Reference pre-integration-test, integration-test, post-integration-test stages
  • Do this after extension makes package, to verify it works in a jetty integration test
  • Can we avoid transitive when functionality moves to core
  • For example when geopackage moved to core …
  • For example when jackson moved to core …
  • Difference between:
  • moduleSets - some ability to exclude modules here
  • dependencySets
  • fileSets
Chit chat- Cloud First GeoServer is now setup
  • Congrats Gabe and camptocamp
  • https://github.com/geoserver/geoserver-cloud
  • http://geoserver.org/geoserver-cloud/
  • The github pages needs some theme to look pretty!
  • foss4G Presentations anyone?
  • Deadline the end of the month, who is up for some geotools / geoserver presentations?
  • State GeoServer
  • GeoServer Ecosystems ← some case studies for biz track
  • GeoServer Orientation
  • DGGS - discrete global grid system
  • OGC API Presentation
  • Cloud First GeoServer ← talk to Gabe :slight_smile:
  • GeoPackage Improvments
  • AppSchema SMART ← community module Marco is working on
  • AssertJ discussion (just thinking out loud, no plan to actually do it in the short term)
  • Alternative to Hamcrest, which is no longer bundled with JUnit
  • AssertJ is a fun alternative that looks good
  • Nice fluent presentation with better output messages etc…
  • Some tools to migrate JUnit assert statements to AssertJ, no one found for Hamcrest
  • GeoServer 2.19.0 Docker?
  • Docker is setup, two pull requests active …
  • https://github.com/geoserver/docker/pull/1
  • https://github.com/geoserver/docker/pull/2
  • Any way to get this unstuck?
  • CITE Tests
  • Docker is setup, not sure what else is going on …
  • Jody / Juan available to help if more assistance is needed
  • M1 Rendering difference
  • Pattern along line is written in java code in geotools
  • So not java2d or opengl optimization …
  • Probably has to be with measurements
  • Code is deep in Java 2D Shape, trying to connect with prevision shape
  • Use git blame on failing test to locate the actual revision implementing
