[Geoserver-devel] GeoTools / GeoServer PMC meeting - 2021-07-06
Attending
Andrea Aime
Torben Barsballe
Kevin Smith
Jody Garnett
Actions from last meeting:- [DONE] Test windows installer
Agenda1. i18n GSIP update
  1. Backporting caching nearest matches fixes
  2. High cognitive complexity clean up, first pass
  3. geotools release bundle
Actions- Andrea: ask on list about backport of caching skip on nearest match or no match (and also on default value)
i18n GSIP update
https://github.com/geoserver/geoserver/wiki/GSIP-203
Status: done
UI and caps done
INSPIRE extension LANGUAGE KVP parameter implemented with translation, with property file to configure.
Added a function, called “language”, which reports the language chosen, along with recode allows to choose labels, or other things like symbols.
Possible to set default language at the service level too.
Backport, probably in a month, touched many files.
Not caching on nearest match or mismatch. Landed on master a month ago, now we would like to backport to 2.19.x. GeoSolutins has servers on master that haven’t misbehaved, and we also deployed a 2.16.x with the same changes.
New behavior is configurable, no behavioral changes if not enabled. Andrea to send a formal request on the devel list.
https://www.sonarsource.com/docs/CognitiveComplexity.pdf
Discussed previously:
The PR is here: https://github.com/geotools/geotools/pull/3569
  • First commit just adds markdown to html
  • Jody (with some encouragement from Andrea) had a go at removing jar-collector
  • moduleSet:
  • Only works during a complete package build to access live module list
  • Was hoping it could use module parent / child structure to direct
  • However very poor control over module by module dependencies
  • binaryDist.xml → gt-release-26-SNAPSHOT-bin.zip
  • dependencySet:
  • Some double handling, release/pom.xml needs dependency and then assembly
  • Has good control over what is packed where
  • binaryDist2.xml → gt-release-26-SNAPSHOT-bin.zip
Looking forward to Ian’s feedback on this one.
  • See release/README.md for testing instructions
  • unzip release/target/gt-release-26-SNAPSHOT-bin.zip
  • java -cp “gt-release-26-SNAPSHOT/lib/*” org.geotools.util.factory.GeoTools
Goal should be to be able to run the quickstart tutorials with just a bin download.
