Attending- Torben Barsballe
Andrea Aime
Jukka Rahkonnen
Kevin Smith
Jody Garnett
Actions from prior meetings:- N/A
Agenda1. GeoServer releases
Home page GSIP
GeoServer Doc Server (and more)
Backporting resource reset GSIP
Feedback from FOSS4G
Drop Java 8 (code sprint activity)
Actions- Volunteers for maintenance and RC releases
Jody: Home Page GSIP available as 2.22-M0 - send to user list for testing
Torben: Switch GS + GT docbuild to new server
GeoServer releases
New build server is up, it’s faster, and it has not released anything yet.
First release maintenance
Then release RC
The 2.22-M0 - worked so the new build server is working!
We need volunteers for both.
GeoSolutions may step up for maintenance, but before we need to backport the resource reset.
RC is waiting on the home page refactor.
Home page GSIP
Available as 2.22-M0
action: send to user list for testing
known issues
https://osgeo-org.atlassian.net/browse/GEOS-10636 ← something broken with login (and backported to 2.21.x and so on)
https://github.com/geoserver/geoserver/pull/6122
There are conflicts in CSS
Mark has provided feedback in a separate ticket: https://osgeo-org.atlassian.net/browse/GEOS-10634
May be related to Select2 javascript, which is provided by WicketStuff, which is already at the latest release for the Wicket version we have. Maybe fixable with CSS? In other places in the UI we expand the size of the dropdown based on contents, not always successful, might need extra margin or padding (adding them to the width, which in CSS includes the padding). We need to also set a maximum width and minimum width to avoid having too large dropdowns. -
idea: stack them vertical to take advantage of header height
idea: dynamically resize based on contents with a max limit (
Making an catalog api request while admin request thread locale is set … does not respect “read” permission and instead returns “false”
Solution was to abort the admin request thread locale; allowed page to talk to catalog like normal
Related CSS PR is also in progress: [GEOS-10556 / GSIP-213] https://github.com/geoserver/geoserver/pull/5984. Would be best to not do too much CSS tinkering until that can be merged.
Dynamic page update on select can be seen when setting the default style and updating the legend graphic - see implementation here:
LegendGraphicAjaxUpdater: https://github.com/geoserver/geoserver/blob/main/src/web/wms/src/main/java/org/geoserver/wms/web/publish/LegendGraphicAjaxUpdater.java
Called from WMSLayerConfig here: https://github.com/geoserver/geoserver/blob/main/src/web/wms/src/main/java/org/geoserver/wms/web/publish/WMSLayerConfig.java#L89-L100
world map “ne” workspace
any feedback on the styles (jody converted from ysld and got decent results)
action: ask about including the roads layer would add 2 megs? is that okay … would avoid rewriting
New docs added:
https://docs.geoserver.org/latest/en/user/webadmin/welcome.html#welcome - new page
https://docs.geoserver.org/latest/en/user/webadmin/index.html#web-admin - new headings, some things like language chooser moved to end of page
https://docs.geoserver.org/latest/en/user/gettingstarted/index.html#getting-started - new tutorials
https://docs.geoserver.org/latest/en/user/webadmin/about.html#about - new page
Test Build:
Staging Doc Server:
About old docs …
What about geoserver 2.8.3? They are available for download, …
Sharing the online docs for older versions is … an anti-feature is it not?
a script to publish old docs? perhaps it downloaded from sourceforge…
Next steps:
Switch all the doc builds over
Switch domain name
Tell Kathy Hoang from planet to shut off the old s3
(she last asked in 2021 about shutting off)
Aside:
geotools: is going to change osgeo servers (this is fine)
geotools calls a script, we need to backport
merge a pull request into main
geowebcache:
still waiting on feedback from chris holmes on this domain name
we could try getting michael smith to ask (as an osgeo director)
approach use the same script to run sphinx build in geowebcache/docs
idea: https://geowebcache.osgeo.org - making a note on https://trac.osgeo.org/osgeo/ticket/2642
See request on devel list.
- waiting for feedback (and +1) on email list
FOSS4G event:
very strong on “gathering of the tribes” flavor, not so much on the “outreach to new people” flavor
even people at their first foss4g they were already using qgis and geoserver and postgis
discussion about this being a european “foss4g-first” approach
1040 people onsight (unexpectedly lots!) + 200 online (unexpectedly small?)
This was a great result!
Assume online videos being made later cut down on online participation
popular topics:
vector tiles remains very popular, but not any feedback from our community
lots of presentations, and geoserver often used in their production
LIADAR ← 3D vector tile specification from Cesium
requires WMTS with gridset 3 dimensions
jukka did a surprise presentation ← good job!
workshop:
installation was only okay (glad to have david and ian helping)
Windows remains trouble
docker mostly worked, but I could not figure out how to help folks running on windows
windows installer was not made (sigh)
Programs folder, running into restrictions on data directory writable etc…
Write into %AppData%/GeoServer/data like old boundless installers
This can be tricky for manual installs, because it’s a hidden folder
cloud env as backup; but needed more
limited permissions etc …
About 5% failed to get geoserver to go; all on windows
People ended up running with Java 18 (gulp!)
Perhaps lead with the Adoptium link in our install instructions?
Docker did okay
5% of folks did docker and were pretty
Jody used it to demo, and run with run different extensions
S3 delayed showing the new docs for a few hours; just a bother…
Amazon asked about setting up an AMI
Responded that companies would need to do this
Kind of odd amazon asking us for a “hand out” … to work for exposure
Presentations:
State of GeoServer
Feature Frenzy
Always lots of questions
Got a new group shot (without jukka who was hiding)
Action: make a blog post!
Drop Java 8
There is a PR from the foss4g code sprint: https://github.com/geoserver/geoserver/pull/6137
This is the documentation change, Ian Turton has already reviewed
blocked: Need a GSIP ← jody
