Attending- Torben Barsballe
Jukka Rahkonnen
Andrea Aime
Kevin Smith
Jody Garnett
Actions from prior meetings:- jody: contact michel about geoserver.css PR [Push back to 2.23]
Agenda1. 2.22-RC release
- Chit chat
Actions- N/A
2.22-RC release
Not aware of urgent PRs that need to be merged.
Missing someone to run the scripts (Andrea checking if he can free some of his work hours)
Jody made branches and jobs.
PR to revert the logging configuration overwrite, currently not passing QA.
GWC release script having some trouble - initial fix merged here.
Action plan:
jody will release geotools
kevin will release geowebcache (and troubleshoot release.rb on modern version of ruby)
volunteer needed for geoserver (apply now!)
Chit chat
Making REST and OGC API coexist: https://github.com/geoserver/geoserver/pull/6225
- Might interact poorly with GWC Rest API wrapper?
The pr to silence the empty settings.xml is merged, however:
the test appender was not working (not collecting events)
action: Jody report test appender not working as a ticket
Logging configuration override discussion
Checksum verification to only update unchanged files → probably not worthwhile, these files don’t change frequently enough for this to be worth it
Will we have a flurry of release notes that all say “Update your logging config” → Even if there are a bunch of changes over the course of several months, people don’t tend to upgrade often enough for this to really be a problem
Docs:
geowebcache?
Not yet … when this is done we can get off s3
We may need a build script?
ruby build script can build; deploying was a pain for s3
can we copy the ant build script from geotools or geoserver?
copy geoserver build jobs as a starting point
geotools? getting swapped over to different server (needs swap to happen and PR)
“geotools-main-docs-lite” remove please (done)
geosever?
Note: with recent swap of latest → stable → maintenance are all the jobs uploading correctly?
