This is the meeting notes from two weeks ago, as I see they were not posted:
Attending- Torben Barsballe
Jukka Rahkonnen
Andrea Aime
Kevin Smith
Jody Garnett
David Blasby
Actions from prior meetings:- Jody report GWC settings.xml test appender not working as a ticket [TODO]
Ask for 2.22.0 Release Volunteer on List [DONE]
Send email to geowebcache-devel about Java 11 switch
Jody: turn GeoTools Java 11 discussion into a proposal [DONE]
Agenda1. Java 11 switch
Translations
GeoServer 2.22.0 release crunch
Security stuff
Spring upgrades
PR roundup / Chit chat
Actions- Still need release manager for 2.22.0
- Jody: geotools#4073 consider adding enum; or close issue
Java 11 switch
GeoTools proposal was made; and got some useful feedback.
We justified this with move to Jakarta but it is insufficient
Apparently Spring 6 will need Java 17 / Jakarta - See GEOS-10638
GeoTools Proposal:
feedback: Have a general heading about advice/warning against newer java
shared branch please jump in
error prone activation checks java version? Not wrong could be simplified
GeoServer Proposal
Order? Three pull-requests …
- GeoServer → GeoWebCache → GeoTools
GeoServer IntelliJ trouble with Java 11:
java.lang.NoSuchMethodError: ‘java.lang.String javax.annotation.Resource.lookup()’
Translations
A non-blocker for 2.22.0 release (can always switch to english). But needs to be addressed.
- Is pull request work? Or does that messup Transifex?
Table for later; in case Alexandre joins.
Fixes/warnings ahead of release?
contact information welcome → text area
workspace single column layout
readme html files not being included in war bundle
anything else from user list feedback
Doc updates:
Contact information docs need an update
Some welcome / tutorial page screen snap
Something about the logging not working in linux with tomcat …
Jody could not reproduce this error on macos
Andrea could not reproduce (but not the same setup) …
No bug report yet … just email discussion
Need a release manager for Nov 18th target …
Security stuff
See geoserver-security email list for details.
Spring upgrades
Spring upgrade is big activity:
Opportunity to upgrade Spring 5.2 → 5.3.14
spring ogcapi modules is going to be very painful as it was extending some dispatcher classes (so rewrite required)
Spring security 2.23 targets:
Opportunity to upgrade 5.1 → 5.5.4
Note 5.3 is no longer supported (newer versions 5.6 / 5.7 are supported)
5.6 is going out of support next week
The old oauth2 client extension is no longer supported; but is still very useful for runtime configurable.
The newer built-in spring-security client is not really suitable for runtime configuration; and many of the methods and classes are finalized
David indicates that upgrade to spring-security oauth2 is possible but not fun
large testing burden for github, google, geonode, etc…
David migrated geonetwork in 2 weeks or so; messy due to everything private/final…
chit chat: Welcome to winter… brr
ReTyping Feature Iterator: allowing match by name, or cast, …
good idea; should be new api
Please use Transform feature source module
Jody will consider adding enum; or close issue
GeoJSON parsing speed improvement incoming (fast double parser flag in newer Jackson release)
FedGeoDay
GeoServer workshop
OGC vs OGC fight (open web services vs ogcapi services)
good presentation on landsat improvement
Policy talks, OSM
FOSS4G Nashville
State of GeoServer 2.22 keynote
Vector mosaic store (maybe)
OGC API how to ship it discussion
ogcapi features is kind of blocked on cql2 and fitler is not ready
filter parameter and filter lang parameter
So filter and ecql for example … can be “okay” and “usable”
