Attending- Torben Barsballe
Jody Garnett
Jukka Rahkonnen
Andrea Aime
Kevin Smith
Actions from prior meetings:- GeoWebCache Doc Build
Agenda1. Jenkins Builds - Docker, GWC
Extension and community modules clean up
Issues with weird attribute names
Release and announcement planning
Map update
Foss4G planning
OSGeo Budget
Actions- Torben: Add GWC Doc build on Jenkins
- Jody: Update sphynx python instructions for GeoServer
Jenkins Builds
GWC Build script written and merged (Thanks Jody).
New python tricks with requirements.txt
worth updating the geoserver / geotools sphinx build instructions? -
sphinx-autobuild is very hand when writing for live feedback
Jody still positive about MkDocs, there is a matching sphinx theme to help ease transition
Will try an experiment and to report back
The are comparable; but MkDocs
TODO: Corresponding Jenkins build
Jenkins docker build is now working, will be tested with next release
GeoTools Java 11 build failing to publish javadocs:
- scp -oStrictHostKeyChecking=no javadocs.zip geotools@anonymised.com:/home/geotools/latest
geotools@anonymised.com: Permission denied (publickey).
Torben is checking it …
It looks like the SSH Agent (with geotools credentials) wasn’t enabled
Java 11 change? That may be when docs started failing …
Now fixed, just needed SSH agent
From email:
extensions → community
xslt
imagemap
community → bit bucket in the sky
WMS-EO
SAML
OWS-Simulate
NSG-WMTS
WMTS-styles
ogcapi/image
ext-teradata
importer-fgdb? May of been disabled during GDAL upgrade
DDS? Nope it is used … by World Wind and Cesium.
printing? Needs some love (jody has a fork of mapfish but it sends daily hate mail).
Docks to clean up:
- geostyler? Docs can be removed …
TODO:
- Andrea is testing importer-fgdb? Can compile; cannot find its native libraries
Strange attribute names?
This is the geoserver way; we do not validate your names - please choose names that work with the protocol you are using
Attributes like
1984
are not valid for XML output; standards like SLD like to work XML stuff like XPath which assume it is working with valid xml stuff -
Some Property Accessors try and check …
Encountered with:
WMS Styling - should be fine as we want a picture not XML
FeatureType customization - cannot fix this stuff as property accessors get stuck
Q: Can property accessor just not check (since it knows it is not doing XPath)?
However if the XPath accessor checks first it assumes
Options:
Use AbstractFactory getPriority()
Or use a marker interface to let simple things be simple
Was waiting on a couple PRs:
Anything else outstanding?
Map update (see below)?
Any outstanding bugs to look at:
representations of some REST resources changed (based on a dependency addition)
double check that changing internationalization changes all (rather than some) of the displayed messages
Q: Are they all translated?
Map update
PR: https://github.com/geoserver/geoserver/pull/6527
Size of data increase; asked on email list (sorry)
todo: Fix the SLDs (some are invalid)
swapping language: en / it … others can be done over time
How is INSPIRE language parameter intended to be used for GetCapabilities and GetMap?
GetMap:
Would it be nice if layer preview change this?
LANGUAGE= ends up being a vendor parameter?
Could add a drop down the openlayer preview
GetCapabilities
We would need a bit more knowledge on what translations were available for a geoserver installing. The INSPIRE module can advertise what languages are supported.
Foss4G planning
Talk and workshop round up; submit on Feb 19th …
reached out geomesa folks for an update
reached out to gabe / camptocamp – no update yet
OSGeo Budget
See: https://wiki.osgeo.org/wiki/OSGeo_Budget_2023
Yes to “initiative” for replacing org.opengis use:
Asked for 20k, 10k approved with 5k funding for downstream projects
OSGeo is asking Apache / others for enough funding to meet our target
Meeting to be scheduled with Apache Foundation
No to “security” initiative
Is this a good idea? Anyone else willing to push it …
Ideas:
Push bug button on home page website
Put a “information” message to admins when logged in to admin UI
(control with Environment variable/checkbox in the GUI) -
GeoTools Security policy is live
Enabled vulnerability reporting as an experiment; if successful we will add to GeoServer
GeoServer fundraising progress:
We have $3700 from 2022 to start from; but this does not match project needs for security fixes (for example)
https://blog.qgis.org/2023/01/16/crowd-funding-call-2023/ and https://www.qgis.org/en/site/about/sustaining_members.html
A lot of small donations, with the bulk of funding from larger contributions
Howard went and did the legwork to ask for larger amounts
